Кто может это обьяснить?
Эта ошибка переодически выскакивает у меня, после дебага. Помогоет токо перезагрузка компа. Parser Error Message: Access is denied: 'RadTabStrip'. Source Error: Line 196: <add assembly="System.EnterpriseServices, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/> Line 197: <add assembly="System.Web.Mobile, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/> Line 198: <add assembly="*"/> Line 199: </assemblies> Line 200: </compilation> Source File: c:\windows\microsoft.net\framework\v1.1.4322\Config\machine.config Line: 198 Assembly Load Trace: The following information can be helpful to determine why the assembly 'RadTabStrip' could not be loaded. === Pre-bind state information === LOG: DisplayName = RadTabStrip (Partial) LOG: Appbase = file:///C:/MarketPowerPro/ASP LOG: Initial PrivatePath = bin Calling assembly : (Unknown). === LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind). LOG: Post-policy reference: RadTabStrip LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/8c9bead2/ea714e40/RadTabStrip.DLL. LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/root/8c9bead2/ea714e40/RadTabStrip/RadTabStrip.DLL. LOG: Attempting download of new URL file:///C:/MarketPowerPro/ASP/bin/RadTabStrip.DLL. LOG: Publisher policy file is not found. LOG: No redirect found in host configuration file (C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\aspnet.config). LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\config\machine.config. LOG: Post-policy reference: RadTabStrip, Version=2.5.1.0, Culture=neutral, PublicKeyToken=a87324b017ca21ce ... |
| 20.07.2006, 18:47 |
Я могу :). В Винде висит служба под названием Indexing Service. Именно она периодически лочит теневую копию твоей сборки. Есть 2 варианта решения проблемы: 1. Отключить эту службу нафиг (но приетом упадет общая производительность поиска файлов на винте) 2. Создать правило в "Computer Managment\Службы и приложения\Служба индексирования" для папки, в которую ASP.NET складывает теневые копии. В твоем случае C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/. ... |
| 20.07.2006, 19:25 |
Забыл дописать... Так вот, во втором варианте нужно запретить индексирование этой папки. PS: кста, не всегда работает... ... |
| 20.07.2006, 19:28 |
start [/forum/topic.php?desktop=1&fid=18&tid=1391466]: |
221ms |
46ms |
| others: | 232ms |
| total: | 548ms |
