Forms autentication, помогите разобраться
с етим кодом , все нормально: <%@ Page LANGUAGE="C#" %> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" > <head> <title>Forms Authentication</title> <script runat="server"> private void Page_Load(object Src, EventArgs e ) { Welcome.InnerHtml = "Hello, " + Context.User.Identity.Name; } private void Signout_Click(Object sender, EventArgs e) { FormsAuthentication.SignOut(); Response.Redirect("login.aspx"); } </script> <body> <h3><font face="Verdana">Using Forms Authentication</font></h3> <span id="Welcome" runat=server/> <form id="Form1" runat=server> <input id="Submit1" type="submit" OnServerClick="Signout_Click" Value="Signout" runat="server"/><p> </form> </body> </html> web. config <?xml version="1.0"?> <configuration> <system.web> <authentication mode="Forms"> <forms name=".ASPXFORMSAUTH" loginUrl="login.aspx" protection="All" timeout="60"/> </authentication> <authorization> <deny users="?"/> </authorization> <compilation debug="true"/></system.web> </configuration> --------------------------- но хотелось сделать в code-behind, теперь въдает ошибку Compiler Error Message: CS0103: The name 'UserEmail' does not exist in the current context Line 19: // лишь пользователю doug@programmingasp.net Line 20: // с паролем 'password' Line 21: if ((UserEmail.Value == "doug@programmingasp.net") && Line 22: (UserPass.Value == "password")) Line 23: { вот код с ошибкой: using System; using System.Web; using System.Web.UI; using System.Web.UI.HtmlControls; using System.Web.UI.WebControls; using System.Web.UI.WebControls.WebParts; using System.Drawing; using System.Web.Security; public class passvalidate: Page { protected RequiredFieldValidator RequiredFieldValidator1; protected RequiredFieldValidator RequiredFieldValidator2; protected Button Button1; void Login_Click(object sender, EventArgs e) { // Аутентификация пользователя: в этом примере вход разрешается // лишь пользователю doug@programmingasp.net // с паролем 'password' if ((UserEmail.Value == "doug@programmingasp.net") && (UserPass.Value == "password")) { FormsAuthentication.RedirectFromLoginPage(UserEmail.Value, false); } else { Msg.Text = "Invalid Credentials: Please try again"; } } } ... |
| 31.07.2006, 17:22 |
Ну а где у тебя собсно текстбоксы UserEmail и UserPassword? Многие вещи нам непонятны не оттого, что наши понятия слабы, а оттого, что данные вещи не входят в круг наших понятий. ... |
| 31.07.2006, 18:35 |
Вот они: <%@ Page src="Login.aspx.cs" Inherits="login" %> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" > <body> <form id="Form1" runat="server"> <center> <h3> <font face="Verdana" color="blue">Login Page</font> </h3> <table> <tr> <td> Email: </td> <td> <input id="UserEmail" type="text" runat="server" size="30" /> </td> <td> Основы разработки приложений в ASP.NET <ASP:RequiredFieldValidator ID="RequiredFieldValidator1" ControlToValidate="UserEmail" Display="Static" ErrorMessage="*" runat="server" /> </td> </tr> <tr> <td> Password: </td> <td> <input id="UserPass" type="password" runat="server" size="30" /> </td> <td> <ASP:RequiredFieldValidator ID="RequiredFieldValidator2" ControlToValidate="UserPass" Display="Static" ErrorMessage="*" runat="server" /> </td> </tr> <tr> <td colspan="3" align="center"> <asp:button ID="Button1" text="Login" OnClick="Login_Click" runat="server"> </asp:button> <P> <asp:Label id="Msg" ForeColor="red" Font-Name="Verdana" Font-Size="10" runat="server" /> </td> </tr> </table> </center> </form> </body> </html> ... |
| 31.07.2006, 20:17 |
| 31.07.2006, 20:17 |
start [/forum/topic.php?desktop=1&fid=18&tid=1391143]: |
183ms |
32ms |
| others: | 230ms |
| total: | 488ms |
