Ошибка "statement conflicted with"
Схлопотал такую ошибку: DELETE statement conflicted with COLUMN REFERENCE constraint 'FK_forums_Posts_forums_Threads'. The conflict occurred in database 'Forum', table 'forums_Posts', column 'ThreadID'. The statement has been terminated. Object 'forums_Threads' was successfully marked for recompilation. Object 'forums_Posts' was successfully marked for recompilation. Object 'forums_SearchBarrel' was successfully marked for recompilation. Почему и как с ней бороться - исходники не мои, так что искать там ошибку сложно. Может, что-то в таблице случилось? ... |
| 22.08.2006, 15:42:00 |
start [/forum/topic.php?desktop=1&fid=18&tid=1390351]: |
178ms |
27ms |
| others: | 202ms |
| total: | 445ms |
