Help with report
Voobwem! Estj stranica na nej formiruetsja otchet(tochnee formiruetsja na server) pri nazhatii na knopku: protected void btnOk_Click(object sender, EventArgs e) { if (lblReportname.Text == "APlan-/A-Gang / Arbeits-Gang") { MyCallParams = "qd_arbeitsgang|betr_auftrag_id|" + ddlPosition.SelectedValue; ProcessWebservice("TRep_Arbeitsgang", MyCallParams); } if (lblReportname.Text == "APlan-/A-Gang / Arbeits-Plan") { MyCallParams = "qd_position|position_id|" + ddlPosition.SelectedValue; ProcessWebservice("TrptArbeitsplan", MyCallParams); } if (lblReportname.Text == "Status / Kommissions-Status") { MyCallParams = "qd_kommission|kommission_id|" + ddlKommission.SelectedValue + "," + "qd_position|position_id|" + ddlPosition.SelectedValue + "," + "variable|nuroffenepos|true"; ProcessWebservice("TRep_KommStatus", MyCallParams); } Mne nado chtobi otchet otkrivalsja v novom okne... dlja etogo ja sdelal ewe odnu stranicu i pri nazhatii na knopku: BtnOk1.Attributes.Add("onclick", "window.open('default4.aspx'); return false;"); No kak perenesti parametri otcheta tuda? i kuda? Otchet: private void ProcessWebservice(String ReportName, String ReportParams) { ebkservice.IWebPrintServiceservice Webservice = new ebkservice.IWebPrintServiceservice(); Byte[] Data = Webservice.getPdfReport(ReportName, ReportParams); //Response.ContentType = "application/pdf"; //Response.AddHeader("Content-Disposition", "attachment"); //Response.AddHeader("Content-Disposition", "inline"); Response.BinaryWrite(Data); Response.End(); Zarannee spasibo! ... |
| 13.09.2006, 15:56:43 |
Help with report
Neuzheli nikto ne stalkivalsja s takim... soeredachej parametrov? ... |
| 13.09.2006, 17:08:52 |
start [/forum/topic.php?desktop=1&fid=18&tid=1389548]: |
181ms |
27ms |
| others: | 246ms |
| total: | 488ms |
