RangeValidator
Есть FormView, в нём: <asp:TextBox ID="nameTextBox" runat="server" Text='<%# Bind("name") %>'></asp:TextBox> <asp:RangeValidator ID="RangeValidator1" runat="server" ControlToValidate="nameTextBox" ErrorMessage="размер названия группы должен быть от 1 до 50 символов" MaximumValue="5" MinimumValue="1" Display="Dynamic"></asp:RangeValidator> Если я ввожу в nameTextBox буквы (неважно сколько), отображается ErrorMessage RangeValidator'а, а если — цифры, то — выдаётся ошибка: String[1]: the Size property has an invalid size of 0. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.InvalidOperationException: String[1]: the Size property has an invalid size of 0. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [InvalidOperationException: String[1]: the Size property has an invalid size of 0.] System.Data.SqlClient.SqlParameter.Validate(Int32 index) +167 System.Data.SqlClient.SqlCommand.BuildParamList(TdsParser parser, SqlParameterCollection parameters) +227 System.Data.SqlClient.SqlCommand.BuildExecuteSql(CommandBehavior behavior, String commandText, SqlParameterCollection parameters, _SqlRPC& rpc) +413 System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +1121 System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +334 System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +407 System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +149 System.Web.UI.WebControls.SqlDataSourceView.ExecuteDbCommand(DbCommand command, DataSourceOperation operation) +493 System.Web.UI.WebControls.SqlDataSourceView.ExecuteInsert(IDictionary values) +551 System.Web.UI.DataSourceView.Insert(IDictionary values, DataSourceViewOperationCallback callback) +173 System.Web.UI.WebControls.FormView.HandleInsert(String commandArg, Boolean causesValidation) +626 System.Web.UI.WebControls.FormView.HandleEvent(EventArgs e, Boolean causesValidation, String validationGroup) +745 System.Web.UI.WebControls.FormView.OnBubbleEvent(Object source, EventArgs e) +163 System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +56 System.Web.UI.WebControls.FormViewRow.OnBubbleEvent(Object source, EventArgs e) +118 System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +56 System.Web.UI.WebControls.LinkButton.OnCommand(CommandEventArgs e) +106 System.Web.UI.WebControls.LinkButton.RaisePostBackEvent(String eventArgument) +175 System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +31 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +32 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +242 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3840 В чём может быть ошибка? ... |
| 02.09.2006, 20:13 |
start [/forum/topic.php?desktop=1&fid=18&tid=1388907]: |
51ms |
23ms |
| others: | 258ms |
| total: | 366ms |
