Что за ошибка?
Server Error in '/PiterReport1' Application. -------------------------------------------------------------------------------- Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed. Details: To enable the details of this specific error message to be viewable on the local server machine, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "RemoteOnly". To enable the details to be viewable on remote machines, please set "mode" to "Off". <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly"/> </system.web> </configuration> Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="On" defaultRedirect="mycustompage.htm"/> </system.web> </configuration> Хелп! ... |
| 31.10.2006, 16:03 |
Что за ошибка?
Это просто сообщение о том, что в приложении произошла ошибка, но вам тебе н покажут, т.к. у вас не настроен как нужно web.config Как настроить: авторDetails: To enable the details of this specific error message to be viewable on the local server machine, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "RemoteOnly". To enable the details to be viewable on remote machines, please set "mode" to "Off". ... |
| 31.10.2006, 16:15 |
Что за ошибка?
Там все написано (с). Любой эксепшен, при данной настройке будет выдавать такое окошко. Если ты хочешь видеть эксепшен, напиши <customErrors mode="Off"/> Если хочешь что б пользователь видел красивое окошечко, гласящее: "Чет мы профтыкали, у нас тут все паламалось. Позвоните нам, и расскажите как исправить" — делаеш следующую настройку: <customErrors mode="On" defaultRedirect="mycustompage.htm" /> или <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> и в mycustompage.htm ложиш красивую надпись :) ... |
| 31.10.2006, 16:20 |
Что за ошибка?
Раскомментировал <customErrors mode="RemoteOnly" defaultRedirect="GenericErrorPage.htm"> <error statusCode="403" redirect="NoAccess.htm" /> <error statusCode="404" redirect="FileNotFound.htm" /> </customErrors> но толку всё равно никакого,может кто-нибудь подскажет? ... |
| 31.10.2006, 16:38 |
Что за ошибка?
Здравствуйте, Lenny, Вы писали: и ещё, если у тебя есть "Crystal Report" поудаляй его со всех страничек. Это тоже может быть причиной ... |
| 31.10.2006, 16:42 |
start [/forum/topic.php?desktop=1&fid=18&tid=1388029]: |
53ms |
40ms |
| others: | 210ms |
| total: | 340ms |
