Ошибка при сериализации?
Ошибка: Unable to serialize the session state. In 'StateServer' and 'SQLServer' mode, ASP.NET will serialize the session state objects, and as a result non-serializable objects or MarshalByRef objects are not permitted. The same restriction applies if similar serialization is done by the custom session state store in 'Custom' mode. Stack Trace: [RemotingException: Remoting cannot find field __identity on type System.MarshalByRefObject.] Что такое __identity on type System.MarshalByRefObject???? ... |
| 13.11.2006, 14:33 |
start [/forum/topic.php?desktop=1&fid=18&tid=1387636]: |
28ms |
31ms |
| others: | 218ms |
| total: | 326ms |
