о пользовательских контролах
есть след контрол: public class TimeControl : System.Web.UI.WebControls.WebControl { public int Hours { get { // здесь нужно вернуть выбранное значение в селекте с hours } } protected override void RenderContents(System.Web.UI.HtmlTextWriter writer) { writer.RenderBeginTag(HtmlTextWriterTag.Div); writer.AddAttribute(HtmlTextWriterAttribute.Width, "100px"); writer.RenderBeginTag(HtmlTextWriterTag.Table); writer.RenderBeginTag(HtmlTextWriterTag.Tr); writer.RenderBeginTag(HtmlTextWriterTag.Td); writer.Write("Hours: "); writer.RenderEndTag(); writer.RenderBeginTag(HtmlTextWriterTag.Td); writer.AddAttribute("id", "selectHour" + this.ID); writer.RenderBeginTag(HtmlTextWriterTag.Select); for (int i = 0; i < 12; i++) { writer.AddAttribute(HtmlTextWriterAttribute.Value, i.ToString()); writer.RenderBeginTag(HtmlTextWriterTag.Option); writer.Write(i.ToString()); writer.RenderEndTag(); } writer.RenderEndTag(); writer.RenderEndTag(); writer.RenderBeginTag(HtmlTextWriterTag.Td); writer.Write("Minutes: "); writer.RenderEndTag(); writer.RenderBeginTag(HtmlTextWriterTag.Td); writer.RenderBeginTag(HtmlTextWriterTag.Select); for (int i = 0; i < 60; i=i+5) { writer.AddAttribute(HtmlTextWriterAttribute.Value, i.ToString()); writer.RenderBeginTag(HtmlTextWriterTag.Option); writer.Write(i.ToString()); writer.RenderEndTag(); } writer.RenderEndTag(); writer.RenderEndTag(); writer.RenderBeginTag(HtmlTextWriterTag.Td); writer.AddAttribute(HtmlTextWriterAttribute.Type, "radio"); writer.AddAttribute(HtmlTextWriterAttribute.Name, this.ID + "group"); writer.AddAttribute(HtmlTextWriterAttribute.Value, "AM"); writer.AddAttribute(HtmlTextWriterAttribute.Checked, "true"); writer.RenderBeginTag(HtmlTextWriterTag.Input); writer.Write("AM"); writer.RenderEndTag(); writer.RenderBeginTag(HtmlTextWriterTag.Td); writer.AddAttribute(HtmlTextWriterAttribute.Type, "radio"); writer.AddAttribute(HtmlTextWriterAttribute.Name, this.ID + "group"); writer.AddAttribute(HtmlTextWriterAttribute.Value, "PM"); writer.RenderBeginTag(HtmlTextWriterTag.Input); writer.Write("PM"); writer.RenderEndTag(); writer.RenderEndTag(); writer.RenderEndTag(); writer.RenderEndTag(); //writer. //base.RenderContents(writer); } } необходимо в свойстве Hours вернуть значение, выбранное в селекте selectHour. Как это сделать?... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 17.11.2006, 15:49 |
для этого заведите web control. он сохрпаняет свое состояние и вы сможете возвращать в свойствте Hour выбранное значение селекта ... |
| 17.11.2006, 17:12 |
Реализовать IPostBackDataHandler где в LoadPostData получать выбранное в селекте значение. Ну и сохранять его в ViewState например. Многие вещи нам непонятны не оттого, что наши понятия слабы, а оттого, что данные вещи не входят в круг наших понятий. ... |
| 17.11.2006, 17:14 |
Здравствуйте, parapet, Вы писали: P>необходимо в свойстве Hours вернуть значение, выбранное в селекте selectHour. Как это сделать? самое простое это проанализировав значение из: Request["selectHour" + this.ID] ... |
| 18.11.2006, 12:58 |
Здравствуйте, cadet354, Вы писали: C>Здравствуйте, parapet, Вы писали: P>>необходимо в свойстве Hours вернуть значение, выбранное в селекте selectHour. Как это сделать? C>самое простое это проанализировав значение из: C>Request["selectHour" + this.ID] а оно пустое :(... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 21.11.2006, 11:45 |
Здравствуйте, parapet, Вы писали: P>Здравствуйте, cadet354, Вы писали: C>>Здравствуйте, parapet, Вы писали: P>>>необходимо в свойстве Hours вернуть значение, выбранное в селекте selectHour. Как это сделать? C>>самое простое это проанализировав значение из: C>>Request["selectHour" + this.ID] P>а оно пустое :( прошу прощения, надо не ID, а name, посмотри с каким name сгенерировался контрол, по идеи должен с ClientId... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 21.11.2006, 12:42 |
Помоему надо с ViewState работать, хоть могу и ошибаться... если стоит MSDN, тут глянь: ms-help://MS.MSDNQTR.v80.en/MS.MSDN.v80/MS.VisualStudio.v80.en/dv_aspnetctrlauth/html/9e98c7de-a888-48df-b14e-02ec8bef7681.htm]здесь ... |
| 21.11.2006, 13:00 |
Здравствуйте, Styk, Вы писали: S>Помоему надо с ViewState работать, хоть могу и ошибаться... S>если стоит MSDN, тут глянь: S>ms-help://MS.MSDNQTR.v80.en/MS.MSDN.v80/MS.VisualStudio.v80.en/dv_aspnetctrlauth/html/9e98c7de-a888-48df-b14e-02ec8bef7681.htm о! RSDN авоматом нашел ссылку, респект! :super: ... |
| 21.11.2006, 13:01 |
Здравствуйте, monstrU, Вы писали: U>для этого заведите web control. он сохрпаняет свое состояние и вы сможете возвращать в свойствте Hour выбранное значение селекта у меня 3 элемента на странице. Нужно узнать значение каждого из них.... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 21.11.2006, 14:16 |
Здравствуйте, Styk, Вы писали: там просто сохранение значения в ViewState, а у меня ситуация когда контрол рендерит несколько элементов HTML, и их значения нужно поместить хоть в ту же сессию...... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 21.11.2006, 14:16 |
Здравствуйте, cadet354, Вы писали: P>>а оно пустое :( C>прошу прощения, надо не ID, а name, посмотри с каким name сгенерировался контрол, C>по идеи должен с ClientId это работающий вариант! :up:... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 21.11.2006, 14:26 |
Здравствуйте, Dimon aka Manowar, Вы писали: DAM>Реализовать IPostBackDataHandler где в LoadPostData получать выбранное в селекте значение. Ну и сохранять его в ViewState например. работает как написал cadet354 : Re[3]: о пользовательских контролах а как с IPostBackDataHandler? У меня что-то дебаггер даже не заходит в LoadPostData :xz:... << RSDN@Home 1.1.4 stable SR1 rev. 568>> ... |
| 21.11.2006, 14:26 |
start [/forum/topic.php?desktop=1&fid=18&tid=1387384]: |
40ms |
62ms |
| others: | 228ms |
| total: | 372ms |
