Проблема с Ораклом
При попытке подключиться к Ораклу из АСП.НЕТ, он выдает ошибку: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.InvalidOperationException: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Source Error: Line 29: Line 30: Line 31: conn.Open(); Line 32: //OracleCommand cmd = new OracleCommand(); Line 33: //cmd.CommandText = "SELECT * from news"; Хотя в то же время, из ISQl все нормально работает. В чем может быть проблема? ... |
| 21.11.2006, 15:53 |
start [/forum/topic.php?desktop=1&fid=18&tid=1387377]: |
37ms |
30ms |
| others: | 212ms |
| total: | 315ms |
