cms на asp.net воспринимает контент как потенциально опасный
Здравствуйте, Уважаемые форумчане. Столкнулся с одной небольшой проблемкой. Я работаю с одной cms (.net forge). При добавлении контента на сайт, cms воспринимает мой контент как потенциально опасный и выкидывается ошибка: Server Error in '/' Application. A potentially dangerous Request.Form value was detected from the client (VisualEditor="... %> <asp:Content ID="Con..."). Description: ASP.NET has detected data in the request that is potentially dangerous because it might include HTML markup or script. The data might represent an attempt to compromise the security of your application, such as a cross-site scripting attack. If this type of input is appropriate in your application, you can include code in a web page to explicitly allow it. For more information, see http://go.microsoft.com/fwlink/?LinkID=212874. Exception Details: System.Web.HttpRequestValidationException: A potentially dangerous Request.Form value was detected from the client (VisualEditor="... %> <asp:Content ID="Con..."). Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [HttpRequestValidationException (0x80004005): A potentially dangerous Request.Form value was detected from the client (VisualEditor="... %> <asp:Content ID="Con...").] System.Web.HttpRequest.ValidateString(String value, String collectionKey, RequestValidationSource requestCollection) +9665149 System.Web.HttpRequest.ValidateHttpValueCollection(HttpValueCollection collection, RequestValidationSource requestCollection) +184 System.Web.HttpRequest.get_Form() +55 System.Web.HttpRequest.get_Item(String key) +42 Bitrix.Main.BitrixHttpModule.<Init>b__2(Object sender, EventArgs e) +81 System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69 Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.17929 В принципе здесь если пройти по ссылке из сообщения http://go.microsoft.com/fwlink/?LinkID=212874 рекомендуют сделать несколько изменений в web.config, но мне данное решение не помогает(( Может кто-нибудь знает в чем проблема? ... |
| 11.12.2012, 10:23 |
AlexanderModestov, а на самой странице <@ Page validateRequest="false" %> пробовал ставить? ... |
| 11.12.2012, 10:55 |
не помогает( ... |
| 11.12.2012, 12:22 |
AlexanderModestov, если не чо не помогает, зачит чет не то сделал, чисти строку на клиенте ... |
| 11.12.2012, 13:12 |
Можно попробовать это . 2.0 наверное подойдет. ... |
| 12.12.2012, 02:48 |
start [/forum/topic.php?desktop=1&fid=18&tid=1358966]: |
179ms |
43ms |
| others: | 217ms |
| total: | 491ms |
