Server Error in '/test' Application
Добрый день! Не нашел похожей ситуации, поэтому создал тему. На днях столкнулся с проблеймой при связки .NET и MSSQL. На локальном сервере все работает нормально, но как только переношу на IIS выдает ошибку: This control does not allow connection strings with the following keywords: ‘Integrated Security’, ‘Trusted_Connection’. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: Microsoft.SharePoint.WebPartPages.DataSourceControlDisabledException: This control does not allow connection strings with the following keywords: ‘Integrated Security’, ‘Trusted_Connection’. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [DataSourceControlDisabledException: This control does not allow connection strings with the following keywords: ‘Integrated Security’, ‘Trusted_Connection’.] Microsoft.SharePoint.WebControls.SPSqlDataSource.CheckConnectionString(String ConnectionString) +16809617 Microsoft.SharePoint.WebControls.SPSqlDataSource.GetView(String viewName) +61 System.Web.UI.WebControls.DataBoundControl.ConnectToDataSourceView() +193 System.Web.UI.WebControls.DataBoundControl.OnLoad(EventArgs e) +28 System.Web.UI.Control.LoadRecursive() +66 System.Web.UI.Control.LoadRecursive() +191 System.Web.UI.Control.LoadRecursive() +191 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2428 Содержание Web.config Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. ... |
| 13.08.2013, 10:13:27 |
Удалить "Integrated Security=SSPI;" ... |
| 13.08.2013, 11:02:37 |
start [/forum/search_topic.php?author=FrankBones&author_mode=last_posts&do_search=1]: |
25ms |
59ms |
64ms |
| others: | 5351ms |
| total: | 5591ms |
