GridView 'GridView1' активировало событие PageIndexChanging, которое не было обработано.
GridView 'GridView1' активировало событие PageIndexChanging, которое не было обработано. <%@ Page Language="C#" AutoEventWireup="true" CodeBehind="WebForm1.aspx.cs" Inherits="WebApplication1.WebForm1" %> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns=" http://www.w3.org/1999/xhtml"> <head runat="server"> <title></title> </head> <body> <form id="form1" runat="server"> <div> <asp:GridView ID="GridView1" runat="server" AllowPaging="True" PageSize="2" onselectedindexchanging="GridView1_SelectedIndexChanging"> </asp:GridView> </div> </form> </body> </html> Код С# ------------------------------------------------------------------------------- using System; using System.Collections.Generic; using System.Data; using System.Data.SqlClient; using System.Linq; using System.Web; using System.Web.UI; using System.Web.UI.WebControls; using System.IO; using System.Net; namespace WebApplication1 { public partial class WebForm1 : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) { if (!IsPostBack) { string conString = @"Data Source=(local);Initial Catalog=Library;Integrated Security=True"; SqlConnection sqlcon = new SqlConnection(conString); SqlCommand sqlcmd; SqlDataAdapter da; DataTable dt = new DataTable(); String query; query = "select * from [Library].[dbo].[Book] where StateBook='1';"; sqlcmd = new SqlCommand(query, sqlcon); sqlcon.Open(); da = new SqlDataAdapter(sqlcmd); dt.Clear(); da.Fill(dt); if (dt.Rows.Count > 0) { GridView1.DataSource = dt; GridView1.DataBind(); } else { //Label1.Text = "Файлов ненайдено"; //Label1.Visible = true; } sqlcon.Close(); } } protected void GridView1_SelectedIndexChanging(object sender, GridViewSelectEventArgs e) { GridView1.PageIndex = e.NewSelectedIndex; GridView1.DataBind(); } } } --------------------------------------------------- Помогите исправить. Я новичок в ASP.NET Спасибо ... |
| 21.06.2014, 09:53:34 |
start [/forum/topic.php?desktop=1&fid=18&tid=1357215]: |
25ms |
67ms |
50ms |
| others: | 321ms |
| total: | 531ms |
