selrow возвращает null на каждый второй клик на том же ряду . Edit form jqGrid.
This happening in Edit form of jqGrid. I need to disable some fields based on one field value. selrow returns first time number, then null, then number, then null and so on. Basically on every other click it returns null. Что мне делать? Код: c# 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. ... |
| 09.10.2014, 19:59:49 |
start [/forum/topic.php?desktop=1&fid=18&tid=1356948]: |
31ms |
74ms |
25ms |
87ms |
| others: | 343ms |
| total: | 597ms |
