ссылка в jstree (mvc)
Скажите пожалуйста, как сделать ссылку href на ветке дерева в таком коде? Код: plaintext $("#demoTree").jstree({ "themes": { "theme": "default", "dots": true, "icons": false, "url": "/Scripts/themes/default/style.css" }, "json_data": { "ajax": { "async": true, "url": "/Home/GetDataAjax", "type": "POST", "data": function(n) { return { id: n.attr ? n.attr("id") : 0 } } } }, "plugins": ["themes", "json_data", "ui"] }).bind("select_node.jstree", function(event, data) { }); }); Заранее благодарен. ... |
| 06.03.2015, 09:29:31 |
Учимся использовать тэги оформления кода - FAQ ... |
| 06.03.2015, 10:08:35 |
vah, Тынц Next we want to add some additional information(fields) about each object, so that we can operate on those fields. The additional information is stored as field "metadata". "metadata" is again an object containing key-value pairs for the additional information. So, the structure of "metadata" would be "metadata":{} Let's name the information we want to store as "href". Lets store the value for this key as the url(We need it for our example). For object having "data" as "Gmail", its "metadata" becomes "metadata":{"href":"www.gmail.com"} ... |
| 06.03.2015, 11:21:13 |
start [/forum/topic.php?desktop=1&fid=18&tid=1356662]: |
30ms |
91ms |
25ms |
82ms |
| others: | 299ms |
| total: | 568ms |
