Регулярка не едет или?
RegularExpressionValidator пускает пустые значения для ^[1-9]\d{0,4}(?:\.\d{2})?$ ^\d+$ аналогично ... |
| 20.01.2016, 19:43:31 |
waszkiewicz, все верно, читайте документацию: https://msdn.microsoft.com/en-us/library/system.web.ui.webcontrols.regularexpressionvalidator(v=vs.110).aspx NoteValidation succeeds if the input control is empty. If a value is required for the associated input control, use a RequiredFieldValidator control in addition to the RegularExpressionValidator control. ... |
| 21.01.2016, 08:03:58 |
start [/forum/topic.php?desktop=1&fid=18&tid=1356069]: |
40ms |
41ms |
| others: | 273ms |
| total: | 402ms |
