Полезные ссылки
Есть предложение постить сюда ссылки, которые могут быть интересны разработчику ASP.Net приложений. С одним условием - ссылка должна быть не общей, а конкретной с кратким описанием. Затем можно будет внести в FAQ по .Net. Если есть предложения/возражения прошу высказаться. Например: неправильно: http://www.asp.net/ правильно: Control Gallery http://www.asp.net/Default.aspx?tabindex=2&tabid=31 The Control Gallery is a directory of ASP.NET controls that you can use in your applications. The number in parantheses indicates how many controls are available in the category. Only controls that can be used with the released version of ASP.NET are listed. The ASP.NET Web Matrix Project http://www.asp.net/webmatrix/default.aspx?tabIndex=4&tabId=46 ASP.NET Web Matrix is a community-supported, easy-to-use WYSIWYG application development tool for ASP.NET. It can be installed via a quick 1.3 MB download (about 5 minutes using a 56Kb modem). New features include: Access database support, J# support, design time enhancements including improved table editing and user-control rendering, many bug fixes, and much more! Best of all? It's absolutely free! ... |
| 29.10.2003, 09:00:00 |
Полезные ссылки
Работаем с GIF HOW TO: Save a .gif File with a New Color Table By Using Visual C# .NET The CompuServe Graphics Interchange Format (GIF) is designed with a maximum of 256 colors that are arranged in a color table. To make common modifications to a .gif image file, you must change a custom color table. However, when System.Drawing edits an Image object and is then asked to save the image with the GIF encoder, the resulting .gif file contains a halftone color table. To save an Image with a custom color table by using the GIF encoder, you must work with a 256-color copy of the Image that System.Drawing has not modified. Туда же Transparent Gifs with GDI+ / System.Drawing Как создать Gif с прозрачным фоном на АСП.НЕТ странице. Developer's CoockBook Generating and Manipulating Images "Recently it has been getting hard to find books that just get to the point, but this book is perfect. If you are just starting out with ASP.NET this book will tell you exactly what you need to know clearly and concisely. If you are an ASP.NET pro then this book is just what you need to remember all those things that are hard to remember. " Глава 22, множество примеров и техник по работе с изображениями. Ладно, в этот раз вышло не очень, так что сильно не пинайте, в следующий подготовлю получше :) Magnus ... |
| 29.10.2003, 15:02:35 |
Полезные ссылки
Всё-таки понадоедаю всем ещё. Ссылки очень попрошу писать именно так, как я указал. http://www.asp.net/Default.aspx?tabindex=2&tabid=31 Представьте, если это .NET Client Web The Official Microsoft Windows Forms Community Site всё в ФАК переносить, как оно будет там выглядеть. Я имею ввиду, что каждую ссылку мне придётся переделывать. Пожалейте :) ... |
| 29.10.2003, 15:53:27 |
Полезные ссылки
;) Убедил. Бесплатный хостинг поддерживающий ASP.NET http://brinkster.com/AboutSolutionComparison.asp Бесплатный пакет невелик но главное присутствует. Magnus ... |
| 29.10.2003, 16:33:41 |
Полезные ссылки
Microsoft Application Blocks for .NET Data Access Application Block Overview http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnbda/html/daab-rm.asp Summary : The Data Access Application Block is a .NET component that contains optimized data access code that will help you call stored procedures and issue SQL text commands against a SQL Server database. It returns SqlDataReader, DataSet, and XmlReader objects. You can use it as a building block in your own .NET-based application to reduce the amount of custom code you need to create, test, and maintain. The download provides full Visual C# and Visual Basic .NET source code and comprehensive documentation. Рекомендую. ... |
| 09.12.2003, 14:47:02 |
Полезные ссылки
Building Secure ASP.NET Applications: Authentication, Authorization, and Secure Communication http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnnetsec/html/secnetlpMSDN.asp Applies to: Microsoft® .NET Framework version 1.0 ASP.NET Enterprise Services Web services .NET Remoting ADO.NET Visual Studio® .NET SQL™ Server Windows® 2000 Summary : This guide presents a practical, scenario driven approach to designing and building secure ASP.NET applications for Windows 2000 and version 1.0 of the .NET Framework. It focuses on the key elements of authentication, authorization, and secure communication within and across the tiers of distributed .NET Web applications. (This roadmap: 6 printed pages; the entire guide: 608 printed pages) ... |
| 10.12.2003, 14:43:44 |
Полезные ссылки
Dictionary of Algorithms and Data Structures http://www.nist.gov/dads/ This is a dictionary of algorithms, algorithmic techniques, data structures, archetypical problems, and related definitions. Algorithms include common functions, such as Ackermann's function. Problems include traveling salesman and Byzantine generals. Some entries have links to implementations and more information. Index pages list entries by area and by type. The two-level index has a total download 1/20 as big as this page. Don't use this site to cheat. Teachers, contact us if we can help. To define or correct terms, please contact Paul E. Black. We need help in automata theory, combinatorics, parallel or randomized algorithms, heuristics, and quantum computing. We do not include algorithms particular to business data processing, communications, operating systems or distributed algorithms, programming languages, AI, graphics, or numerical analysis: it is tough enough covering "general" algorithms and data structures. However, if you want to tackle one of these areas, we'll consider including them. Some terms with a leading variable, such as n-way, m-dimensional, or p-branching, are under k-. You may find terms dealing with hardware, the computer industry, slang, etc., in the Free On-Line Dictionary Of Computing or in A Glossary of Computer Oriented Abbreviations and Acronyms. ... |
| 10.12.2003, 16:05:09 |
Полезные ссылки
.Net Собеседник - Новости мира Net, C#, ASP.Net http://subscribe.ru/catalog/comp.soft.prog.dotnetgrains Вот, решил сделать рассылку. К этому меня натолкнули попытки переводов статей, которые я размещал в форуме - всё-таки форум для таких вещей не место. Как получилось - судить вам, так что жду ваших отзывов и предложений. Планируется 2 выпуска в месяц, в первых 3-4-х будут использованы переводы, которые уже здесь лежат. Первый выпуск зашедулен на 26.12, делаю я в формате html, текстовая версия формируется автоматом, поэтому как она будет выглядеть - не знаю. Первый выпуск небольшой, можно сказать пробный, следующий будет скорее всего после НГ. ... |
| 24.12.2003, 16:40:04 |
Полезные ссылки
Понадоедаю вам ещё - уже готов 3 номер рассылки, так что кто ещё не влился - вливайтесь. ... |
| 13.01.2004, 10:05:53 |
Полезные ссылки
ASP.Net Erprise Manager http://www.aspenterprisemanager.com/ ASP Enterprise Manager is a web-based interface for Microsoft SQL Server and MSDE written using ASP.Net, VB.Net and C#.Net. This project was developed to allow many SQL Server and MSDE design and administration tasks to be performed from any computer with a web browser. ... |
| 14.06.2004, 10:50:45 |
Полезные ссылки
Куча ссылок на .Net компоненты - http://yanhao.vip.sina.com/ Welcome to the best .Net component source site - Winform Component, ASP.Net Component, Other .Net Component, Activex Component. ... |
| 14.06.2004, 10:52:24 |
Полезные ссылки
Есть две очень полезные штуковины: Reflector и примочка к нему . Дают позможность полностью дизассемблировать код .NET. А еще есть проэкт Mono (.NET for Linux) ... |
| 14.06.2004, 12:19:51 |
Полезные ссылки
Часто задаваемые вопросы о серверном Web-элементе управления DataGrid http://www.gotdotnet.ru/LearnDotNet/ASPNET/684.aspx Ответы на часто задаваемые вопросы об использовании серверного Web-элемента управления DataGrid. Серверный Web-элемент управления DataGrid - мощное средство отображения информации, извлекаемой из источника данных. Он прост в использовании: достаточно задать всего несколько его свойств, чтобы отобразить данные в таблице (сетке) (которая смотрится весьма профессионально); при этом показываемые данные можно изменять. В то же время DataGrid предоставляет сложную объектную модель, обеспечивающую высокую гибкость в выводе данных. В этой статье даются ответы на некоторые вопросы о настройке внешнего вида сетки, которые часто задают в телеконференциях, на Web-сайтах и в различных форумах разработчиков. Некоторые из описанных здесь приемов весьма просты, другие же довольно сложны. Однако во всех случаях ответы демонстрируют, как выйти за рамки базовой функциональности элемента управления DataGrid. ... |
| 18.02.2005, 10:08:31 |
Полезные ссылки
medigo.ru -книги по .NET ... |
| 25.02.2005, 05:51:20 |
Полезные ссылки
makar medigo.ru -книги по .NET Ни одну(!) из них скачать не смог, хоть одно время посещал этот сайт каждый день, ссылки всё время были битые :( ... |
| 28.02.2005, 14:24:54 |
Полезные ссылки
Connection Strings (Строки подсоединения) для разных источников данных с примерами. http://www.connectionstrings.com/ ... |
| 01.03.2005, 14:25:55 |
Полезные ссылки
hDrummer makar medigo.ru -книги по .NET Ни одну(!) из них скачать не смог, хоть одно время посещал этот сайт каждый день, ссылки всё время были битые :( я все скачал. слышал что там вроде можно качать только из России. Попробуй через русский прокси. ... |
| 04.03.2005, 09:13:57 |
Полезные ссылки
hDrummer makar medigo.ru -книги по .NET Ни одну(!) из них скачать не смог, хоть одно время посещал этот сайт каждый день, ссылки всё время были битые :( 100% Я все скачал что были там через русские прокси хоть и канал у меня дохлый. а вот еще вам ссылочку ... |
| 17.03.2005, 20:39:39 |
Полезные ссылки
Всё про ASP.NET и .NET Framework ASP Net Mania ... |
| 06.06.2005, 16:11:22 |
Полезные ссылки
hDrummer ASP.Net Erprise Manager http://www.aspenterprisemanager.com/ ASP Enterprise Manager is a web-based interface for Microsoft SQL Server and MSDE written using ASP.Net, VB.Net and C#.Net. This project was developed to allow many SQL Server and MSDE design and administration tasks to be performed from any computer with a web browser. SQL Server Web Data Administrator ... |
| 15.08.2005, 14:49:37 |
start [/forum/topic.php?desktop=1&fid=18&tid=1355814]: |
31ms |
64ms |
26ms |
123ms |
| others: | 321ms |
| total: | 611ms |
