2 таблицы в процеруре, а не 1 HEEEEELP
Всем привет! Пытаюсь адаптировать чужой код под себя: <%@ Import Namespace="System.Data" %> <%@ Import Namespace="System.Data.SQLClient" %> <script runat="server" language="VB"> Protected SQLStmt As String = "SELECT CompanyName, ContactName, ContactTitle, Phone, Fax FROM Customers" Sub Page_Load(Source As Object, E As EventArgs) If Not Page.IsPostBack Then SQLStatement.Text = SQLStmt BindData() End If End Sub Sub BindData() Dim myDataSet As New DataSet Dim myDataSetCommand As SQLDataAdapter Dim ConString As String ConString ="server=localhost;database=Northwind;uid=YOURUSERID;pwd=YOURPASSWORD;Trusted_Connection=yes" myDataSetCommand = New SQLDataAdapter(SQLStatement.Text, ConString) myDataSetCommand.fill(myDataSet, "Customers") myDataGrid.DataSource = myDataSet.Tables("Customers").DefaultView myDataGrid.DataBind() End Sub Sub PageIndexChanged_OnClick(Source As Object, E As DataGridPageChangedEventArgs) MyDataGrid.CurrentPageIndex = e.NewPageIndex BindData() End Sub Sub SortCommand_OnClick(Source As Object, E As DataGridSortCommandEventArgs) SQLStatement.Text = SQLStmt & " ORDER BY " & E.SortExpression BindData() End Sub </script> <style> .DataGrid {font:x-small Verdana, Arial, sans-serif} </style> <title>ASPExpress.com - Paging AND Sorting in the DataGrid</title> </head> <body> <div align="center">Paging And Sorting Together with ASP.Net </div> <form runat="server" method="post"> <asp:DataGrid runat="server" id="myDataGrid" borderwidth="5" bordercolor="black" Borderstyle="double" PagerStyle-VerticalAlign="top" Cellpadding="4" Cellspacing="0" ShowHeader="True" CssClass="DataGrid" HeaderStyle-ForeColor="Black" HeaderStyle-Font-Bold="True" AllowSorting="True" OnSortCommand="SortCommand_OnClick" AllowPaging="True" OnPageIndexChanged="PageIndexChanged_OnClick" PageSize="10" width="100%" HeaderStyle-BackColor="#aaaadd" AlternatingItemStyle-BackColor="#eeeeee" PagerStyle-Backcolor="#aaaadd" PagerStyle-Forecolor="Black" PagerStyle-HorizontalAlign="center" PagerStyle-Mode="NumericPages" PagerStyle-BorderStyle="Inset" /> </form> <asp:Label id="SQLStatement" runat="server" Visible="false" /> </body> </html> При запросе страницы данные выводятся корректно (единственное - не работает сама сортировка). У меня есть процедура, хранимая на сервере, в которой используются 3 таблицы, а не одна. myDataSetCommand.fill(myDataSet, "Customers") myDataGrid.DataSource = myDataSet.Tables("Customers").DefaultView Как мне прописать этот момент? ... |
| 31.03.2004, 11:00:53 |
>У меня есть процедура, хранимая на сервере, в которой используются 3 таблицы, а не одна. Если вы хотели сказать что хранимая процедура возвращает 3 result set, то так: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. Соответственно 3 результата находятся в коллекции Tables и представляют собой экземпляры класса DataTable. Если хотите например записи первого DataTable вывести в грид, то это можно сделать например так: Код: plaintext 1. 2. ... |
| 31.03.2004, 11:22:00 |
Если вы хотели сказать что хранимая процедура возвращает 3 result set, то так: Нет, не возвращает 3 result set! Ситуация такая: Есть процедура, которая храниться на сервере: CREATE PROCEDURE dbo.name AS SET NOCOUNT ON SELECT CompanyName, ContactName, ContactTitle, Phone, Fax FROM dbo.partners AS pa, dbo.price AS pr GO В строке Protected SQLStmt As String = "SELECT CompanyName, ContactName, ContactTitle, Phone, Fax FROM Customers" прописываю Protected SQLStmt As String = "exec dbo.name" Данные выводятся но не сортируются. Выводит такую ошибку при клике по какому-то из заголовков: Код: plaintext 1. 2. 3. 4. 5. ... |
| 31.03.2004, 11:55:30 |
start [/forum/topic.php?desktop=1&fid=17&tid=1354171]: |
46ms |
40ms |
| others: | 194ms |
| total: | 322ms |
