проблема с передачей параметров OracleClient
Вот код Dim param As New System.Data.OracleClient.OracleParameter Dim li As New listitem SelectCommand.Parameters.Clear() For Each variab As ListViewItem In lvspr.SelectedItems var.idob = CType(variab.Text(), Integer) Next oracon.ConnectionString = var.constr SelectCommand.Connection = oracon oracon.Open() SelectCommand.CommandType = CommandType.StoredProcedure param = Me.SelectCommand.Parameters.Add("numobject", System.Data.OracleClient.OracleType.Number) param.Direction = ParameterDirection.Input param.Value = var.objname param = Me.SelectCommand.Parameters.Add("idsybrnkref", System.Data.OracleClient.OracleType.Number) param.Direction = ParameterDirection.Input param.Value = var.idob param = Me.SelectCommand.Parameters.Add("nameobject", System.Data.OracleClient.OracleType.Char, var.objname.Length) param.Direction = ParameterDirection.Input param.Value = var.objname param = Me.SelectCommand.Parameters.Add("flag", System.Data.OracleClient.OracleType.Number) param.Direction = ParameterDirection.InputOutput param.Value = -1 SelectCommand.CommandText = "eac.p_object.set_object_to_tree" SelectCommand.ExecuteNonQuery() заголовок процедуры PROCEDURE set_object_to_tree ( numobject IN NUMBER, idsybrnkref IN NUMBER, nameobject IN VARCHAR2, flag IN OUT NUMBER ) В результате возвращается ошибка "Input string is not correct format" В чём проблема не пойму ... |
| 03.12.2004, 11:11:13 |
start [/forum/topic.php?desktop=1&fid=17&tid=1353927]: |
211ms |
29ms |
| others: | 236ms |
| total: | 530ms |
