Ado .net и работа с ХП
Есть такая ХП: create procedure GetMessagesCount @Count int OUTPUT, @User varchar(100)=NULL AS IF isNull(@User,'')='' select @Count=COUNT(*) from messages; ELSE select @Count=COUNT(*) from messages where UserName=@User; и есть такой код: System.Data.SqlClient.SqlConnection Connection=new SqlConnection(); Connection.ConnectionString=ConnectionString; System.Data.SqlClient.SqlCommand Command=new SqlCommand(); Command.Connection=Connection; Command.CommandType=CommandType.StoredProcedure; Command.CommandText="GetMessagesCount"; SqlParameter Param=new SqlParameter("Count",SqlDbType.Int); Param.Direction=ParameterDirection.Output; Command.Parameters.Add(Param); Connection.Open(); int Count=(int)Command.Parameters["Count"].Value; Connection.Close(); В стороке int Count=(int)Command.Parameters["Count"].Value; - ошибка(те Value==null) В чем траблы? C ув. Tors ... |
| 20.05.2005, 16:14:10 |
start [/forum/topic.php?desktop=1&fid=17&tid=1353733]: |
189ms |
35ms |
| others: | 222ms |
| total: | 491ms |
