множественный выбор в Ole
Подскажите как реализовать? выбрать через OLE в Table записи выбираемые следующим образом: "select kc,kvo,sum([sum]) as s150,0 as s259,0 as s421,0 as s422,0 as s445,0 as s448,0 as s449,0 as s453,0 as s457,0 as s465,0 as s479,0 as s480,0 as s580,0 as s581,0 as s582 from zp103 where kvo='150' group by kc,kvo"; "select kc,kvo,0 as s150,sum([sum]) as s259,0 as s421,0 as s422,0 as s445,0 as s448,0 as s449,0 as s453,0 as s457,0 as s465,0 as s479,0 as s480,0 as s580,0 as s581,0 as s582 from zp103 where kvo='259' group by kc,kvo"; "select kc,kvo,0 as s150,0 as s259,sum([sum]) as s421,0 as s422,0 as s445,0 as s448,0 as s449,0 as s453,0 as s457,0 as s465,0 as s479,0 as s480,0 as s580,0 as s581,0 as s582 from zp103 where kvo='421' group by kc,kvo"; и т.д. ... |
| 07.12.2006, 06:26 |
а далее select kc, sum(s150) as s150, sum(s259) as s259, sum(s421) as s421, sum(s422) as s422, sum(s426) as s426, sum(s427) as s427, sum(s445) as s445, sum(s448) as s448, sum(s449) as s449, sum(s453) as s453, sum(s457) as s457, sum(s465) as s465, sum(s479) as s479, sum(s480) as s480, sum(s580) as s580, sum(s581) as s581, sum(s582) as s582 from Table ... |
| 07.12.2006, 06:31 |
start [/forum/topic.php?desktop=1&fid=17&tid=1353035]: |
45ms |
25ms |
| others: | 188ms |
| total: | 293ms |
