LINQ - Join by Using Composite Keys
This example shows how to perform join operations in which you want to use more than one key to define a match. This is accomplished by using a composite key. You create a composite key as an anonymous type or named typed with the values that you want to compare. If the query variable will be passed across method boundaries, use a named type that overrides Equals and GetHashCode for the key. The names of the properties, and the order in which they occur, must be identical in each key Тем кто соединяет по двум и более полям прошу обратить на последнюю фразу! ... |
| 10.04.2008, 16:21 |
круто, не знал, но сложновато конечно... ... |
| 10.04.2008, 17:43 |
зыкруто, не знал, но сложновато конечно... А если это всё с группировкой то выглядит монстровидно! from c in RashNaklDtls group c by new { c.Partia.par_va_id, c.Partia.par_pk_id } into grp join arc in this.VariArtcs on grp.Key.par_va_id equals arc.va_id join pak in this.Packings on new { va = grp.Key.par_va_id, pk = grp.Key.par_pk_id } equals new { va = pak.pk_va_id, pk = pak.pk_id } orderby arc.va_articul, pak.pk_descr select с ... |
| 11.04.2008, 15:58 |
start [/forum/topic.php?desktop=1&fid=17&tid=1352322]: |
29ms |
| others: | 197ms |
| total: | 276ms |
