powered by simpleCommunicator - 2.0.51     © 2025 Programmizd 02
Форумы / ADO.NET, LINQ, Entity Framework, NHibernate, DAL, ORM [игнор отключен] [закрыт для гостей] / [EF] Зачем сортирует по всем полям?
3 сообщений из 3, страница 1 из 1
    #38686883
maratoss
Есть такой запрос, который генерит такой sql и у меня такой вопрос зачем делается сортировка по всем полям?:
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
var q = from item in entities.StatisticsOrderView.Where(x => x.OriginType == 6)
	join invoiceRow in entities.CustomerInvoiceRow.Where(x => x.Type == 2 && x.State == 0)
	on item.InvoiceId equals invoiceRow.InvoiceId into g
	select new StatisticsOrderDTO {
		Id = item.OriginId,
		Rows = g.Select(x => new StatisticsOrderRowDTO {
			Id = x.CustomerInvoiceRowId,
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
SELECT *
FROM   (SELECT *,
               CASE
                 WHEN ([Extent2].[CustomerInvoiceRowId] IS NULL) THEN CAST(NULL AS int)
                 ELSE 1
               END AS [C1]
        FROM   (SELECT *
                FROM   [dbo].[StatisticsOrderView] AS [StatisticsOrderView]) AS [Extent1]
               LEFT OUTER JOIN [dbo].[CustomerInvoiceRow] AS [Extent2]
                 ON (2 = [Extent2].[Type])
                    AND (0 = [Extent2].[State])
                    AND ([Extent1].[InvoiceId] = [Extent2].[InvoiceId])
        WHERE  [Extent1].[OriginType] = 6 /* @p__linq__0 */) AS [Project1]
ORDER  BY [Project1].[OwnerActorId] ASC,
          [Project1].[ActorId] ASC,
          [Project1].[ActorNr] ASC,
          [Project1].[SupplierBlockPayment] ASC,
          [Project1].[CustomerGracePeriodDays] ASC,
          [Project1].[CustomerPriceListTypeId] ASC,
          [Project1].[Status] ASC,
          [Project1].[StatusName] ASC,
          [Project1].[InvoiceType] ASC,
          [Project1].[BillingTypeId] ASC,
          [Project1].[ProjectId] ASC,
          [Project1].[BillingTypeName] ASC,
          [Project1].[RemainingAmount] ASC,
          [Project1].[RemainingAmountExVat] ASC,
          [Project1].[BlockPayment] ASC,
          [Project1].[SupplierInvoicePaymentMethodType] ASC,
          [Project1].[RegistrationType] ASC,
          [Project1].[DeliveryAddressId] ASC,
          [Project1].[BillingAddressId] ASC,
          [Project1].[BillingInvoicePrinted] ASC,
          [Project1].[HasHouseholdTaxDeduction] ASC,
          [Project1].[InsecureDebt] ASC,
          [Project1].[MultipleAssetRows] ASC,
          [Project1].[NoOfReminders] ASC,
          [Project1].[NextContractPeriodYear] ASC,
          [Project1].[NextContractPeriodValue] ASC,
          [Project1].[SysPaymentMethodId] ASC,
          [Project1].[PaymentMethodName] ASC,
          [Project1].[PaymentRowId] ASC,
          [Project1].[PaymentNr] ASC,
          [Project1].[PaymentNrString] ASC,
          [Project1].[PaymentSeqNr] ASC,
          [Project1].[PaymentAmount] ASC,
          [Project1].[PaymentAmountCurrency] ASC,
          [Project1].[PaymentAmountDiff] ASC,
          [Project1].[BankFee] ASC,
          [Project1].[SequenceNumber] ASC,
          [Project1].[SequenceNumberRecordId] ASC,
          [Project1].[PaymentIsSuggestion] ASC,
          [Project1].[CurrencyCode] ASC,
          [Project1].[CurrencyRate] ASC,
          [Project1].[AccountYearId] ASC,
          [Project1].[VoucherSeriesId] ASC,
          [Project1].[HasVoucher] ASC,
          [Project1].[InvoiceTotalAmountCurrency] ASC,
          [Project1].[VATAmount] ASC,
          [Project1].[InvoicePaidAmount] ASC,
          [Project1].[InvoicePaidAmountCurrency] ASC,
          [Project1].[InvoicePayAmount] ASC,
          [Project1].[InvoicePayAmountCurrency] ASC,
          [Project1].[FullyPayed] ASC,
          [Project1].[OrderNumbers] ASC,
          [Project1].[VATAmountCurrency] ASC,
          [Project1].[SysCurrencyId] ASC,
          [Project1].[LangId] ASC,
          [Project1].[OriginType] ASC,
          [Project1].[OriginId] ASC,
          [Project1].[InvoiceNr] ASC,
          [Project1].[ActorName] ASC,
          [Project1].[InvoiceTotalAmount] ASC,
          [Project1].[InvoiceId] ASC,
          [Project1].[C1] ASC
    #38686905
maratoss
EF 6.0.2
    #38686922
carrotik
maratoss,
...ну, ИМХО, логично - если вы не задаете свою сортировку, то возвращается полностью отсортированная коллекция, с которой проще потом работать подзапросами или поиском ...
