Помогите создать запрос
Есть запрос: /************************************************** select con.contract_headref head, con.contract_number conum, bo.bo_number bonum, bo.bo_docdate bodate, kfsr.budgetcodes_code kfsr_key, kcsr.budgetcodes_code kcsr_key, kvr.budgetcodes_code kvr_key, kesr.budgetcodes_code kesr_key, kvsr.budgetcodes_code kvsr_key, uecon.budgetcodes_code uecon_key, ufunc.budgetcodes_code ufunc_key, comp.companies_fullname compname, csQ1.contractstages_paymentsum Q1, csQ2.contractstages_paymentsum Q2, csQ3.contractstages_paymentsum Q3, csQ4.contractstages_paymentsum Q4 from contract con left join bo on (bo.bo_key = con.bo_key) left join budgetcodes kfsr on (kfsr.budgetcodes_key = con.kfsr_key) left join budgetcodes kcsr on (kcsr.budgetcodes_key = con.kcsr_key) left join budgetcodes kvr on (kvr.budgetcodes_key = con.kvr_key) left join budgetcodes kesr on (kesr.budgetcodes_key = con.kesr_key) left join budgetcodes kvsr on (kvsr.budgetcodes_key = con.kvsr_key) left join budgetcodes uecon on (uecon.budgetcodes_key = con.usereconcode_key) left join budgetcodes ufunc on (ufunc.budgetcodes_key = con.userfunccode_key) left join companies comp on (comp.companies_key = con.consumer_key) left join contractstages csQ1 on (bo.bo_key = csQ1.contract_key and csQ1.contractstages_paymentdate < "01.04.2003") left join contractstages csQ2 on (bo.bo_key = csQ2.contract_key and csQ2.contractstages_paymentdate < "01.07.2003") left join contractstages csQ3 on (bo.bo_key = csQ3.contract_key and csQ3.contractstages_paymentdate < "01.10.2003") left join contractstages csQ4 on (bo.bo_key = csQ4.contract_key and csQ4.contractstages_paymentdate >= "01.10.2003") where con.contract_iscomplex = 0 and csQ1.rpl_key < 3 and csQ2.rpl_key < 3 and csQ3.rpl_key < 3 and csQ4.rpl_key < 3 and bo.bo_number is not null group by con.contract_headref, con.contract_number, bo.bo_number, bo.bo_docdate, kfsr.budgetcodes_code, kcsr.budgetcodes_code, kvr.budgetcodes_code, kesr.budgetcodes_code, kvsr.budgetcodes_code, uecon.budgetcodes_code, ufunc.budgetcodes_code, comp.companies_fullname, csQ1.contractstages_paymentsum, csQ2.contractstages_paymentsum, csQ3.contractstages_paymentsum, csQ4.contractstages_paymentsum order by 12 /********************************************** Если в таблице нет значения Q1,Q2,Q3 или Q4, либо одного либо нескольких, то запрос выводит строку несколько раз, причём с разными значениями полей. Как сделать так, что если значения нет, то ставить 0, а если есть, то выводить это значение??? ... |
| 21.10.2003, 10:37:31 |
start [/forum/topic.php?desktop=1&fid=16&tid=1348698]: |
192ms |
32ms |
| others: | 192ms |
| total: | 455ms |
