Ошибка в проге на Clipper 5.0
Как избавиться от ошибки: Unrecoverable error 650: Processor stack fault ? Или расскажите что-нибудь об этой ошибке... Заранее спасибо! ... |
| 19.12.2003, 13:53:26 |
search.msn.com Сегодня я добрый: 5.6 What is an "Unrecoverable Error 650: Processor Stack Fault"? It's a result of infinite recursion, which occurs when a function calls itself, which calls itself, which calls itself, and so on without stopping. Most often this occurs when your error handler has an error, which triggers the error handler... ... |
| 22.12.2003, 14:59:06 |
start [/forum/topic.php?desktop=1&fid=16&tid=1348609]: |
186ms |
26ms |
| others: | 183ms |
| total: | 432ms |
