Беда с Kdevelop
Отказывается компилять проект. Запускаю automake, запускаю configure. Потом пытаюсь собрать, а он мне выбрасывает окошко с матом, что надо запустить аутомаке и конфигуре (скрин прилагается). Вывод аутомаке и конфигуре тоже. automake *cd "/home/sarin/qttest/test" && WANT_AUTOCONF_2_5="1" WANT_AUTOMAKE_1_6="1" gmake -f Makefile.cvs *This Makefile is only for the CVS repository *This will be deleted before making the distribution **** Creating acinclude.m4 **** Creating list of subdirectories **** Creating configure.in **** Creating aclocal.m4 */usr/share/aclocal/shtool.m4:25: warning: underquoted definition of AC_PROG_SHTOOL *run info '(automake)Extending aclocal' *or see http://sources.redhat.com/automake/automake.html#Extending%20aclocal **** Creating configure **** Creating config.h template **** Creating Makefile templates **** Postprocessing Makefile templates **** Creating date/time stamp **** Finished *Don't forget to run ./configure *If you haven't done so in a while, run ./configure --help configure *cd "/home/sarin/qttest/test/debug" && CXXFLAGS="-O0 -g3" "/home/sarin/qttest/test/configure" --enable-debug=full *checking build system type... i686-pc-linux-gnu *checking host system type... i686-pc-linux-gnu *checking target system type... i686-pc-linux-gnu *checking for a BSD-compatible install... /usr/bin/ginstall -c *checking for -p flag to install... yes *checking whether build environment is sane... yes *checking for gawk... gawk *checking whether make sets $(MAKE)... yes *checking for style of include used by make... GNU *checking for gcc... gcc *checking for C compiler default output file name... a.out *checking whether the C compiler works... yes *checking whether we are cross compiling... no *checking for suffix of executables... *checking for suffix of object files... o *checking whether we are using the GNU C compiler... yes *checking whether gcc accepts -g... yes *checking for gcc option to accept ANSI C... none needed *checking dependency style of gcc... gcc3 *checking how to run the C preprocessor... gcc -E *checking for g++... g++ *checking whether we are using the GNU C++ compiler... yes *checking whether g++ accepts -g... yes *checking dependency style of g++... gcc3 *checking whether g++ supports -fno-builtin... no *checking whether g++ supports -Woverloaded-virtual... yes *checking whether g++ supports -Wmissing-format-attribute... yes *checking whether g++ supports -Wundef... yes *checking whether g++ supports -Wno-long-long... yes *checking whether g++ supports -Wnon-virtual-dtor... yes *checking whether g++ supports -fno-exceptions... yes *checking whether g++ supports -fno-check-new... yes *checking whether g++ supports -fno-common... yes *checking whether g++ supports -fexceptions... yes *checking how to run the C++ preprocessor... g++ -E *checking whether g++ supports -O0... yes *checking whether g++ supports -Wl,--no-undefined... yes *checking whether g++ supports -Wl,--allow-shlib-undefined... yes *not using lib directory suffix *checking for a sed that does not truncate output... /bin/sed *checking for egrep... grep -E *checking for ld used by gcc... /usr/bin/ld *checking if the linker (/usr/bin/ld) is GNU ld... yes *checking for /usr/bin/ld option to reload object files... -r *checking for BSD-compatible nm... /usr/bin/nm -B *checking whether ln -s works... yes *checking how to recognise dependent libraries... pass_all *checking for ANSI C header files... yes *checking for sys/types.h... yes *checking for sys/stat.h... yes *checking for stdlib.h... yes *checking for string.h... yes *checking for memory.h... yes *checking for strings.h... yes *checking for inttypes.h... yes *checking for stdint.h... yes *checking for unistd.h... yes *checking dlfcn.h usability... yes *checking dlfcn.h presence... yes *checking for dlfcn.h... yes *checking for g77... no *checking for f77... no *checking for xlf... no *checking for frt... no *checking for pgf77... no *checking for fort77... no *checking for fl32... no *checking for af77... no *checking for f90... no *checking for xlf90... no *checking for pgf90... no *checking for epcf90... no *checking for f95... no *checking for fort... no *checking for xlf95... no *checking for ifc... no *checking for efc... no *checking for pgf95... no *checking for lf95... no *checking for gfortran... no *checking whether we are using the GNU Fortran 77 compiler... no *checking whether accepts -g... no *checking the maximum length of command line arguments... 32768 *checking command to parse /usr/bin/nm -B output from gcc object... ok *checking for objdir... .libs *checking for ar... ar *checking for ranlib... ranlib *checking for strip... strip *checking if gcc static flag works... yes *checking if gcc supports -fno-rtti -fno-exceptions... no *checking for gcc option to produce PIC... -fPIC *checking if gcc PIC flag -fPIC works... yes *компиляция yes (gcc) *checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes *checking whether -lc should be explicitly linked in... no *checking dynamic linker characteristics... GNU/Linux ld.so *checking how to hardcode library paths into programs... immediate *checking whether stripping libraries is possible... yes *checking for shl_load... no *checking for shl_load in -ldld... no *checking for dlopen... no *checking for dlopen in -ldl... yes *checking whether a program can dlopen itself... yes *checking whether a statically linked program can dlopen itself... yes *checking if libtool supports shared libraries... yes *checking whether to build shared libraries... yes *checking whether to build static libraries... no *configure: creating libtool *appending configuration tag "CXX" to libtool *checking for ld used by g++... /usr/bin/ld *checking if the linker (/usr/bin/ld) is GNU ld... yes *checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes *checking for g++ option to produce PIC... -fPIC *checking if g++ PIC flag -fPIC works... yes *компиляция yes (g++) *checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes *checking dynamic linker characteristics... GNU/Linux ld.so *checking how to hardcode library paths into programs... immediate *checking whether stripping libraries is possible... yes *checking for shl_load... (cached) no *checking for shl_load in -ldld... (cached) no *checking for dlopen... (cached) no *checking for dlopen in -ldl... (cached) yes *checking whether a program can dlopen itself... (cached) yes *checking whether a statically linked program can dlopen itself... (cached) yes *appending configuration tag "F77" to libtool *checking for msgfmt... /usr/bin/msgfmt *checking for gmsgfmt... /usr/bin/msgfmt *checking for xgettext... /usr/bin/xgettext *checking if C++ programs can be compiled... yes *checking for strlcat... yes *checking if strlcat needs custom prototype... no *checking for strlcpy... yes *checking if strlcpy needs custom prototype... no *checking for main in -lutil... yes *checking for main in -lcompat... no *checking for crypt in -lcrypt... yes *checking for socklen_t... socklen_t *checking for dnet_ntoa in -ldnet... no *checking for dnet_ntoa in -ldnet_stub... no *checking for inet_ntoa... yes *checking for connect... yes *checking for remove... yes *checking for shmat... yes *checking for sys/types.h... (cached) yes *checking for stdint.h... (cached) yes *checking for poll in -lpoll... no *checking CoreAudio/CoreAudio.h usability... no *checking CoreAudio/CoreAudio.h presence... no *checking for CoreAudio/CoreAudio.h... no *checking if res_init needs -lresolv... yes *checking if res_init is available... yes *checking for killpg in -lucb... no *checking for int... yes *checking size of int... 4 *checking for short... yes *checking size of short... 2 *checking for long... yes *checking size of long... 4 *checking for char *... yes *checking size of char *... 4 *checking for dlopen in -ldl... (cached) yes *checking for shl_unload in -ldld... no *checking for size_t... yes *checking size of size_t... 4 *checking for unsigned long... yes *checking size of unsigned long... 4 *checking sizeof size_t == sizeof unsigned long... yes *checking crt_externs.h usability... no *checking crt_externs.h presence... no *checking for crt_externs.h... no *checking for _NSGetEnviron... no *checking for vsnprintf... yes *checking for snprintf... yes *checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include *checking for IceConnectionNumber in -lICE... yes *checking for libXext... yes *checking for pthread_create in -lpthread... yes *checking for extra includes... no *checking for extra libs... no *checking for libz... -lz *checking for libpng... -lpng -lz -lm *checking for libjpeg6b... no *checking for libjpeg... -ljpeg *checking for perl... /usr/bin/perl *checking for Qt... libraries /usr/lib/qt3//lib, headers /usr/lib/qt3//include using -mt *checking for moc... /usr/lib/qt3//bin/moc *checking for uic... /usr/lib/qt3//bin/uic *checking whether uic supports -L ... yes *checking whether uic supports -nounload ... yes *checking if Qt needs -ljpeg... no *checking for rpath... yes *checking for KDE... *configure: error: *in the prefix, you've chosen, are no KDE headers installed. This will fail. *So, check this please and use another prefix! ... |
| 01.05.2005, 21:37 |
Беда с Kdevelop
Вы создайте линуксовый топик, так быстрее будет. ... |
| 02.05.2005, 09:58 |
Беда с Kdevelop
За совет спасибо. Но здесь линуксоидов много тусуется. У них в выходные затишье просто. Форум Линух может за выходные ни разу не обновится. ... |
| 02.05.2005, 12:50 |
Беда с Kdevelop
Привет Сарин, Ты прав! Тусуемси тоже. Хотя, к линуху больще имеет отношение. Так вот, можно отрыть твое ./configure и найти в нем "checking for KDE..."? Ну и с десяток, другой строк, че она там проверяеть? Тады точную диагностику дам. А щас тольки могу стказать что у тя что-то типа kde*-devel-* не стоит. Вобщем техника така 1) находишь имя файла, которого нема (судя по всему какой-нить kde*.h) 2) идешь на rpm.pbone.net и ищешь в каком rpm сякой kde*.h есть. 3) ищешь сей rpm (или близкий) у себя в дистре. 4) ставишь его и повторящь сборку ... и так 12 раз (глупий грузинский анекдот (с)) ... |
| 04.05.2005, 20:09 |
Беда с Kdevelop
Да я уже воткнул Kdevelop-for-KDE. Всё заработало. Только вопросов ещё больше стало Как, например, приживить форму созданную в Qt Designer к проекту в девелоперу? ... |
| 04.05.2005, 21:37 |
start [/forum/topic.php?desktop=1&fid=16&tid=1347712]: |
31ms |
35ms |
| others: | 218ms |
| total: | 322ms |
