программирование на Java, Oracle
Hello ! I have some problem. I am working with JBoss4 , Oracle10g , java. I need to create XADataSource in JBoss, so that my transaction able to support 2 phases submission. Below is my code in oracle-ds.xml <datasources> <xa-datasource> <jndi-name>XAOracleDS</jndi-name> <track-connection-by-tx>true</track-connection-by-tx> <isSameRM-override-value>false</isSameRM-override-value> <xa-datasource-class>oracle.jdbc.xa.client.OracleXADataSource</xa-datasource-class> <xa-datasource-property name="URL">jdbc:oracle:thin:@192.9.200.177:1521:devnbtwo</xa-datasource-property> <xa-datasource-property name="User">b1</xa-datasource-property> <xa-datasource-property name="Password">b2</xa-datasource-property> <exception-sorter-class-name>org.jboss.resource.adapter.jdbc.vendor.OracleExceptionSorter </exception-sorter-class-name> <no-tx-separate-pools/> </xa-datasource> <type-mapping>Oracle10g</type-mapping> <!--<mbean code="org.jboss.resource.adapter.jdbc.xa.oracle.OracleXAExceptionFormatter" name="jboss.jca:service=OracleXAExceptionFormatter"> --> <depends optional-attribute-name="TransactionManagerService">jboss:service=TransactionManager </depends> <!--</mbean>--> </datasources> and there is java Code : XADataSource dataSource = (XADataSource)context.lookup("java:/XAOracleDS"); but this dosn't work, throws EJBException: Error initializing context:javax.ejb.EJBException: java.lang.ClassCastException: org.jboss.resource.adapter.jdbc.WrapperDataSource May I know anybody can give me some suggestion of this code? May I know anything else should I do in my java code? Thank you. ... |
| 01.06.2006, 17:55 |
start [/forum/topic.php?desktop=1&fid=16&tid=1346807]: |
53ms |
| others: | 205ms |
| total: | 310ms |
