assembler kod
kto mojet pomogite. vot takoy kod est ego nado napisat na delphi unit UnitMain; interface uses Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs, StdCtrls type TfrmKey=class(TForm) Edit1: TEdit; Edit2: TEdit; GroupBox1: TGroupBox; Button1: TButton; Label1: TLabel; Label2: TLabel; procedure FormCreate(Sender : TObject); procedure Button1Click(Sender : TObject); private { Private declarations } public { Public declarations } end ; var frmKey: TfrmKey; {This file is generated by DeDe Ver 3.50.02 Copyright (c) 1999-2002 DaFixer} implementation {$R *.DFM} procedure TfrmKey.FormCreate(Sender : TObject); begin (* 00457410 55 push ebp 00457411 8BEC mov ebp, esp 00457413 6A00 push $00 00457415 53 push ebx 00457416 8BD8 mov ebx, eax 00457418 33C0 xor eax, eax 0045741A 55 push ebp * Possible String Reference to: 'йPЗъялр[Y]Г‹АU‹мj' | 0045741B 685F744500 push $0045745F ***** TRY | 00457420 64FF30 push dword ptr fs:[eax] 00457423 648920 mov fs:[eax], esp 00457426 8D45FC lea eax, [ebp-$04] | 00457429 E872FAFFFF call 00456EA0 0045742E 8B55FC mov edx, [ebp-$04] * Reference to control TfrmKey.Edit1 : TEdit | 00457431 8B83F8020000 mov eax, [ebx+$02F8] * Reference to: Controls.TControl.SetText(TControl;TCaption); | 00457437 E820DBFDFF call 00434F5C 0045743C 33D2 xor edx, edx * Reference to control TfrmKey.Edit2 : TEdit | 0045743E 8B83FC020000 mov eax, [ebx+$02FC] * Reference to: Controls.TControl.SetText(TControl;TCaption); | 00457444 E813DBFDFF call 00434F5C 00457449 33C0 xor eax, eax 0045744B 5A pop edx 0045744C 59 pop ecx 0045744D 59 pop ecx 0045744E 648910 mov fs:[eax], edx ****** FINALLY | * Possible String Reference to: '[Y]Г‹АU‹мj' | 00457451 6866744500 push $00457466 00457456 8D45FC lea eax, [ebp-$04] * Reference to: System.@LStrClr(void;void); | 00457459 E852CDFAFF call 004041B0 0045745E C3 ret * Reference to: System.@HandleFinally; | 0045745F E950C7FAFF jmp 00403BB4 00457464 EBF0 jmp 00457456 ****** END | 00457466 5B pop ebx 00457467 59 pop ecx 00457468 5D pop ebp 00457469 C3 ret *) end; procedure TfrmKey.Button1Click(Sender : TObject); begin (* 0045746C 55 push ebp 0045746D 8BEC mov ebp, esp 0045746F 6A00 push $00 00457471 53 push ebx 00457472 8BD8 mov ebx, eax 00457474 33C0 xor eax, eax 00457476 55 push ebp * Possible String Reference to: 'йзЖъялр[Y]Г' | 00457477 68C8744500 push $004574C8 ***** TRY | 0045747C 64FF30 push dword ptr fs:[eax] 0045747F 648920 mov fs:[eax], esp 00457482 8D55FC lea edx, [ebp-$04] * Reference to control TfrmKey.Edit2 : TEdit | 00457485 8B83FC020000 mov eax, [ebx+$02FC] * Reference to: Controls.TControl.GetText(TControl):TCaption; | 0045748B E89CDAFDFF call 00434F2C 00457490 8B45FC mov eax, [ebp-$04] * Reference to : TSetup._PROC_00456F14() | 00457493 E87CFAFFFF call 00456F14 00457498 84C0 test al, al 0045749A 740C jz 004574A8 * Possible String Reference to: 'Ok' | 0045749C B8DC744500 mov eax, $004574DC * Reference to: Dialogs.ShowMessage(AnsiString); | 004574A1 E8B204FDFF call 00427958 004574A6 EB0A jmp 004574B2 004574A8 B8E8744500 mov eax, $004574E8 * Reference to: Dialogs.ShowMessage(AnsiString); | 004574AD E8A604FDFF call 00427958 004574B2 33C0 xor eax, eax 004574B4 5A pop edx 004574B5 59 pop ecx 004574B6 59 pop ecx 004574B7 648910 mov fs:[eax], edx ****** FINALLY | * Possible String Reference to: '[Y]Г' | 004574BA 68CF744500 push $004574CF 004574BF 8D45FC lea eax, [ebp-$04] * Reference to: System.@LStrClr(void;void); | 004574C2 E8E9CCFAFF call 004041B0 004574C7 C3 ret * Reference to: System.@HandleFinally; | 004574C8 E9E7C6FAFF jmp 00403BB4 004574CD EBF0 jmp 004574BF ****** END | 004574CF 5B pop ebx 004574D0 59 pop ecx 004574D1 5D pop ebp 004574D2 C3 ret *) end; end. ... |
| 19.12.2009, 12:43:18 |
start [/forum/topic.php?desktop=1&fid=16&tid=1344023]: |
194ms |
| others: | 193ms |
| total: | 431ms |
