Lisp
Помогите найти ошибку. Программа выгружает данные из AutoCad в Excel/ ((defun writeex10_com (shname1 shname2 bname /) (vl-load-com) (setq g_oex (vlax-get-or-create-object "Excel.Application.10")) (vlax-put-property g_oex 'SheetsInNewWorkbook 2) (vlax-put-property g_oex 'Visible :vlax-true) (setq q_wbs (vlax-put-property g_oex 'Workbooks)) (setq g_cb (vlax-invoke-method g_wbs 'add)) (setq g_shs (vlax-get-property g_cb 'sheets)) (setq g_csh (vlax-get-property g_shs 'Item 1)) (vlax-put-property g_csh 'Name shname1) (setq g_sh2 (vlax-get-property g_shs 'Item 2)) (vlax-put-property g_sh2 'Name shname2) (setq g_r1 (vlax-get-property g_oex "Range" "B3:B3")) (vlax-invoke-method g_sh2 'Activate) (setq g_r2 (vlax-get-property g_oex "Range" "A2:C4")) (vlax-invoke-method g_sh 'Activate) (vlax-put-property g_r1 "Value2" 1234) (vlax-put-property g_r2 "Value2" "Пишу в тишине") (setq g_cr (vlax-get-property g_csh 'Range "E7")) (vlax-put-property g_cr "Value2" -17.873) (vlax-invoke-method g_cb 'SaveAs bname -4143 "" "" :vlax-false :vlax-false nil) (vlax-invoke-method g_oex "Quit") (if (and g_cr (not (vlax-object-released-p g_cr))) (vlax-release-object g_cr)) (if (and g_r2 (not (vlax-object-released-p g_r2))) (vlax-release-object g_r2)) (if (and g_r1 (not (vlax-object-released-p g_r1))) (vlax-release-object g_r1)) (if (and g_csh (not (vlax-object-released-p g_csh))) (vlax-release-object g_csh)) (if (and g_sh2 (not (vlax-object-released-p g_sh2))) (vlax-release-object g_sh2)) (if (and g_shs (not (vlax-object-released-p g_shs))) (vlax-release-object g_shs)) (if (and g_cb (not (vlax-object-released-p g_cb))) (vlax-release-object g_cb)) (if (and g_wbs (not (vlax-object-released-p g_wbs))) (vlax-release-object g_wbs)) (if (and g_oex (not (vlax-object-released-p g_oex))) (vlax-release-object g_oex)) (setq g_cr nil g_r2 nil g_r1 nil g_csh nil g_sh2 nil g_shs nil g_cb nil g_wbs nil g_oex nil) (gc) ) ... |
| 13.05.2010, 16:32:37 |
start [/forum/topic.php?desktop=1&fid=16&tid=1343688]: |
173ms |
36ms |
| others: | 209ms |
| total: | 453ms |
