Симуляция в AutoIt 3
Как симулировать нажатие левой кнопки мыши на указанных координатах в автоите? ... |
| 30.11.2010, 21:43:19 |
Код: plaintext MouseClick Perform a mouse click operation. MouseClick ( "button" [, x, y [, clicks [, speed ]]] ) Parameters button The button to click: "left", "right", "middle", "main", "menu", "primary", "secondary". x, y [optional] The x/y coordinates to move the mouse to. If no x and y coords are given, the current position is used (default). clicks [optional] The number of times to click the mouse. Default is 1. speed [optional] the speed to move the mouse in the range 1 (fastest) to 100 (slowest). A speed of 0 will move the mouse instantly. Default speed is 10. Return Value Success: Returns 1. Failure: Returns 0, the button is not in the list or invalid parameter as x without y. Remarks If the button is an empty string, the left button will be clicked. If x or y equal to the Default keyword no move occurs in the corresponding coordinate. If the user has swapped the left and right mouse buttons in the control panel, then the behaviour of the buttons is different. "Left" and "right" always click those buttons, whether the buttons are swapped or not. The "primary" or "main" button will be the main click, whether or not the buttons are swapped. The "secondary" or "menu" buttons will usually bring up the context menu, whether the buttons are swapped or not. Button Normal Swapped "" Left Left "left" Left Left "middle" Middle Middle "right" Right Right "primary" Left Right "main" Left Right "secondary" Right Left "menu" Right Left Related MouseClickDrag, MouseGetPos, MouseMove, MouseCoordMode (Option), MouseClickDelay (Option), ControlClick, MouseDown, MouseUp, MouseWheel Example ; Double click at the current mouse pos MouseClick("left") MouseClick("left") ; Double click at 0,500 MouseClick("left", 0, 500, 2) ; SAFER VERSION of Double click at 0,500 - takes into account user's control panel settings MouseClick("primary", 0, 500, 2) ... |
| 01.12.2010, 05:52:50 |
Именно симулировать, чтобы мышка не передвигалась ... |
| 01.12.2010, 12:33:57 |
Хелп читать некогда? Код: plaintext 1. 2. Если известен контрол, который нужно кликнуть - так и используйте ControlClick() ... |
| 01.12.2010, 19:37:38 |
AndreTMХелп читать некогда? Код: plaintext 1. 2. Если известен контрол, который нужно кликнуть - так и используйте ControlClick() В том то и дело, что не известен ... |
| 01.12.2010, 22:05:42 |
start [/forum/topic.php?desktop=1&fid=16&tid=1343289]: |
206ms |
45ms |
| others: | 201ms |
| total: | 487ms |
