Change the elements of massive
Zdravstvuyte! Pomogite pojaluista. Est dataset sostoyashiy iz nabora liniy zapolnennih bukvami. p,x,s,n,t,p,f,c,n,k,e,e,s,s,w,w,p,w,o,p,k,s,u Neobhodimo zamenit kajduyu bukvu na opredelennoe znachenie (sostoyashee iz 0 i 1) v zavisimosti ot pozicii. I tak proytis po vsem liniyam. kolichestvo simvolov v kajdoy stroke odinakovoye. Pitalas razbit dataset na linii pro pomoshi ReadLine(). Ne poymu kak obratitsia k opredelennomu simvolu v stroke. static public void ReplaceInFile(string filePath, string searchText, string replaceText) { //StreamReader reader = new StreamReader(filePath); //string content = reader.ReadToEnd(); //reader.Close(); using (StreamReader reader = File.OpenText(fileName)) { while (!reader.EndOfStream) { string line = reader.ReadLine(); int max = line.Length; int i = 0; for (i = 0; i <= max; i++) { // vot zdes ??????? } // do something with the line } } Zaranee blagodarna! ... |
| 23.03.2011, 19:39 |
start [/forum/topic.php?desktop=1&fid=16&tid=1343048]: |
23ms |
190ms |
33ms |
| others: | 271ms |
| total: | 550ms |
