Размер dw/ds в памяти/на диске.
Какими средствами можно воспользоваться для определения Subj в PB8.0 ... |
| 16.02.2004, 16:08 |
From Help: Storage DataWindow object property Description The amount of virtual storage in bytes that has been allocated for the DataWindow object. Controls DataWindows Syntax PowerBuilder dot notation: dw_control.Object.DataWindow.Storage Describe argument: "DataWindow.Storage" Usage Canceling a query that uses too much storage You can check this property in the script for the RetrieveRow event in the DataWindow control and cancel a query if it is consuming too much storage. ... |
| 16.02.2004, 20:57 |
start [/forum/topic.php?desktop=1&fid=15&tid=1339295]: |
75ms |
27ms |
| others: | 241ms |
| total: | 382ms |
