объект gnv_app
zdrasti. mozet kto dast ssilochku gde pochitat pro "объект gnv_app"? ili v dvux slovax raskazet chto eto takoe :) spasibo. ... |
| 05.10.2004, 12:36:27 |
объект gnv_app
RTFM PowerBuilder Foundation Class Library (PFC)Description N_cst_appmanager is the application manager and functions as a substitute for the Application object. It contains many useful functions as well as reference variables for application services. PowerBuilder Foundation Class Library (PFC)Usage To use n_cst_appmanager: 1 (Optional) Access the extension-level n_cst_appmanager user object and create a descendant application manager. 2 Define a global variable, gnv_app, of type n_cst_appmanager (or your customized descendant). n_cst_appmanager gnv_app 3 Add PowerScript code to your application's Open event to create an instance of n_cst_appmanager and call the pfc_Open event, passing the commandline argument: gnv_app = CREATE n_cst_appmanager gnv_app.Event pfc_Open(commandline) 4 Add PowerScript code to the Constructor event to selectively enable application services: Preference service—of_SetAppPreference Debug service—of_SetDebug DataWindow caching service—of_SetDwCache Most recently used object service—of_SetMRU Error handling service—of_SetError Transaction registration service—of_SetTrRegistration Security service—of_SetSecurity 5 Add PowerScript code to the pfc_Open event to open the initial window. 6 Add code to the Constructor event in n_cst_appmanager (or your customized descendant) to initialize instance variables for version, company, and INI file. ... |
| 05.10.2004, 13:27:20 |
start [/forum/topic.php?desktop=1&fid=15&tid=1338830]: |
40ms |
26ms |
| others: | 195ms |
| total: | 293ms |
