DW ControlMenu Events
Какие events вызываются при нажатии на кнопки DW ControlMenu, например [х]? ... |
| 06.02.2006, 11:13:24 |
Action with Max/Min/Close Buttons on a Sheet/DW Map this to the userevent: PBM_SYSCOMMAND IF commandtype = 61488 THEN // Maximize Button ..... END IF IF commandtype = 61472 THEN // Minimize button .... END IF IF commandtype = 61536 THEN // Close the Window .... END IF Пример: // Disable Max/Min/Close Buttons IF message.wordparm = 61488 THEN // Maximize Button message.processed = TRUE message.returnvalue = 1 END IF IF message.wordparm = 61472 THEN // Minimize button message.processed = TRUE message.returnvalue = 1 END IF IF message.wordparm = 61536 THEN // Close the Window message.processed = TRUE message.returnvalue = 1 END IF ... |
| 06.02.2006, 14:13:00 |
start [/forum/topic.php?desktop=1&fid=15&tid=1337918]: |
50ms |
27ms |
| others: | 240ms |
| total: | 350ms |
