Почему не работает em_1.mask='####-##-##'
В helpe написано in script, туда и ставлю ... |
| 09.08.2006, 14:14:11 |
In scripts The Mask property takes a string value and can be used to obtain the value of a mask. It cannot be used to set the value. The following example uses the SetMask function to set the datatype and string format for a mask, and then uses the Mask property to obtain the value of the string format: string ls_mask em_1.SetMask(StringMask!, '@@@,@@') ls_mask = em_1.Mask ... |
| 09.08.2006, 14:18:04 |
start [/forum/topic.php?desktop=1&fid=15&tid=1337651]: |
25ms |
37ms |
| others: | 206ms |
| total: | 297ms |
