Doubleclick and Dragdrop events
Kogda ia ispolisuiu Dragdrop event a posle nego doubleclick, srabativaet v oboih sluchaiah dragdrop. Mojet ia chto-to propuskau, spasibo bol'shoe za pomosch. Vot code for dragdrop.... long ll_sql_code string ls_sql_err1,ls_sql_err2 if g_upd_privilege = 'update' then this.setrow(row) dragobject ldo_dragged_control ldo_dragged_control = draggedobject() ids_flight_data[ii_tick].setitem(ids_flight_data[ii_tick].find("oid = "+ldo_dragged_control.tag,1,ids_flight_data[ii_tick].rowcount()),"aircraft_oid",this.getitemnumber(getrow(),"oid")) // ids_flight_data[ii_tick].setitem(ids_flight_data[ii_tick].find("oid = "+ldo_dragged_control.tag,1,ids_flight_data[ii_tick].rowcount()),"upd_timestamp",w_flight_board_main.wf_get_server_datetime()) if ids_flight_data[ii_tick].update() = 1 then commit; this.modify(& 'sched_flight_oid_'+ldo_dragged_control.tag+'.visible ="0~tlong(mid(flight_bar_vis,'+string(getrow())+',1))" '+& 'origination_'+ldo_dragged_control.tag+'.visible ="0~tlong(mid(flight_bar_vis,'+string(getrow())+',1))" '+& 'departuretime_'+ldo_dragged_control.tag+'.visible ="0~tlong(mid(flight_bar_vis,'+string(getrow())+',1))" '+& 'destination_'+ldo_dragged_control.tag+'.visible ="0~tlong(mid(flight_bar_vis,'+string(getrow())+',1))" '+& 'arrivaltime_'+ldo_dragged_control.tag+'.visible ="0~tlong(mid(flight_bar_vis,'+string(getrow())+',1))" '+& 'flight_oid_'+ldo_dragged_control.tag+'.visible ="0~tlong(mid(flight_bar_vis,'+string(getrow())+',1))" '+& 'ca_oid_'+ldo_dragged_control.tag+'.visible ="0~tif(describe(~'ca_oid_'+ldo_dragged_control.tag+'.text~')=~', ~',0,long(mid(flight_bar_vis,'+string(getrow())+',1)))" '+& 'fo_oid_'+ldo_dragged_control.tag+'.visible ="0~tif(describe(~'fo_oid_'+ldo_dragged_control.tag+'.text~')=~', ~',0,long(mid(flight_bar_vis,'+string(getrow())+',1)))" '+& 'fe_oid_'+ldo_dragged_control.tag+'.visible ="0~tif(describe(~'fe_oid_'+ldo_dragged_control.tag+'.text~')=~', ~',0,long(mid(flight_bar_vis,'+string(getrow())+',1)))"'& ) trigger event timer() else ll_sql_code = sqlca.sqlcode ls_sql_err1 = string(sqlca.sqldbcode) ls_sql_err2 = sqlca.sqlerrtext rollback; if ll_sql_code <> 0 then messagebox("Error Updating Database! "+ls_sql_err1,ls_sql_err2) end if end if end if ... |
| 28.02.2007, 22:10:10 |
| 06.03.2007, 18:17:50 |
Ну и на кой нам " code for dragdrop.... " нужен? Ты бы еще весь проект прислала. Шо не работает-то? Когда происходит doubleclick? ... |
| 07.03.2007, 14:06:20 |
Kogda proishodit doubleclick srabativaet dragdrop event. ... |
| 07.03.2007, 17:28:33 |
Хочеш совет? Не совсем тот что ты ожидаеш, но ... напиши другое окно, и избався от всех етих draganddrop. Используй master и detail approach и усё будет Ок, честно. Скинь пару скриншатов, что ты там твориш и что должно быть, тока не cutandpaste код, от него тока голова кругом идёт. ... |
| 07.03.2007, 21:29:41 |
start [/forum/topic.php?desktop=1&fid=15&tid=1337306]: |
39ms |
40ms |
| others: | 198ms |
| total: | 316ms |
