Pixel
Код: plaintext 1. 2. 3. СПАСИБО ... |
| 19.06.2007, 11:09:02 |
Pixel
Милиметры перевести в пиксели, а пиксели в юниты (PBU). ... |
| 19.06.2007, 11:36:11 |
Pixel
авторМилиметры перевести в пиксели, а пиксели в юниты (PBU). Искал в help F1 Pixel и ничего не нашёл ... |
| 19.06.2007, 11:53:42 |
Pixel
Description Converts pixels to PowerBuilder units. Because pixels are not usually square, you also specify whether you are converting the pixels' horizontal or vertical measurement. Syntax PixelsToUnits ( pixels, type ) Argument Description pixels An integer whose value is the number of pixels you want to convert to PowerBuilder units. type A value of the ConvertType enumerated datatype value indicating how to convert the value:· XPixelsToUnits! — Convert the pixels in the horizontal direction.· YPixelsToUnits! — Convert the pixels in the vertical direction. Return value Integer. Returns the converted value if it succeeds and -1 if an error occurs. If any argument's value is NULL, PixelsToUnits returns NULL. Description Converts PowerBuilder units to pixels and reports the measurement. Because pixels are not usually square, you also specify whether to convert in the horizontal or vertical direction. Syntax UnitsToPixels ( units, type ) Argument Description units An integer whose value is the number of PowerBuilder units you want to convert to pixels type A value of the ConvertType enumerated datatype indicating how to convert the value:· XUnitsToPixels! — Convert the units in the horizontal direction· YUnitsToPixels! — Convert the units in the vertical direction Return value Integer. Returns the converted value if it succeeds and -1 if an error occurs. If any argument's value is NULL, UnitsToPixels returns NULL. ... |
| 19.06.2007, 12:13:02 |
start [/forum/topic.php?desktop=1&fid=15&tid=1337119]: |
44ms |
| others: | 203ms |
| total: | 302ms |
