data window, property ‘Display’
data window, property ‘Display’ в свойствах object DataWindow имеется, перепробовал все значения, всё одинаково , что с ними, что и без них ... |
| 10.07.2007, 11:25:11 |
Description The way the OLE Object control displays the OLE object it contains. It can display an icon or an image of the object's contents. The image is reduced to fit inside the OLE container. Both the icon and the image are provided by the OLE server. If the OLE server does not support a contents view, PowerBuilder displays an icon even if DisplayType is set to contents. Controls OLE Object controls Syntax PowerBuilder dot notation: dw_control.Object.olecontrolname.DisplayType Describe and Modify argument: "olecontrolname.DisplayType { = ' type ' }" Parameter Description olecontrolname The name of the OLE Object control for which you want to get or set the type of display. type A number specifying whether the user will see an icon or an image of the OLE object's contents. Type can be a quoted DataWindow expression. Values are:0 - Icon1 - Content Usage In the painter Select the control and set the value in the Properties view, Options tab. ... |
| 10.07.2007, 13:04:58 |
start [/forum/topic.php?desktop=1&fid=15&tid=1337085]: |
32ms |
| others: | 193ms |
| total: | 279ms |
