link to internet adress in mailsession
как можно добавить ссылку в notetext на интерет адресс в mailsession ? string ls_pdf_path string ls_pdf_filename mailSession mSes mailReturnCode mRet mailMessage mMsg mailFileDescription mAttch ls_pdf_path = f_get_general_parameter("pdf_path") ls_pdf_filename = f_get_general_parameter("pdf_filename") mSes = create mailSession mRet = mSes.mailLogon(mailNewSession!) IF mRet <> mailReturnSuccess! THEN MessageBox("Mail", 'Logon failed.') RETURN END IF // Populate the mailMessage structure mMsg.Subject = 'invoice' mMsg.NoteText = '2 invoices was created . link to ... ' mMsg.Recipient[1].name = sle_email.Text mAttch.Pathname = ls_pdf_path + ls_pdf_filename mAttch.Filename = ls_pdf_filename mMsg.AttachmentFile[1] = mAttch mRet = mSes.mailSend(mMsg) IF mRet <> mailReturnSuccess! THEN MessageBox("Invoice Mail", 'Mail not sent.') else MessageBox("Invoice Mail", 'Mail sent successfully.') End if mSes.mailLogoff() DESTROY mSes ... |
| 19.09.2007, 16:05:18 |
start [/forum/topic.php?desktop=1&fid=15&tid=1336986]: |
35ms |
| others: | 217ms |
| total: | 294ms |
