VScrollbar in the computed field, PB9
Hi Guys, Have you ever bumped with the problem of big-size computed fields in DataWindow PB9? I've got a global PB function returns a formatted string and used as an expression in the computed field. So far so good, it works properly and shows exactly what I want, BUT... The size of returning string is a way bigger then the visible portion of DW field. Generally, where are 2 approaches: 1) make my the field "AutoSize Height" - it works, unfortunately not acceptable in my particular situation; 2) add "Vert scroll bar" - this is exactly what I need. The problem is that I cannot find such property in computed field!!! Any suggestion, any idea about how to scroll long text in the computed field would be highly appreciated. Thanks in advance. ... |
| 28.04.2008, 19:03 |
Polar Cat2) add "Vert scroll bar" - this is exactly what I need. The problem is that I cannot find such property in computed field!!!Скроллирование допускается только для полей, включенных в исходный SQL запрос. Добавьте поле типа varchar2 (или как оно у вас называется), установите свойства Display Only и Vert Scroll Bar. В клиентском коде (например в событии retrieveend) устанавливайте значение поля равным результату Вашей функции примерно так: Код: plaintext ... |
| 28.04.2008, 20:57 |
PL99 - Thanks a lot for a prompt answer. I'm hog-tied with prohibition to make any changes to existing PB script. The only way I allowed to resolve an issue is to change somehow the DW syntax. Otherwise we would have to re-deploy application completely which is unacceptable. So it looks like mission impossible just because of system architect's short-sightedness and PB restrictions. Once again thank you for your help. ... |
| 28.04.2008, 23:10 |
start [/forum/topic.php?desktop=1&fid=15&tid=1336694]: |
77ms |
50ms |
| others: | 236ms |
| total: | 413ms |
