Rows v Excel
Буду очень благодарна если ктото может помоч перевести дата из таблицы в ехсел формат. Для начала имею пустую форму... SELECT flight_Data.aircraft_Oid, 'ac_id'= dbo.Udf_Get_aircraft_id_by_Oid(flight_data.aircraft_oid), day_name_1' = upper(left(datename(weekday, dateadd(day, 1 - 1, :start_Date)), 3)), 'day_no_1' = datepart(day, dateadd(day, 1 - 1, :start_Date)), 'day_name_2' = upper(left(datename(weekday, dateadd(day, 2 - 1, :start_Date)), 3)), 'day_no_2' = datepart(day, dateadd(day, 2 - 1, :start_Date)), 'day_name_3' = upper(left(datename(weekday, dateadd(day, 3 - 1, :start_Date)), 3)), 'day_no_3' = datepart(day, dateadd(day, 3 - 1, :start_Date)), 'day_name_4' = upper(left(datename(weekday, dateadd(day, 4 - 1, :start_Date)), 3)), 'day_no_4' = datepart(day, dateadd(day, 4 - 1, :start_Date)), 'day_name_5' = upper(left(datename(weekday, dateadd(day, 5 - 1, :start_Date)), 3)), 'day_no_5' = datepart(day, dateadd(day, 5 - 1, :start_Date)), 'day_name_6' = upper(left(datename(weekday, dateadd(day, 6 - 1, :start_Date)), 3)), 'day_no_6' = datepart(day, dateadd(day, 6 - 1, :start_Date)), 'day_name_7' = upper(left(datename(weekday, dateadd(day, 7 - 1, :start_Date)), 3)), 'day_no_7' = datepart(day, dateadd(day, 7 - 1, :start_Date)), 'origin_1' = ' ', 'origin_2' = ' ', 'origin_3' = ' ', 'origin_4' = ' ', 'origin_5' = ' ', 'origin_6' = ' ', 'origin_7' = ' ', 'origin_8' = ' ', 'origin_9' = ' ', 'origin_10' = ' ', 'origin_11' = ' ', 'origin_12' = ' ', 'origin_13' = ' ', 'origin_14' = ' ', 'origin_15' = ' ', 'origin_16' = ' ', 'origin_17' = ' ', 'origin_18' = ' ', 'origin_19' = ' ', 'origin_20' = ' ', 'origin_21' = ' ', 'origin_22' = ' ', 'origin_23' = ' ', 'origin_24' = ' ', 'origin_25' = ' ', 'origin_26' = ' ', 'origin_27' = ' ', 'origin_28' = ' ', 'origin_29' = ' ', 'origin_30' = ' ', 'origin_31' = ' ', 'origin_32' = ' ', 'origin_33' = ' ', 'origin_34' = ' ', 'origin_35' = ' ' from flight_Data where actual_time_out between :start_Date and dateadd(day, 7 - 1, :start_Date) 7 днеи, 5 полетов в день.. Я могу наверно создать датастор....но не уверена как сделат луп.. Спасибо болшое всем за помощ и с Наступающим Новым Годом ... |
| 29.12.2008, 22:22 |
Rows v Excel
Svetalana Shulman, Опиши проще, что нужно получить, как понял day_name_1 должно быть ПОН, ВТО,СРЕ, и.т.д. day_no_1 - часть чего? и в каком виде? и потом это все в формат EXCEL? ... |
| 30.12.2008, 10:08 |
Rows v Excel
Imitazia Formata Excel.. Ia seichas poprobuiu prilojit' .srd datawindow file esli poluchitsia.. Rezultat kotori' nujen: Agrument nachalnaia data, zagolovki - 7 dnei s toi dati ( den' nedeli i data) Kajdi' row... dlia odnogo samoleta.. Kajdi den' vozmojno 5 poletov v datovom poriadke. Grafik ne nujen , prosto otkuda i kuda i vremia, no eto ia uje potom soobraju kak, esli u menia budet osnovnoi format. V database, kajdi' polet eto 1 record. Drugimi slovami nado perevernut' neskolko records v odnu liniu. Dumala napisat' UDAFF, s peredachei dat, no ne uverena kak eto sdelat'. Spasibo .. ... |
| 30.12.2008, 16:27 |
Rows v Excel
Svetalana Shulman, Svetalana izvini no y meny tolko versiy powerbuilder release 8. S novym year too! ... |
| 30.12.2008, 20:30 |
Rows v Excel
Так ведь есть функция SaveAs, которая сваливает баффер datawindow на диск в разные форматы, в том числе,EXCEL. Из моего скромного опыта для работы с EXCEL лучше всего проявили себя форматы Excel5! и Text!. Text! хоть и текст формат, разделённый табами, но Excel его поднимает, запросто, можно ,даже,для обману, сделать окончание файла xls, чтоб реагировал на doubleclick, потом в базу будет легче поднимать, или через bcp или через bulk insert. С новым годом, немного опаздали, мадам, спраздновал в конце сентября. Ну да ладно... ... |
| 01.01.2009, 12:57 |
Rows v Excel
No, Saveas ne srabotaet for this case.. Data v tablize otdelni' record dlia kajdogo poleta.. a mne nujno sdelat' mnojestvennie poleti v kajdoi stroke. ... |
| 02.01.2009, 16:32 |
Rows v Excel
А какая база, если SQL2005, есть там этот pivot. Не так чтоб он был прост, но, вобчем, досигаем. В Екселе Pivot есть давно, в 2002 ещё видел, как для африканских телефонистов на нём репорты мастырили, сам, правда не делал. Откройте в Екселе меню DATA->PIVOT TABLE и.т.д. Но если по старинке, ох, засмеют. Вычисляете максимальную длину строки в колонках, count(*) , group by, максимум от всего этого, потом делаете вспомогательную таблицу из одной колонки-идентификатора записи, и alter table , в цикле добавляете поля. Проявив мужество и героизм, заполняете, это творение , при помощи bcp сваливаете на диск в текстовый файл tab delimited,открываете екселем. ... |
| 05.01.2009, 19:08 |
start [/forum/search_topic.php?author=Unreal&author_mode=last_topics&do_search=1]: |
45ms |
36ms |
| others: | 612ms |
| total: | 760ms |
