XMLSpreadsheet
Есть простой XML файл <?xml version="1.0" standalone="yes" ?> <DataSet> <International> <ReisNo>351</ReisNo> <DepIATA>DOK</DepIATA> <STD>10:00</STD> <ArrIATA>KBP</ArrIATA> <STA>11:00</STA> <CraftType>Yak-42</CraftType> <Dest>0</Dest> </International> <International> <ReisNo>153</ReisNo> <DepIATA>DOK</DepIATA> <STD>03:25</STD> <ArrIATA>DME</ArrIATA> <STA>04:55</STA> <CraftType>Yak-42</CraftType> <Dest>1</Dest> </International> </DataSet> И есть XSL шаблон <?xml version="1.0" encoding="utf-8" ?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns="urn:schemas-microsoft-com:office:spreadsheet" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:x="urn:schemas-microsoft-com:office:excel" xmlns:ss="urn:schemas-microsoft-com:office:spreadsheet"> <xsl:template match="/"> <xsl:processing-instruction name="mso-application"> <xsl:text>progid="Excel.Sheet"</xsl:text> </xsl:processing-instruction> <Workbook> <Styles> <Style ss:ID="Default" ss:Name="Normal"> <Alignment ss:Vertical="Center" ss:Horizontal="Center" /> <Borders /> <Font /> <Interior /> <NumberFormat /> <Protection /> </Style> </Styles> <Worksheet ss:Name="UTC English"> <Table> <Row > <Cell> <Data ss:Type="String">NN</Data> </Cell> <Cell> <Data ss:Type="String">Flt Nr</Data> </Cell> <Cell> <Data ss:Type="String">Airport Dep</Data> </Cell> <Cell> <Data ss:Type="String">STD (UTC)</Data> </Cell> <Cell> <Data ss:Type="String">Airport Arr</Data> </Cell> <Cell> <Data ss:Type="String">STA (UTC)</Data> </Cell> <Cell> <Data ss:Type="String">Aircraft type</Data> </Cell> </Row> <Row> <Cell ss:MergeAcross="7"> <Data ss:Type="String">I Domestic</Data> </Cell> </Row> <xsl:apply-templates select="//International" /> <Row> <Cell ss:MergeAcross="7"> <Data ss:Type="String">II International</Data> </Cell> </Row> <xsl:apply-templates select="//International" /> </Table> </Worksheet> </Workbook> </xsl:template> <xsl:template match="International"> <Row> <Cell> <Data ss:Type="Number"> <xsl:number value="position()"/> </Data> </Cell> <Cell> <Data ss:Type="Number"> <xsl:value-of select="ReisNo" /> </Data> </Cell> <Cell> <Data ss:Type="String"> <xsl:value-of select="DepIATA" /> </Data> </Cell> <Cell> <Data ss:Type="String"> <xsl:value-of select="STD" /> </Data> </Cell> <Cell> <Data ss:Type="String"> <xsl:value-of select="ArrIATA" /> </Data> </Cell> <Cell> <Data ss:Type="String"> <xsl:value-of select="STA" /> </Data> </Cell> <Cell> <Data ss:Type="String"> <xsl:value-of select="CraftType" /> </Data> </Cell> </Row> </xsl:template> </xsl:stylesheet> Сейчас все данные из xml выводятся два раза (<xsl:apply-templates select="//International" />) А как можно вывести сначала узлы с <Dest>0</Dest>, потом заголовок <Data ss:Type="String">II International</Data> и наконец узлы с <Dest>1</Dest>??? ... |
| 06.04.2006, 19:02:28 |
XMLSpreadsheet
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. ... |
| 23.04.2006, 23:29:33 |
start [/forum/topic.php?desktop=1&fid=14&tid=1334815]: |
59ms |
25ms |
| others: | 212ms |
| total: | 332ms |
