Подскажите пожалуйста!!!
Как вывести результат "Function Получить" в DataGrid или Table пример функции ниже '------------------------------------------------------------------------------ ' <autogenerated> ' This code was generated by a tool. ' Runtime Version: 1.1.4322.2300 ' ' Changes to this file may cause incorrect behavior and will be lost if ' the code is regenerated. ' </autogenerated> '------------------------------------------------------------------------------ Option Strict Off Option Explicit On Imports System Imports System.ComponentModel Imports System.Diagnostics Imports System.Web.Services Imports System.Web.Services.Protocols Imports System.Xml.Serialization ' 'This source code was auto-generated by Microsoft.VSDesigner, Version 1.1.4322.2300. ' Namespace localhost '<remarks/> <System.Diagnostics.DebuggerStepThroughAttribute(), _ System.ComponentModel.DesignerCategoryAttribute("code"), _ System.Web.Services.WebServiceBindingAttribute(Name:="ПлатежноеПаручениеSoapBinding", [Namespace]:="http://www.pkpp.ru/shipment")> _ Public Class ПлатежноеПаручение Inherits System.Web.Services.Protocols.SoapHttpClientProtocol '<remarks/> Public Sub New() MyBase.New Me.Url = "http://localhost/webservis/paymants.1cws" End Sub '<remarks/> <System.Web.Services.Protocols.SoapDocumentMethodAttribute("", RequestNamespace:="http://www.pkpp.ru/shipment", ResponseNamespace:="http://www.pkpp.ru/shipment", Use:=System.Web.Services.Description.SoapBindingUse.Literal, ParameterStyle:=System.Web.Services.Protocols.SoapParameterStyle.Wrapped)> _ Public Function Получить(<System.Xml.Serialization.XmlElementAttribute(DataType:="date")> ByVal ДатаДокумента1 As Date, <System.Xml.Serialization.XmlElementAttribute(DataType:="date")> ByVal ДатаДокумента2 As Date) As <System.Xml.Serialization.XmlElementAttribute("return", IsNullable:=true)> ПлатежноеПоручение Dim results() As Object = Me.Invoke("Получить", New Object() {ДатаДокумента1, ДатаДокумента2}) Return CType(results(0),ПлатежноеПоручение) End Function '<remarks/> Public Function BeginПолучить(ByVal ДатаДокумента1 As Date, ByVal ДатаДокумента2 As Date, ByVal callback As System.AsyncCallback, ByVal asyncState As Object) As System.IAsyncResult Return Me.BeginInvoke("Получить", New Object() {ДатаДокумента1, ДатаДокумента2}, callback, asyncState) End Function '<remarks/> Public Function EndПолучить(ByVal asyncResult As System.IAsyncResult) As ПлатежноеПоручение Dim results() As Object = Me.EndInvoke(asyncResult) Return CType(results(0),ПлатежноеПоручение) End Function '<remarks/> <System.Web.Services.Protocols.SoapDocumentMethodAttribute("", RequestNamespace:="http://www.pkpp.ru/shipment", ResponseNamespace:="http://www.pkpp.ru/shipment", Use:=System.Web.Services.Description.SoapBindingUse.Literal, ParameterStyle:=System.Web.Services.Protocols.SoapParameterStyle.Wrapped)> _ Public Function Проверка(<System.Xml.Serialization.XmlElementAttribute(IsNullable:=true)> ByVal Номер As String) As <System.Xml.Serialization.XmlElementAttribute("return", IsNullable:=true)> ПлатежноеПоручение Dim results() As Object = Me.Invoke("Проверка", New Object() {Номер}) Return CType(results(0),ПлатежноеПоручение) End Function '<remarks/> Public Function BeginПроверка(ByVal Номер As String, ByVal callback As System.AsyncCallback, ByVal asyncState As Object) As System.IAsyncResult Return Me.BeginInvoke("Проверка", New Object() {Номер}, callback, asyncState) End Function '<remarks/> Public Function EndПроверка(ByVal asyncResult As System.IAsyncResult) As ПлатежноеПоручение Dim results() As Object = Me.EndInvoke(asyncResult) Return CType(results(0),ПлатежноеПоручение) End Function End Class '<remarks/> <System.Xml.Serialization.XmlTypeAttribute([Namespace]:="http://www.pkpp.ru/shipment")> _ Public Class ПлатежноеПоручение '<remarks/> Public Контрагент As String '<remarks/> Public Дата As Date '<remarks/> Public Документ As String '<remarks/> Public Номер As String '<remarks/> Public Сумма As Double '<remarks/> Public Содержание As String End Class End Namespace "Function Проверка" возвращает одно значение все без проблем вывожу в текст ,а с "Function Получить" невыходит ???? ... |
| 19.09.2006, 11:50:46 |
тебе в форум по вб, а вообще, что значит фраза "не выходит"? ... |
| 19.09.2006, 13:09:54 |
maXmoтебе в форум по вб, а вообще, что значит фраза "не выходит"? Не выходит это значит что не получается выбрать из результата функции записи ... |
| 19.09.2006, 13:26:16 |
start [/forum/topic.php?desktop=1&fid=14&tid=1334650]: |
46ms |
| others: | 232ms |
| total: | 331ms |
