XSL and java 1.5
День добрый ! Хотелось бы прояснить для себя некоторую проблемку, на 1.5 джаве при трансформации получаю ошибку на sort следующего плана <xsl:sort data-type="number" order="descending" select="sum(//*[1]/Subscription/UsageSummary[@UnitID=$PrevUnitID and @ServiceGroup=$CurrentServiceCategoryGroup and @CategoryLabel=current()/@CategoryLabel]/@RatedCost)"/> ошибка имеет вид java.lang.VerifyError: (class: GregorSamsa$4, method: extractValueFromDOM signature: (Lcom/sun/org/apache/xalan/internal/xsltc/DOM;IILcom/sun/org/apache/xalan/internal/xsltc/runtime/AbstractTranslet;I)Ljava/lang/String;) Illegal local variable number at java.lang.Class.getDeclaredConstructors0(Native Method) at java.lang.Class.privateGetDeclaredConstructors(Class.java:2357) at java.lang.Class.getConstructor0(Class.java:2671) at java.lang.Class.newInstance0(Class.java:321) at java.lang.Class.newInstance(Class.java:303) at com.sun.org.apache.xalan.internal.xsltc.dom.NodeSortRecordFactory.makeNodeSortRecord(NodeSortRecordFactory.java:149) at com.sun.org.apache.xalan.internal.xsltc.dom.SortingIterator.setStartNode(SortingIterator.java:59) XML имеет следующий вид ... <Subscription ... > <UsageSummary ServiceCategory="SharerMinutes" CategoryLabel="Calls Between Sharers" ServiceGroup="TalkBetweenSharers" UnitID="D" TimeBandID="P" QtyChargeable="95.38" BilledCost="0" RatedCost="6.68" BundleUsed="" IntraCompany="true" CDRCount="49" PrintOrder="20010" > </UsageSummary> <UsageSummary ServiceCategory="Answerphone" CategoryLabel="Answerphone" ServiceGroup="TalkOther" UnitID="D" TimeBandID="P" QtyChargeable="0.33" BilledCost="0" RatedCost="0" BundleUsed="" IntraCompany="false" CDRCount="1" PrintOrder="60010" > </UsageSummary> <UsageSummary ServiceCategory="Landline" CategoryLabel="Landline" ServiceGroup="Landline" UnitID="D" TimeBandID="P" QtyChargeable="21.48" BilledCost="0" RatedCost="1.83" BundleUsed="" IntraCompany="false" CDRCount="11" PrintOrder="50010" > </UsageSummary> </Subscription> ... при этом если убрать внутреннее условие в сорте - все работает великолепно, в чем может быть причина, помогите плизз - на 1.4 у меня эта строка работала прекрасно, заранее благодарен ... |
| 29.12.2006, 13:04:10 |
XSL and java 1.5
попробуй сделать так: <xsl:sort data-type="number" order="descending" select="{sum(//*[1]/Subscription/UsageSummary[@UnitID=$PrevUnitID and @ServiceGroup=$CurrentServiceCategoryGroup and @CategoryLabel=current()/@CategoryLabel]/@RatedCost)}"/> если память не изменяет, сложные условия с использованием значений атрибутов нужно брать в {} скобки. Проверять и ставить яву ломает, за работоспособность не ручаюсь, :) ... |
| 09.01.2007, 13:34:31 |
start [/forum/topic.php?desktop=1&fid=14&tid=1334530]: |
167ms |
46ms |
| others: | 191ms |
| total: | 434ms |
