xml xsl Excel
добрый день имеется XML отчет <?xml version="1.0" encoding="utf-8"?> <PLMXML xmlns=" http://www.plmxml.org/Schemas/PLMXMLSchema" schemaVersion="6" date="2011-08-11" time="14:29:48" author="Teamcenter V2007.1.8.2009082500 - infodba@IMC-62266904(62266904)"> <Header id="id1" traverseRootRefs="#id6 #id13" transferContext="CRF_ITM_RPT_TMODE_INST"></Header> <ProductRevision id="id12" name="333" accessRefs="#id16" subType="Деталь Revision" masterRef="#id36" revision="0"> <Description>333</Description> <ApplicationRef version="y1P1M_ntwsW4BC" application="Teamcenter" label="y1F1M_ntwsW4BC"></ApplicationRef> <UserData id="id27"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="333/0;1" title="object_string"></UserValue> <UserValue value="333" title="object_name"></UserValue> <UserValue value="333" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:26" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:09" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id26" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="333" title="item_id"></UserValue></UserData> <AssociatedForm id="id32" role="IMAN_master_form" formRef="#id28"></AssociatedForm> <AssociatedForm id="id35" role="IMAN_specification" formRef="#id33"></AssociatedForm></ProductRevision> <ProductRevision id="id49" name="63674Р-1001018_По умолчанию" accessRefs="#id16" subType="Деталь Revision" masterRef="#id60" revision="0"> <Description>63674Р-1001018_По умолчанию</Description> <ApplicationRef version="CSD1M_ntwsW4BC" application="Teamcenter" label="COK1M_ntwsW4BC"></ApplicationRef> <UserData id="id51"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="63674Р-1001018/0;1-63674Р-1001018_По умолчанию" title="object_string"></UserValue> <UserValue value="63674Р-1001018_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001018_По умолчанию" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:09" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id50" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="63674Р-1001018" title="item_id"></UserValue></UserData> <AssociatedForm id="id56" role="IMAN_master_form" formRef="#id52"></AssociatedForm> <AssociatedForm id="id59" role="IMAN_specification" formRef="#id57"></AssociatedForm></ProductRevision> <ProductRevision id="id69" name="Деталь 2" accessRefs="#id16" subType="Деталь Revision" masterRef="#id80" revision="0"> <Description>Деталь 2</Description> <ApplicationRef version="CeG1M_ntwsW4BC" application="Teamcenter" label="CaN1M_ntwsW4BC"></ApplicationRef> <UserData id="id71"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="128/0;1-Деталь 2" title="object_string"></UserValue> <UserValue value="Деталь 2" title="object_name"></UserValue> <UserValue value="Деталь 2" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:09" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id70" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="128" title="item_id"></UserValue></UserData> <AssociatedForm id="id76" role="IMAN_master_form" formRef="#id72"></AssociatedForm> <AssociatedForm id="id79" role="IMAN_specification" formRef="#id77"></AssociatedForm></ProductRevision> <ProductRevision id="id89" name="63674Р-1001016_По умолчанию" accessRefs="#id16" subType="Деталь Revision" masterRef="#id100" revision="0"> <Description>63674Р-1001016_По умолчанию</Description> <ApplicationRef version="CqJ1M_ntwsW4BC" application="Teamcenter" label="CqA1M_ntwsW4BC"></ApplicationRef> <UserData id="id91"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value=" 63674Р-1001016/0;1-63674Р-1001016_По умолчанию" title="object_string"></UserValue> <UserValue value="63674Р-1001016_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001016_По умолчанию" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:09" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id90" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value=" 63674Р-1001016" title="item_id"></UserValue></UserData> <AssociatedForm id="id96" role="IMAN_master_form" formRef="#id92"></AssociatedForm> <AssociatedForm id="id99" role="IMAN_specification" formRef="#id97"></AssociatedForm></ProductRevision> <ProductRevision id="id109" name="Пакет подушек передней опоры_По" accessRefs="#id16" subType="Деталь Revision" masterRef="#id120" revision="0"> <Description>Пакет подушек передней опоры_По умолчанию.2</Description> <ApplicationRef version="C2M1M_ntwsW4BC" application="Teamcenter" label="C2D1M_ntwsW4BC"></ApplicationRef> <UserData id="id111"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="123/0;1-Пакет подушек передней опоры_По" title="object_string"></UserValue> <UserValue value="Пакет подушек передней опоры_По" title="object_name"></UserValue> <UserValue value="Пакет подушек передней опоры_По умолчанию.2" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:09" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id110" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="123" title="item_id"></UserValue></UserData> <AssociatedForm id="id116" role="IMAN_master_form" formRef="#id112"></AssociatedForm> <AssociatedForm id="id119" role="IMAN_specification" formRef="#id117"></AssociatedForm></ProductRevision> <ProductRevision id="id125" name="Кронштейн правый в сборе" accessRefs="#id16" subType="Сб_единица Revision" masterRef="#id133" revision="0"> <Description>Кронштейн правый в сборе</Description> <ApplicationRef version="CGH1M_ntwsW4BC" application="Teamcenter" label="CCN1M_ntwsW4BC"></ApplicationRef> <UserData id="id127"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="99/0;1-Кронштейн правый в сборе" title="object_string"></UserValue> <UserValue value="Кронштейн правый в сборе" title="object_name"></UserValue> <UserValue value="Кронштейн правый в сборе" title="object_desc"></UserValue> <UserValue value="Сб_единица Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:26" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:06" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id126" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="99" title="item_id"></UserValue></UserData> <AssociatedForm id="id132" role="IMAN_master_form" formRef="#id128"></AssociatedForm></ProductRevision> <ProductRevision id="id146" name="63674Р-1001019_По умолчанию" accessRefs="#id16" subType="Деталь Revision" masterRef="#id157" revision="0"> <Description>63674Р-1001019_По умолчанию</Description> <ApplicationRef version="SOK1M_ntwsW4BC" application="Teamcenter" label="SOB1M_ntwsW4BC"></ApplicationRef> <UserData id="id148"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value=" 63674Р-1001019/0;1-63674Р-1001019_По умолчанию" title="object_string"></UserValue> <UserValue value="63674Р-1001019_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001019_По умолчанию" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id147" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value=" 63674Р-1001019" title="item_id"></UserValue></UserData> <AssociatedForm id="id153" role="IMAN_master_form" formRef="#id149"></AssociatedForm> <AssociatedForm id="id156" role="IMAN_specification" formRef="#id154"></AssociatedForm></ProductRevision> <ProductRevision id="id166" name="Деталь1" accessRefs="#id16" subType="Деталь Revision" masterRef="#id177" revision="0"> <Description>Деталь1</Description> <ApplicationRef version="SaN1M_ntwsW4BC" application="Teamcenter" label="SaE1M_ntwsW4BC"></ApplicationRef> <UserData id="id168"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="139/0;1-Деталь1" title="object_string"></UserValue> <UserValue value="Деталь1" title="object_name"></UserValue> <UserValue value="Деталь1" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id167" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="139" title="item_id"></UserValue></UserData> <AssociatedForm id="id173" role="IMAN_master_form" formRef="#id169"></AssociatedForm> <AssociatedForm id="id176" role="IMAN_specification" formRef="#id174"></AssociatedForm></ProductRevision> <ProductRevision id="id186" name="63674Р-1001017_По умолчанию" accessRefs="#id16" subType="Деталь Revision" masterRef="#id197" revision="0"> <Description>63674Р-1001017_По умолчанию</Description> <ApplicationRef version="SqA1M_ntwsW4BC" application="Teamcenter" label="SmH1M_ntwsW4BC"></ApplicationRef> <UserData id="id188"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value=" 63674Р-1001017/0;1-63674Р-1001017_По умолчанию" title="object_string"></UserValue> <UserValue value="63674Р-1001017_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001017_По умолчанию" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id187" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value=" 63674Р-1001017" title="item_id"></UserValue></UserData> <AssociatedForm id="id193" role="IMAN_master_form" formRef="#id189"></AssociatedForm> <AssociatedForm id="id196" role="IMAN_specification" formRef="#id194"></AssociatedForm></ProductRevision> <ProductRevision id="id206" name="Пакет подушек передней опоры_По" accessRefs="#id16" subType="Деталь Revision" masterRef="#id217" revision="0"> <Description>Пакет подушек передней опоры_По умолчанию.1</Description> <ApplicationRef version="S2D1M_ntwsW4BC" application="Teamcenter" label="SyK1M_ntwsW4BC"></ApplicationRef> <UserData id="id208"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="134/0;1-Пакет подушек передней опоры_По" title="object_string"></UserValue> <UserValue value="Пакет подушек передней опоры_По" title="object_name"></UserValue> <UserValue value="Пакет подушек передней опоры_По умолчанию.1" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id207" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="134" title="item_id"></UserValue></UserData> <AssociatedForm id="id213" role="IMAN_master_form" formRef="#id209"></AssociatedForm> <AssociatedForm id="id216" role="IMAN_specification" formRef="#id214"></AssociatedForm></ProductRevision> <ProductRevision id="id222" name="Кронштейн левый в сборе" accessRefs="#id16" subType="Сб_единица Revision" masterRef="#id230" revision="0"> <Description>Кронштейн левый в сборе</Description> <ApplicationRef version="SCP1M_ntwsW4BC" application="Teamcenter" label="SCG1M_ntwsW4BC"></ApplicationRef> <UserData id="id224"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="100/0;1-Кронштейн левый в сборе" title="object_string"></UserValue> <UserValue value="Кронштейн левый в сборе" title="object_name"></UserValue> <UserValue value="Кронштейн левый в сборе" title="object_desc"></UserValue> <UserValue value="Сб_единица Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:06" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id223" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="100" title="item_id"></UserValue></UserData> <AssociatedForm id="id229" role="IMAN_master_form" formRef="#id225"></AssociatedForm></ProductRevision> <ProductRevision id="id239" name="ZF 16S2220TO" accessRefs="#id16" subType="Деталь Revision" masterRef="#id250" revision="0"> <Description>ZF 16S2220TO</Description> <ApplicationRef version="iCG1M_ntwsW4BC" application="Teamcenter" label="S_N1M_ntwsW4BC"></ApplicationRef> <UserData id="id241"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="ZF 16S2220TO/0;1" title="object_string"></UserValue> <UserValue value="ZF 16S2220TO" title="object_name"></UserValue> <UserValue value="ZF 16S2220TO" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id240" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="ZF 16S2220TO" title="item_id"></UserValue></UserData> <AssociatedForm id="id246" role="IMAN_master_form" formRef="#id242"></AssociatedForm> <AssociatedForm id="id249" role="IMAN_specification" formRef="#id247"></AssociatedForm></ProductRevision> <ProductRevision id="id259" name="Кожух вентилятора на двигателе" accessRefs="#id16" subType="Деталь Revision" masterRef="#id270" revision="0"> <Description>Кожух вентилятора на двигателе</Description> <ApplicationRef version="iOJ1M_ntwsW4BC" application="Teamcenter" label="iOA1M_ntwsW4BC"></ApplicationRef> <UserData id="id261"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="102/0;1-Кожух вентилятора на двигателе" title="object_string"></UserValue> <UserValue value="Кожух вентилятора на двигателе" title="object_name"></UserValue> <UserValue value="Кожух вентилятора на двигателе" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id260" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="102" title="item_id"></UserValue></UserData> <AssociatedForm id="id266" role="IMAN_master_form" formRef="#id262"></AssociatedForm> <AssociatedForm id="id269" role="IMAN_specification" formRef="#id267"></AssociatedForm></ProductRevision> <ProductRevision id="id279" name="Задний левый кронштейн двигателя" accessRefs="#id16" subType="Деталь Revision" masterRef="#id290" revision="0"> <Description>Задний левый кронштейн двигателя</Description> <ApplicationRef version="iaM1M_ntwsW4BC" application="Teamcenter" label="iaD1M_ntwsW4BC"></ApplicationRef> <UserData id="id281"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="103/0;1-Задний левый кронштейн двигателя" title="object_string"></UserValue> <UserValue value="Задний левый кронштейн двигателя" title="object_name"></UserValue> <UserValue value="Задний левый кронштейн двигателя" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id280" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="103" title="item_id"></UserValue></UserData> <AssociatedForm id="id286" role="IMAN_master_form" formRef="#id282"></AssociatedForm> <AssociatedForm id="id289" role="IMAN_specification" formRef="#id287"></AssociatedForm></ProductRevision> <ProductRevision id="id299" name="Symmetry of Задний левый кронште" accessRefs="#id16" subType="Деталь Revision" masterRef="#id310" revision="0"> <Description>Symmetry of Задний левый кронштейн двигателя</Description> <ApplicationRef version="imP1M_ntwsW4BC" application="Teamcenter" label="imG1M_ntwsW4BC"></ApplicationRef> <UserData id="id301"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="104/0;1-Symmetry of Задний левый кронште" title="object_string"></UserValue> <UserValue value="Symmetry of Задний левый кронште" title="object_name"></UserValue> <UserValue value="Symmetry of Задний левый кронштейн двигателя" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id300" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="104" title="item_id"></UserValue></UserData> <AssociatedForm id="id306" role="IMAN_master_form" formRef="#id302"></AssociatedForm> <AssociatedForm id="id309" role="IMAN_specification" formRef="#id307"></AssociatedForm></ProductRevision> <ProductRevision id="id319" name="Скоба правая" accessRefs="#id16" subType="Деталь Revision" masterRef="#id330" revision="0"> <Description>Скоба правая</Description> <ApplicationRef version="i2C1M_ntwsW4BC" application="Teamcenter" label="iyJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id321"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="106/0;1-Скоба правая" title="object_string"></UserValue> <UserValue value="Скоба правая" title="object_name"></UserValue> <UserValue value="Скоба правая" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:10" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id320" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="106" title="item_id"></UserValue></UserData> <AssociatedForm id="id326" role="IMAN_master_form" formRef="#id322"></AssociatedForm> <AssociatedForm id="id329" role="IMAN_specification" formRef="#id327"></AssociatedForm></ProductRevision> <ProductRevision id="id339" name="6370-1109131" accessRefs="#id16" subType="Деталь Revision" masterRef="#id350" revision="0"> <Description>6370-1109131</Description> <ApplicationRef version="yCF1M_ntwsW4BC" application="Teamcenter" label="i_M1M_ntwsW4BC"></ApplicationRef> <UserData id="id341"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1109131/0;1" title="object_string"></UserValue> <UserValue value="6370-1109131" title="object_name"></UserValue> <UserValue value="6370-1109131" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id340" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1109131" title="item_id"></UserValue></UserData> <AssociatedForm id="id346" role="IMAN_master_form" formRef="#id342"></AssociatedForm> <AssociatedForm id="id349" role="IMAN_specification" formRef="#id347"></AssociatedForm></ProductRevision> <ProductRevision id="id363" name="6370-1109047" accessRefs="#id16" subType="Деталь Revision" masterRef="#id374" revision="0"> <Description>6370-1109047</Description> <ApplicationRef version="yaD1M_ntwsW4BC" application="Teamcenter" label="yWK1M_ntwsW4BC"></ApplicationRef> <UserData id="id365"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1109047/0;1" title="object_string"></UserValue> <UserValue value="6370-1109047" title="object_name"></UserValue> <UserValue value="6370-1109047" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id364" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1109047" title="item_id"></UserValue></UserData> <AssociatedForm id="id370" role="IMAN_master_form" formRef="#id366"></AssociatedForm> <AssociatedForm id="id373" role="IMAN_specification" formRef="#id371"></AssociatedForm></ProductRevision> <ProductRevision id="id383" name="6370-1109138" accessRefs="#id16" subType="Деталь Revision" masterRef="#id394" revision="0"> <Description>6370-1109138</Description> <ApplicationRef version="ymG1M_ntwsW4BC" application="Teamcenter" label="yiN1M_ntwsW4BC"></ApplicationRef> <UserData id="id385"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1109138/0;1" title="object_string"></UserValue> <UserValue value="6370-1109138" title="object_name"></UserValue> <UserValue value="6370-1109138" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id384" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1109138" title="item_id"></UserValue></UserData> <AssociatedForm id="id390" role="IMAN_master_form" formRef="#id386"></AssociatedForm> <AssociatedForm id="id393" role="IMAN_specification" formRef="#id391"></AssociatedForm></ProductRevision> <ProductRevision id="id403" name="5323E-1109225" accessRefs="#id16" subType="Деталь Revision" masterRef="#id414" revision="0"> <Description>5323E-1109225</Description> <ApplicationRef version="yyJ1M_ntwsW4BC" application="Teamcenter" label="yyA1M_ntwsW4BC"></ApplicationRef> <UserData id="id405"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="5323E-1109225/0;1" title="object_string"></UserValue> <UserValue value="5323E-1109225" title="object_name"></UserValue> <UserValue value="5323E-1109225" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id404" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="5323E-1109225" title="item_id"></UserValue></UserData> <AssociatedForm id="id408" role="IMAN_specification" formRef="#id406"></AssociatedForm> <AssociatedForm id="id413" role="IMAN_master_form" formRef="#id409"></AssociatedForm></ProductRevision> <ProductRevision id="id419" name="6370-1109046" accessRefs="#id16" subType="Сб_единица Revision" masterRef="#id427" revision="0"> <Description>6370-1109046</Description> <ApplicationRef version="yOI1M_ntwsW4BC" application="Teamcenter" label="yKP1M_ntwsW4BC"></ApplicationRef> <UserData id="id421"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1109046/0;1" title="object_string"></UserValue> <UserValue value="6370-1109046" title="object_name"></UserValue> <UserValue value="6370-1109046" title="object_desc"></UserValue> <UserValue value="Сб_единица Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:06" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id420" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1109046" title="item_id"></UserValue></UserData> <AssociatedForm id="id426" role="IMAN_master_form" formRef="#id422"></AssociatedForm></ProductRevision> <ProductRevision id="id440" name="CHR-10816-12_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id451" revision="0"> <Description>CHR-10816-12_AF0</Description> <ApplicationRef version="CLH1M_ntwsW4BC" application="Teamcenter" label="CHO1M_ntwsW4BC"></ApplicationRef> <UserData id="id442"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-12_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-12_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-12_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id441" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-12_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id447" role="IMAN_master_form" formRef="#id443"></AssociatedForm> <AssociatedForm id="id450" role="IMAN_specification" formRef="#id448"></AssociatedForm></ProductRevision> <ProductRevision id="id460" name="CHR-10816-14_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id471" revision="0"> <Description>CHR-10816-14_AF0</Description> <ApplicationRef version="CXK1M_ntwsW4BC" application="Teamcenter" label="CXB1M_ntwsW4BC"></ApplicationRef> <UserData id="id462"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-14_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-14_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-14_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id461" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-14_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id467" role="IMAN_master_form" formRef="#id463"></AssociatedForm> <AssociatedForm id="id470" role="IMAN_specification" formRef="#id468"></AssociatedForm></ProductRevision> <ProductRevision id="id480" name="CHR-10816-16_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id491" revision="0"> <Description>CHR-10816-16_AF0</Description> <ApplicationRef version="CjN1M_ntwsW4BC" application="Teamcenter" label="CjE1M_ntwsW4BC"></ApplicationRef> <UserData id="id482"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-16_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-16_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-16_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id481" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-16_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id487" role="IMAN_master_form" formRef="#id483"></AssociatedForm> <AssociatedForm id="id490" role="IMAN_specification" formRef="#id488"></AssociatedForm></ProductRevision> <ProductRevision id="id500" name="CHR-10816-18_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id511" revision="0"> <Description>CHR-10816-18_AF0</Description> <ApplicationRef version="CzA1M_ntwsW4BC" application="Teamcenter" label="CvH1M_ntwsW4BC"></ApplicationRef> <UserData id="id502"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-18_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-18_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-18_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id501" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-18_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id505" role="IMAN_specification" formRef="#id503"></AssociatedForm> <AssociatedForm id="id510" role="IMAN_master_form" formRef="#id506"></AssociatedForm></ProductRevision> <ProductRevision id="id520" name="CHR-10816-20_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id531" revision="0"> <Description>CHR-10816-20_AF0</Description> <ApplicationRef version="C$D1M_ntwsW4BC" application="Teamcenter" label="C7K1M_ntwsW4BC"></ApplicationRef> <UserData id="id522"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-20_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-20_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-20_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id521" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-20_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id527" role="IMAN_master_form" formRef="#id523"></AssociatedForm> <AssociatedForm id="id530" role="IMAN_specification" formRef="#id528"></AssociatedForm></ProductRevision> <ProductRevision id="id540" name="CHR-10816-24_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id551" revision="0"> <Description>CHR-10816-24_AF0</Description> <ApplicationRef version="SLG1M_ntwsW4BC" application="Teamcenter" label="SHN1M_ntwsW4BC"></ApplicationRef> <UserData id="id542"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-24_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-24_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-24_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id541" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-24_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id547" role="IMAN_master_form" formRef="#id543"></AssociatedForm> <AssociatedForm id="id550" role="IMAN_specification" formRef="#id548"></AssociatedForm></ProductRevision> <ProductRevision id="id560" name="CHR-10816-22_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id571" revision="0"> <Description>CHR-10816-22_AF0</Description> <ApplicationRef version="SXJ1M_ntwsW4BC" application="Teamcenter" label="SXA1M_ntwsW4BC"></ApplicationRef> <UserData id="id562"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-22_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-22_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-22_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id561" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-22_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id567" role="IMAN_master_form" formRef="#id563"></AssociatedForm> <AssociatedForm id="id570" role="IMAN_specification" formRef="#id568"></AssociatedForm></ProductRevision> <ProductRevision id="id580" name="CHR-10816-20_AF1" accessRefs="#id16" subType="Деталь Revision" masterRef="#id591" revision="0"> <Description>CHR-10816-20_AF1</Description> <ApplicationRef version="SjM1M_ntwsW4BC" application="Teamcenter" label="SjD1M_ntwsW4BC"></ApplicationRef> <UserData id="id582"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-20_AF1/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-20_AF1" title="object_name"></UserValue> <UserValue value="CHR-10816-20_AF1" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id581" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-20_AF1" title="item_id"></UserValue></UserData> <AssociatedForm id="id587" role="IMAN_master_form" formRef="#id583"></AssociatedForm> <AssociatedForm id="id590" role="IMAN_specification" formRef="#id588"></AssociatedForm></ProductRevision> <ProductRevision id="id600" name="CHR-10816-24_AF1" accessRefs="#id16" subType="Деталь Revision" masterRef="#id611" revision="0"> <Description>CHR-10816-24_AF1</Description> <ApplicationRef version="SvP1M_ntwsW4BC" application="Teamcenter" label="SvG1M_ntwsW4BC"></ApplicationRef> <UserData id="id602"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-24_AF1/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-24_AF1" title="object_name"></UserValue> <UserValue value="CHR-10816-24_AF1" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id601" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-24_AF1" title="item_id"></UserValue></UserData> <AssociatedForm id="id605" role="IMAN_specification" formRef="#id603"></AssociatedForm> <AssociatedForm id="id610" role="IMAN_master_form" formRef="#id606"></AssociatedForm></ProductRevision> <ProductRevision id="id620" name="CHR-10816-22_AF1" accessRefs="#id16" subType="Деталь Revision" masterRef="#id631" revision="0"> <Description>CHR-10816-22_AF1</Description> <ApplicationRef version="S$C1M_ntwsW4BC" application="Teamcenter" label="S7J1M_ntwsW4BC"></ApplicationRef> <UserData id="id622"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-22_AF1/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-22_AF1" title="object_name"></UserValue> <UserValue value="CHR-10816-22_AF1" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id621" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-22_AF1" title="item_id"></UserValue></UserData> <AssociatedForm id="id627" role="IMAN_master_form" formRef="#id623"></AssociatedForm> <AssociatedForm id="id630" role="IMAN_specification" formRef="#id628"></AssociatedForm></ProductRevision> <ProductRevision id="id640" name="CHR-10816-26_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id651" revision="0"> <Description>CHR-10816-26_AF0</Description> <ApplicationRef version="iLF1M_ntwsW4BC" application="Teamcenter" label="iHM1M_ntwsW4BC"></ApplicationRef> <UserData id="id642"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-26_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-26_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-26_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:11" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id641" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-26_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id647" role="IMAN_master_form" formRef="#id643"></AssociatedForm> <AssociatedForm id="id650" role="IMAN_specification" formRef="#id648"></AssociatedForm></ProductRevision> <ProductRevision id="id660" name="850-1009073_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id671" revision="0"> <Description>850-1009073_AF0</Description> <ApplicationRef version="iXI1M_ntwsW4BC" application="Teamcenter" label="iTP1M_ntwsW4BC"></ApplicationRef> <UserData id="id662"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="850-1009073_AF0/0;1" title="object_string"></UserValue> <UserValue value="850-1009073_AF0" title="object_name"></UserValue> <UserValue value="850-1009073_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id661" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="850-1009073_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id667" role="IMAN_master_form" formRef="#id663"></AssociatedForm> <AssociatedForm id="id670" role="IMAN_specification" formRef="#id668"></AssociatedForm></ProductRevision> <ProductRevision id="id680" name="236-1009024-B" accessRefs="#id16" subType="Деталь Revision" masterRef="#id691" revision="0"> <Description>236-1009024-B</Description> <ApplicationRef version="ijL1M_ntwsW4BC" application="Teamcenter" label="ijC1M_ntwsW4BC"></ApplicationRef> <UserData id="id682"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="236-1009024-B/0;1" title="object_string"></UserValue> <UserValue value="236-1009024-B" title="object_name"></UserValue> <UserValue value="236-1009024-B" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id681" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="236-1009024-B" title="item_id"></UserValue></UserData> <AssociatedForm id="id687" role="IMAN_master_form" formRef="#id683"></AssociatedForm> <AssociatedForm id="id690" role="IMAN_specification" formRef="#id688"></AssociatedForm></ProductRevision> <ProductRevision id="id700" name="201-1009042-B" accessRefs="#id16" subType="Деталь Revision" masterRef="#id711" revision="0"> <Description>201-1009042-B</Description> <ApplicationRef version="ivO1M_ntwsW4BC" application="Teamcenter" label="ivF1M_ntwsW4BC"></ApplicationRef> <UserData id="id702"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="201-1009042-B/0;1" title="object_string"></UserValue> <UserValue value="201-1009042-B" title="object_name"></UserValue> <UserValue value="201-1009042-B" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id701" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="201-1009042-B" title="item_id"></UserValue></UserData> <AssociatedForm id="id705" role="IMAN_specification" formRef="#id703"></AssociatedForm> <AssociatedForm id="id710" role="IMAN_master_form" formRef="#id706"></AssociatedForm></ProductRevision> <ProductRevision id="id720" name="316180-P2" accessRefs="#id16" subType="Деталь Revision" masterRef="#id731" revision="0"> <Description>316180-P2</Description> <ApplicationRef version="i$B1M_ntwsW4BC" application="Teamcenter" label="i7I1M_ntwsW4BC"></ApplicationRef> <UserData id="id722"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="316180-P2/0;1" title="object_string"></UserValue> <UserValue value="316180-P2" title="object_name"></UserValue> <UserValue value="316180-P2" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id721" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="316180-P2" title="item_id"></UserValue></UserData> <AssociatedForm id="id727" role="IMAN_master_form" formRef="#id723"></AssociatedForm> <AssociatedForm id="id730" role="IMAN_specification" formRef="#id728"></AssociatedForm></ProductRevision> <ProductRevision id="id740" name="CHR-10816-28_AF0" accessRefs="#id16" subType="Деталь Revision" masterRef="#id751" revision="0"> <Description>CHR-10816-28_AF0</Description> <ApplicationRef version="yLE1M_ntwsW4BC" application="Teamcenter" label="yHL1M_ntwsW4BC"></ApplicationRef> <UserData id="id742"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="CHR-10816-28_AF0/0;1" title="object_string"></UserValue> <UserValue value="CHR-10816-28_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-28_AF0" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id741" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="CHR-10816-28_AF0" title="item_id"></UserValue></UserData> <AssociatedForm id="id747" role="IMAN_master_form" formRef="#id743"></AssociatedForm> <AssociatedForm id="id750" role="IMAN_specification" formRef="#id748"></AssociatedForm></ProductRevision> <ProductRevision id="id756" name="Картер масляный (new)" accessRefs="#id16" subType="Сб_единица Revision" masterRef="#id764" revision="0"> <Description>Картер масляный (new)</Description> <ApplicationRef version="y_M1M_ntwsW4BC" application="Teamcenter" label="y_D1M_ntwsW4BC"></ApplicationRef> <UserData id="id758"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="Karter new/0;1-Картер масляный (new)" title="object_string"></UserValue> <UserValue value="Картер масляный (new)" title="object_name"></UserValue> <UserValue value="Картер масляный (new)" title="object_desc"></UserValue> <UserValue value="Сб_единица Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:06" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id757" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="Karter new" title="item_id"></UserValue></UserData> <AssociatedForm id="id763" role="IMAN_master_form" formRef="#id759"></AssociatedForm></ProductRevision> <ProductRevision id="id773" name="651-C_SW0001" accessRefs="#id16" subType="Деталь Revision" masterRef="#id784" revision="0"> <Description>651-C_SW0001</Description> <ApplicationRef version="yXH1M_ntwsW4BC" application="Teamcenter" label="yTO1M_ntwsW4BC"></ApplicationRef> <UserData id="id775"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="651-C_SW0001/0;1" title="object_string"></UserValue> <UserValue value="651-C_SW0001" title="object_name"></UserValue> <UserValue value="651-C_SW0001" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id774" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="651-C_SW0001" title="item_id"></UserValue></UserData> <AssociatedForm id="id780" role="IMAN_master_form" formRef="#id776"></AssociatedForm> <AssociatedForm id="id783" role="IMAN_specification" formRef="#id781"></AssociatedForm></ProductRevision> <ProductRevision id="id793" name="Центр шарнира управления КПП" accessRefs="#id16" subType="Деталь Revision" masterRef="#id804" revision="0"> <Description>Центр шарнира управления КПП</Description> <ApplicationRef version="yjK1M_ntwsW4BC" application="Teamcenter" label="yjB1M_ntwsW4BC"></ApplicationRef> <UserData id="id795"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="110/0;1-Центр шарнира управления КПП" title="object_string"></UserValue> <UserValue value="Центр шарнира управления КПП" title="object_name"></UserValue> <UserValue value="Центр шарнира управления КПП" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id794" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="110" title="item_id"></UserValue></UserData> <AssociatedForm id="id800" role="IMAN_master_form" formRef="#id796"></AssociatedForm> <AssociatedForm id="id803" role="IMAN_specification" formRef="#id801"></AssociatedForm></ProductRevision> <ProductRevision id="id813" name="6370-1109131-99" accessRefs="#id16" subType="Деталь Revision" masterRef="#id824" revision="0"> <Description>6370-1109131-99</Description> <ApplicationRef version="yvN1M_ntwsW4BC" application="Teamcenter" label="yvE1M_ntwsW4BC"></ApplicationRef> <UserData id="id815"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1109131-99/0;1" title="object_string"></UserValue> <UserValue value="6370-1109131-99" title="object_name"></UserValue> <UserValue value="6370-1109131-99" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id814" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1109131-99" title="item_id"></UserValue></UserData> <AssociatedForm id="id818" role="IMAN_specification" formRef="#id816"></AssociatedForm> <AssociatedForm id="id823" role="IMAN_master_form" formRef="#id819"></AssociatedForm></ProductRevision> <ProductRevision id="id833" name="63674P-1308005" accessRefs="#id16" subType="Деталь Revision" masterRef="#id844" revision="0"> <Description>63674P-1308005</Description> <ApplicationRef version="y$A1M_ntwsW4BC" application="Teamcenter" label="y7H1M_ntwsW4BC"></ApplicationRef> <UserData id="id835"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="63674P-1308005/0;1" title="object_string"></UserValue> <UserValue value="63674P-1308005" title="object_name"></UserValue> <UserValue value="63674P-1308005" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id834" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="63674P-1308005" title="item_id"></UserValue></UserData> <AssociatedForm id="id838" role="IMAN_specification" formRef="#id836"></AssociatedForm> <AssociatedForm id="id843" role="IMAN_master_form" formRef="#id839"></AssociatedForm></ProductRevision> <ProductRevision id="id853" name="6370-1109131-98" accessRefs="#id16" subType="Деталь Revision" masterRef="#id864" revision="0"> <Description>6370-1109131-98</Description> <ApplicationRef version="DID1M_ntwsW4BC" application="Teamcenter" label="DEK1M_ntwsW4BC"></ApplicationRef> <UserData id="id855"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1109131-98/0;1" title="object_string"></UserValue> <UserValue value="6370-1109131-98" title="object_name"></UserValue> <UserValue value="6370-1109131-98" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id854" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1109131-98" title="item_id"></UserValue></UserData> <AssociatedForm id="id860" role="IMAN_master_form" formRef="#id856"></AssociatedForm> <AssociatedForm id="id863" role="IMAN_specification" formRef="#id861"></AssociatedForm></ProductRevision> <ProductRevision id="id873" name="Компрессор кондиционера" accessRefs="#id16" subType="Деталь Revision" masterRef="#id884" revision="0"> <Description>Компрессор кондиционера</Description> <ApplicationRef version="DUG1M_ntwsW4BC" application="Teamcenter" label="DQN1M_ntwsW4BC"></ApplicationRef> <UserData id="id875"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="114/0;1-Компрессор кондиционера" title="object_string"></UserValue> <UserValue value="Компрессор кондиционера" title="object_name"></UserValue> <UserValue value="Компрессор кондиционера" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id874" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="114" title="item_id"></UserValue></UserData> <AssociatedForm id="id880" role="IMAN_master_form" formRef="#id876"></AssociatedForm> <AssociatedForm id="id883" role="IMAN_specification" formRef="#id881"></AssociatedForm></ProductRevision> <ProductRevision id="id893" name="tub-adm.IGS" accessRefs="#id16" subType="Деталь Revision" masterRef="#id904" revision="0"> <Description>tub-adm.IGS</Description> <ApplicationRef version="DgJ1M_ntwsW4BC" application="Teamcenter" label="DgA1M_ntwsW4BC"></ApplicationRef> <UserData id="id895"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="115/0;1-tub-adm.IGS" title="object_string"></UserValue> <UserValue value="tub-adm.IGS" title="object_name"></UserValue> <UserValue value="tub-adm.IGS" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id894" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="115" title="item_id"></UserValue></UserData> <AssociatedForm id="id900" role="IMAN_master_form" formRef="#id896"></AssociatedForm> <AssociatedForm id="id903" role="IMAN_specification" formRef="#id901"></AssociatedForm></ProductRevision> <ProductRevision id="id913" name="КОМ ZF N71/4c" accessRefs="#id16" subType="Деталь Revision" masterRef="#id924" revision="0"> <Description>КОМ ZF N71/4c</Description> <ApplicationRef version="DsM1M_ntwsW4BC" application="Teamcenter" label="DsD1M_ntwsW4BC"></ApplicationRef> <UserData id="id915"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="116/0;1-КОМ ZF N71/4c" title="object_string"></UserValue> <UserValue value="КОМ ZF N71/4c" title="object_name"></UserValue> <UserValue value="КОМ ZF N71/4c" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:12" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id914" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="116" title="item_id"></UserValue></UserData> <AssociatedForm id="id918" role="IMAN_specification" formRef="#id916"></AssociatedForm> <AssociatedForm id="id923" role="IMAN_master_form" formRef="#id919"></AssociatedForm></ProductRevision> <ProductRevision id="id933" name="Насос HYVA-061L" accessRefs="#id16" subType="Деталь Revision" masterRef="#id944" revision="0"> <Description>Насос HYVA-061L</Description> <ApplicationRef version="D4P1M_ntwsW4BC" application="Teamcenter" label="D4G1M_ntwsW4BC"></ApplicationRef> <UserData id="id935"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="117/0;1-Насос HYVA-061L" title="object_string"></UserValue> <UserValue value="Насос HYVA-061L" title="object_name"></UserValue> <UserValue value="Насос HYVA-061L" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:13" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id934" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="117" title="item_id"></UserValue></UserData> <AssociatedForm id="id940" role="IMAN_master_form" formRef="#id936"></AssociatedForm> <AssociatedForm id="id943" role="IMAN_specification" formRef="#id941"></AssociatedForm></ProductRevision> <ProductRevision id="id957" name="Kricshka Kompressora Kondicioner" accessRefs="#id16" subType="Деталь Revision" masterRef="#id968" revision="0"> <Description>Kricshka Kompressora Kondicionera</Description> <ApplicationRef version="TQN1M_ntwsW4BC" application="Teamcenter" label="TQE1M_ntwsW4BC"></ApplicationRef> <UserData id="id959"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="161/0;1-Kricshka Kompressora Kondicioner" title="object_string"></UserValue> <UserValue value="Kricshka Kompressora Kondicioner" title="object_name"></UserValue> <UserValue value="Kricshka Kompressora Kondicionera" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:13" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id958" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="161" title="item_id"></UserValue></UserData> <AssociatedForm id="id964" role="IMAN_master_form" formRef="#id960"></AssociatedForm> <AssociatedForm id="id967" role="IMAN_specification" formRef="#id965"></AssociatedForm></ProductRevision> <ProductRevision id="id977" name="Trubka Kompressora 2" accessRefs="#id16" subType="Деталь Revision" masterRef="#id988" revision="0"> <Description>Trubka Kompressora 2</Description> <ApplicationRef version="TgA1M_ntwsW4BC" application="Teamcenter" label="TcH1M_ntwsW4BC"></ApplicationRef> <UserData id="id979"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="162/0;1-Trubka Kompressora 2" title="object_string"></UserValue> <UserValue value="Trubka Kompressora 2" title="object_name"></UserValue> <UserValue value="Trubka Kompressora 2" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:13" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id978" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="162" title="item_id"></UserValue></UserData> <AssociatedForm id="id984" role="IMAN_master_form" formRef="#id980"></AssociatedForm> <AssociatedForm id="id987" role="IMAN_specification" formRef="#id985"></AssociatedForm></ProductRevision> <ProductRevision id="id997" name="Trubka Kompressora 1" accessRefs="#id16" subType="Деталь Revision" masterRef="#id1008" revision="0"> <Description>Trubka Kompressora 1</Description> <ApplicationRef version="TsD1M_ntwsW4BC" application="Teamcenter" label="ToK1M_ntwsW4BC"></ApplicationRef> <UserData id="id999"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="163/0;1-Trubka Kompressora 1" title="object_string"></UserValue> <UserValue value="Trubka Kompressora 1" title="object_name"></UserValue> <UserValue value="Trubka Kompressora 1" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:13" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id998" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="163" title="item_id"></UserValue></UserData> <AssociatedForm id="id1004" role="IMAN_master_form" formRef="#id1000"></AssociatedForm> <AssociatedForm id="id1007" role="IMAN_specification" formRef="#id1005"></AssociatedForm></ProductRevision> <ProductRevision id="id1017" name="Pimpka Kompressora" accessRefs="#id16" subType="Деталь Revision" masterRef="#id1028" revision="0"> <Description>Pimpka Kompressora</Description> <ApplicationRef version="T4G1M_ntwsW4BC" application="Teamcenter" label="T0N1M_ntwsW4BC"></ApplicationRef> <UserData id="id1019"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="164/0;1-Pimpka Kompressora" title="object_string"></UserValue> <UserValue value="Pimpka Kompressora" title="object_name"></UserValue> <UserValue value="Pimpka Kompressora" title="object_desc"></UserValue> <UserValue value="Деталь Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:13" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id1018" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="164" title="item_id"></UserValue></UserData> <AssociatedForm id="id1024" role="IMAN_master_form" formRef="#id1020"></AssociatedForm> <AssociatedForm id="id1027" role="IMAN_specification" formRef="#id1025"></AssociatedForm></ProductRevision> <ProductRevision id="id1037" name="Kricshka Kompressora (Sborka)" accessRefs="#id16" subType="Сб_единица Revision" masterRef="#id1045" revision="0"> <Description>Kricshka Kompressora (Sborka)</Description> <ApplicationRef version="TIC1M_ntwsW4BC" application="Teamcenter" label="TEJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id1039"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="118/0;1-Kricshka Kompressora (Sborka)" title="object_string"></UserValue> <UserValue value="Kricshka Kompressora (Sborka)" title="object_name"></UserValue> <UserValue value="Kricshka Kompressora (Sborka)" title="object_desc"></UserValue> <UserValue value="Сб_единица Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:06" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id1038" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="118" title="item_id"></UserValue></UserData> <AssociatedForm id="id1044" role="IMAN_master_form" formRef="#id1040"></AssociatedForm></ProductRevision> <ProductRevision id="id1050" name="Силовой агрегат" accessRefs="#id16" subType="Сб_установка Revision" masterRef="#id1058" revision="0"> <Description>Силовой агрегат</Description> <ApplicationRef version="yND1M_ntwsW4BC" application="Teamcenter" label="ipN1M_ntwsW4BC"></ApplicationRef> <UserData id="id1052"> <UserValue value="0" title="item_revision_id"></UserValue> <UserValue value="6370-1000250-10/0;1-Силовой агрегат" title="object_string"></UserValue> <UserValue value="Силовой агрегат" title="object_name"></UserValue> <UserValue value="Силовой агрегат" title="object_desc"></UserValue> <UserValue value="Сб_установка Revision" title="object_type"></UserValue> <UserValue value="" title="process_stage"></UserValue> <UserValue value="2011-05-10T10:07:25" title="creation_date"></UserValue> <UserValue value="2011-05-10T10:10:06" title="last_mod_date"></UserValue> <UserValue value="0-01-00T00:00:00" title="date_released"></UserValue> <UserValue type="reference" value="" title="owning_user" dataRef="#id13"></UserValue> <UserValue type="reference" value="" title="owning_group" dataRef="#id20"></UserValue> <UserValue value="" title="release_status_list"> <UserList id="id1051" type="list"></UserList></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue> <UserValue value="6370-1000250-10" title="item_id"></UserValue></UserData> <AssociatedForm id="id1057" role="IMAN_master_form" formRef="#id1053"></AssociatedForm></ProductRevision> <Product id="id36" name="333" accessRefs="#id16" subType="Деталь" productId="333"> <Description>333</Description> <ApplicationRef version="y1F1M_ntwsW4BC" application="Teamcenter" label="y1F1M_ntwsW4BC"></ApplicationRef> <UserData id="id37"> <UserValue value="333" title="item_id"></UserValue> <UserValue value="333" title="object_name"></UserValue> <UserValue value="333" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:26" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id40" role="IMAN_master_form" formRef="#id38"></AssociatedForm></Product> <Product id="id60" name="63674Р-1001018_По умолчанию" accessRefs="#id16" subType="Деталь" productId="63674Р-1001018"> <Description>63674Р-1001018_По умолчанию</Description> <ApplicationRef version="COK1M_ntwsW4BC" application="Teamcenter" label="COK1M_ntwsW4BC"></ApplicationRef> <UserData id="id61"> <UserValue value="63674Р-1001018" title="item_id"></UserValue> <UserValue value="63674Р-1001018_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001018_По умолчанию" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id64" role="IMAN_master_form" formRef="#id62"></AssociatedForm></Product> <Product id="id80" name="Деталь 2" accessRefs="#id16" subType="Деталь" productId="128"> <Description>Деталь 2</Description> <ApplicationRef version="CaN1M_ntwsW4BC" application="Teamcenter" label="CaN1M_ntwsW4BC"></ApplicationRef> <UserData id="id81"> <UserValue value="128" title="item_id"></UserValue> <UserValue value="Деталь 2" title="object_name"></UserValue> <UserValue value="Деталь 2" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id84" role="IMAN_master_form" formRef="#id82"></AssociatedForm></Product> <Product id="id100" name="63674Р-1001016_По умолчанию" accessRefs="#id16" subType="Деталь" productId=" 63674Р-1001016"> <Description>63674Р-1001016_По умолчанию</Description> <ApplicationRef version="CqA1M_ntwsW4BC" application="Teamcenter" label="CqA1M_ntwsW4BC"></ApplicationRef> <UserData id="id101"> <UserValue value=" 63674Р-1001016" title="item_id"></UserValue> <UserValue value="63674Р-1001016_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001016_По умолчанию" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id104" role="IMAN_master_form" formRef="#id102"></AssociatedForm></Product> <Product id="id120" name="Пакет подушек передней опоры_По" accessRefs="#id16" subType="Деталь" productId="123"> <Description>Пакет подушек передней опоры_По умолчанию.2</Description> <ApplicationRef version="C2D1M_ntwsW4BC" application="Teamcenter" label="C2D1M_ntwsW4BC"></ApplicationRef> <UserData id="id121"> <UserValue value="123" title="item_id"></UserValue> <UserValue value="Пакет подушек передней опоры_По" title="object_name"></UserValue> <UserValue value="Пакет подушек передней опоры_По умолчанию.2" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id124" role="IMAN_master_form" formRef="#id122"></AssociatedForm></Product> <Product id="id133" name="Кронштейн правый в сборе" accessRefs="#id16" subType="Сб_единица" productId="99"> <Description>Кронштейн правый в сборе</Description> <ApplicationRef version="CCN1M_ntwsW4BC" application="Teamcenter" label="CCN1M_ntwsW4BC"></ApplicationRef> <UserData id="id134"> <UserValue value="99" title="item_id"></UserValue> <UserValue value="Кронштейн правый в сборе" title="object_name"></UserValue> <UserValue value="Кронштейн правый в сборе" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:26" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id137" role="IMAN_master_form" formRef="#id135"></AssociatedForm></Product> <Product id="id157" name="63674Р-1001019_По умолчанию" accessRefs="#id16" subType="Деталь" productId=" 63674Р-1001019"> <Description>63674Р-1001019_По умолчанию</Description> <ApplicationRef version="SOB1M_ntwsW4BC" application="Teamcenter" label="SOB1M_ntwsW4BC"></ApplicationRef> <UserData id="id158"> <UserValue value=" 63674Р-1001019" title="item_id"></UserValue> <UserValue value="63674Р-1001019_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001019_По умолчанию" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id161" role="IMAN_master_form" formRef="#id159"></AssociatedForm></Product> <Product id="id177" name="Деталь1" accessRefs="#id16" subType="Деталь" productId="139"> <Description>Деталь1</Description> <ApplicationRef version="SaE1M_ntwsW4BC" application="Teamcenter" label="SaE1M_ntwsW4BC"></ApplicationRef> <UserData id="id178"> <UserValue value="139" title="item_id"></UserValue> <UserValue value="Деталь1" title="object_name"></UserValue> <UserValue value="Деталь1" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id181" role="IMAN_master_form" formRef="#id179"></AssociatedForm></Product> <Product id="id197" name="63674Р-1001017_По умолчанию" accessRefs="#id16" subType="Деталь" productId=" 63674Р-1001017"> <Description>63674Р-1001017_По умолчанию</Description> <ApplicationRef version="SmH1M_ntwsW4BC" application="Teamcenter" label="SmH1M_ntwsW4BC"></ApplicationRef> <UserData id="id198"> <UserValue value=" 63674Р-1001017" title="item_id"></UserValue> <UserValue value="63674Р-1001017_По умолчанию" title="object_name"></UserValue> <UserValue value="63674Р-1001017_По умолчанию" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id201" role="IMAN_master_form" formRef="#id199"></AssociatedForm></Product> <Product id="id217" name="Пакет подушек передней опоры_По" accessRefs="#id16" subType="Деталь" productId="134"> <Description>Пакет подушек передней опоры_По умолчанию.1</Description> <ApplicationRef version="SyK1M_ntwsW4BC" application="Teamcenter" label="SyK1M_ntwsW4BC"></ApplicationRef> <UserData id="id218"> <UserValue value="134" title="item_id"></UserValue> <UserValue value="Пакет подушек передней опоры_По" title="object_name"></UserValue> <UserValue value="Пакет подушек передней опоры_По умолчанию.1" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id221" role="IMAN_master_form" formRef="#id219"></AssociatedForm></Product> <Product id="id230" name="Кронштейн левый в сборе" accessRefs="#id16" subType="Сб_единица" productId="100"> <Description>Кронштейн левый в сборе</Description> <ApplicationRef version="SCG1M_ntwsW4BC" application="Teamcenter" label="SCG1M_ntwsW4BC"></ApplicationRef> <UserData id="id231"> <UserValue value="100" title="item_id"></UserValue> <UserValue value="Кронштейн левый в сборе" title="object_name"></UserValue> <UserValue value="Кронштейн левый в сборе" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:27" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id234" role="IMAN_master_form" formRef="#id232"></AssociatedForm></Product> <Product id="id250" name="ZF 16S2220TO" accessRefs="#id16" subType="Деталь" productId="ZF 16S2220TO"> <Description>ZF 16S2220TO</Description> <ApplicationRef version="S_N1M_ntwsW4BC" application="Teamcenter" label="S_N1M_ntwsW4BC"></ApplicationRef> <UserData id="id251"> <UserValue value="ZF 16S2220TO" title="item_id"></UserValue> <UserValue value="ZF 16S2220TO" title="object_name"></UserValue> <UserValue value="ZF 16S2220TO" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:28" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id254" role="IMAN_master_form" formRef="#id252"></AssociatedForm></Product> <Product id="id270" name="Кожух вентилятора на двигателе" accessRefs="#id16" subType="Деталь" productId="102"> <Description>Кожух вентилятора на двигателе</Description> <ApplicationRef version="iOA1M_ntwsW4BC" application="Teamcenter" label="iOA1M_ntwsW4BC"></ApplicationRef> <UserData id="id271"> <UserValue value="102" title="item_id"></UserValue> <UserValue value="Кожух вентилятора на двигателе" title="object_name"></UserValue> <UserValue value="Кожух вентилятора на двигателе" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id274" role="IMAN_master_form" formRef="#id272"></AssociatedForm></Product> <Product id="id290" name="Задний левый кронштейн двигателя" accessRefs="#id16" subType="Деталь" productId="103"> <Description>Задний левый кронштейн двигателя</Description> <ApplicationRef version="iaD1M_ntwsW4BC" application="Teamcenter" label="iaD1M_ntwsW4BC"></ApplicationRef> <UserData id="id291"> <UserValue value="103" title="item_id"></UserValue> <UserValue value="Задний левый кронштейн двигателя" title="object_name"></UserValue> <UserValue value="Задний левый кронштейн двигателя" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id294" role="IMAN_master_form" formRef="#id292"></AssociatedForm></Product> <Product id="id310" name="Symmetry of Задний левый кронште" accessRefs="#id16" subType="Деталь" productId="104"> <Description>Symmetry of Задний левый кронштейн двигателя</Description> <ApplicationRef version="imG1M_ntwsW4BC" application="Teamcenter" label="imG1M_ntwsW4BC"></ApplicationRef> <UserData id="id311"> <UserValue value="104" title="item_id"></UserValue> <UserValue value="Symmetry of Задний левый кронште" title="object_name"></UserValue> <UserValue value="Symmetry of Задний левый кронштейн двигателя" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id314" role="IMAN_master_form" formRef="#id312"></AssociatedForm></Product> <Product id="id330" name="Скоба правая" accessRefs="#id16" subType="Деталь" productId="106"> <Description>Скоба правая</Description> <ApplicationRef version="iyJ1M_ntwsW4BC" application="Teamcenter" label="iyJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id331"> <UserValue value="106" title="item_id"></UserValue> <UserValue value="Скоба правая" title="object_name"></UserValue> <UserValue value="Скоба правая" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id334" role="IMAN_master_form" formRef="#id332"></AssociatedForm></Product> <Product id="id350" name="6370-1109131" accessRefs="#id16" subType="Деталь" productId="6370-1109131"> <Description>6370-1109131</Description> <ApplicationRef version="i_M1M_ntwsW4BC" application="Teamcenter" label="i_M1M_ntwsW4BC"></ApplicationRef> <UserData id="id351"> <UserValue value="6370-1109131" title="item_id"></UserValue> <UserValue value="6370-1109131" title="object_name"></UserValue> <UserValue value="6370-1109131" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id354" role="IMAN_master_form" formRef="#id352"></AssociatedForm></Product> <Product id="id374" name="6370-1109047" accessRefs="#id16" subType="Деталь" productId="6370-1109047"> <Description>6370-1109047</Description> <ApplicationRef version="yWK1M_ntwsW4BC" application="Teamcenter" label="yWK1M_ntwsW4BC"></ApplicationRef> <UserData id="id375"> <UserValue value="6370-1109047" title="item_id"></UserValue> <UserValue value="6370-1109047" title="object_name"></UserValue> <UserValue value="6370-1109047" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id378" role="IMAN_master_form" formRef="#id376"></AssociatedForm></Product> <Product id="id394" name="6370-1109138" accessRefs="#id16" subType="Деталь" productId="6370-1109138"> <Description>6370-1109138</Description> <ApplicationRef version="yiN1M_ntwsW4BC" application="Teamcenter" label="yiN1M_ntwsW4BC"></ApplicationRef> <UserData id="id395"> <UserValue value="6370-1109138" title="item_id"></UserValue> <UserValue value="6370-1109138" title="object_name"></UserValue> <UserValue value="6370-1109138" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id398" role="IMAN_master_form" formRef="#id396"></AssociatedForm></Product> <Product id="id414" name="5323E-1109225" accessRefs="#id16" subType="Деталь" productId="5323E-1109225"> <Description>5323E-1109225</Description> <ApplicationRef version="yyA1M_ntwsW4BC" application="Teamcenter" label="yyA1M_ntwsW4BC"></ApplicationRef> <UserData id="id415"> <UserValue value="5323E-1109225" title="item_id"></UserValue> <UserValue value="5323E-1109225" title="object_name"></UserValue> <UserValue value="5323E-1109225" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id418" role="IMAN_master_form" formRef="#id416"></AssociatedForm></Product> <Product id="id427" name="6370-1109046" accessRefs="#id16" subType="Сб_единица" productId="6370-1109046"> <Description>6370-1109046</Description> <ApplicationRef version="yKP1M_ntwsW4BC" application="Teamcenter" label="yKP1M_ntwsW4BC"></ApplicationRef> <UserData id="id428"> <UserValue value="6370-1109046" title="item_id"></UserValue> <UserValue value="6370-1109046" title="object_name"></UserValue> <UserValue value="6370-1109046" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:29" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id431" role="IMAN_master_form" formRef="#id429"></AssociatedForm></Product> <Product id="id451" name="CHR-10816-12_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-12_AF0"> <Description>CHR-10816-12_AF0</Description> <ApplicationRef version="CHO1M_ntwsW4BC" application="Teamcenter" label="CHO1M_ntwsW4BC"></ApplicationRef> <UserData id="id452"> <UserValue value="CHR-10816-12_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-12_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-12_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id455" role="IMAN_master_form" formRef="#id453"></AssociatedForm></Product> <Product id="id471" name="CHR-10816-14_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-14_AF0"> <Description>CHR-10816-14_AF0</Description> <ApplicationRef version="CXB1M_ntwsW4BC" application="Teamcenter" label="CXB1M_ntwsW4BC"></ApplicationRef> <UserData id="id472"> <UserValue value="CHR-10816-14_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-14_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-14_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id475" role="IMAN_master_form" formRef="#id473"></AssociatedForm></Product> <Product id="id491" name="CHR-10816-16_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-16_AF0"> <Description>CHR-10816-16_AF0</Description> <ApplicationRef version="CjE1M_ntwsW4BC" application="Teamcenter" label="CjE1M_ntwsW4BC"></ApplicationRef> <UserData id="id492"> <UserValue value="CHR-10816-16_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-16_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-16_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id495" role="IMAN_master_form" formRef="#id493"></AssociatedForm></Product> <Product id="id511" name="CHR-10816-18_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-18_AF0"> <Description>CHR-10816-18_AF0</Description> <ApplicationRef version="CvH1M_ntwsW4BC" application="Teamcenter" label="CvH1M_ntwsW4BC"></ApplicationRef> <UserData id="id512"> <UserValue value="CHR-10816-18_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-18_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-18_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id515" role="IMAN_master_form" formRef="#id513"></AssociatedForm></Product> <Product id="id531" name="CHR-10816-20_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-20_AF0"> <Description>CHR-10816-20_AF0</Description> <ApplicationRef version="C7K1M_ntwsW4BC" application="Teamcenter" label="C7K1M_ntwsW4BC"></ApplicationRef> <UserData id="id532"> <UserValue value="CHR-10816-20_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-20_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-20_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id535" role="IMAN_master_form" formRef="#id533"></AssociatedForm></Product> <Product id="id551" name="CHR-10816-24_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-24_AF0"> <Description>CHR-10816-24_AF0</Description> <ApplicationRef version="SHN1M_ntwsW4BC" application="Teamcenter" label="SHN1M_ntwsW4BC"></ApplicationRef> <UserData id="id552"> <UserValue value="CHR-10816-24_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-24_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-24_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:31" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id555" role="IMAN_master_form" formRef="#id553"></AssociatedForm></Product> <Product id="id571" name="CHR-10816-22_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-22_AF0"> <Description>CHR-10816-22_AF0</Description> <ApplicationRef version="SXA1M_ntwsW4BC" application="Teamcenter" label="SXA1M_ntwsW4BC"></ApplicationRef> <UserData id="id572"> <UserValue value="CHR-10816-22_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-22_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-22_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id575" role="IMAN_master_form" formRef="#id573"></AssociatedForm></Product> <Product id="id591" name="CHR-10816-20_AF1" accessRefs="#id16" subType="Деталь" productId="CHR-10816-20_AF1"> <Description>CHR-10816-20_AF1</Description> <ApplicationRef version="SjD1M_ntwsW4BC" application="Teamcenter" label="SjD1M_ntwsW4BC"></ApplicationRef> <UserData id="id592"> <UserValue value="CHR-10816-20_AF1" title="item_id"></UserValue> <UserValue value="CHR-10816-20_AF1" title="object_name"></UserValue> <UserValue value="CHR-10816-20_AF1" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id595" role="IMAN_master_form" formRef="#id593"></AssociatedForm></Product> <Product id="id611" name="CHR-10816-24_AF1" accessRefs="#id16" subType="Деталь" productId="CHR-10816-24_AF1"> <Description>CHR-10816-24_AF1</Description> <ApplicationRef version="SvG1M_ntwsW4BC" application="Teamcenter" label="SvG1M_ntwsW4BC"></ApplicationRef> <UserData id="id612"> <UserValue value="CHR-10816-24_AF1" title="item_id"></UserValue> <UserValue value="CHR-10816-24_AF1" title="object_name"></UserValue> <UserValue value="CHR-10816-24_AF1" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id615" role="IMAN_master_form" formRef="#id613"></AssociatedForm></Product> <Product id="id631" name="CHR-10816-22_AF1" accessRefs="#id16" subType="Деталь" productId="CHR-10816-22_AF1"> <Description>CHR-10816-22_AF1</Description> <ApplicationRef version="S7J1M_ntwsW4BC" application="Teamcenter" label="S7J1M_ntwsW4BC"></ApplicationRef> <UserData id="id632"> <UserValue value="CHR-10816-22_AF1" title="item_id"></UserValue> <UserValue value="CHR-10816-22_AF1" title="object_name"></UserValue> <UserValue value="CHR-10816-22_AF1" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:32" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id635" role="IMAN_master_form" formRef="#id633"></AssociatedForm></Product> <Product id="id651" name="CHR-10816-26_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-26_AF0"> <Description>CHR-10816-26_AF0</Description> <ApplicationRef version="iHM1M_ntwsW4BC" application="Teamcenter" label="iHM1M_ntwsW4BC"></ApplicationRef> <UserData id="id652"> <UserValue value="CHR-10816-26_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-26_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-26_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id655" role="IMAN_master_form" formRef="#id653"></AssociatedForm></Product> <Product id="id671" name="850-1009073_AF0" accessRefs="#id16" subType="Деталь" productId="850-1009073_AF0"> <Description>850-1009073_AF0</Description> <ApplicationRef version="iTP1M_ntwsW4BC" application="Teamcenter" label="iTP1M_ntwsW4BC"></ApplicationRef> <UserData id="id672"> <UserValue value="850-1009073_AF0" title="item_id"></UserValue> <UserValue value="850-1009073_AF0" title="object_name"></UserValue> <UserValue value="850-1009073_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id675" role="IMAN_master_form" formRef="#id673"></AssociatedForm></Product> <Product id="id691" name="236-1009024-B" accessRefs="#id16" subType="Деталь" productId="236-1009024-B"> <Description>236-1009024-B</Description> <ApplicationRef version="ijC1M_ntwsW4BC" application="Teamcenter" label="ijC1M_ntwsW4BC"></ApplicationRef> <UserData id="id692"> <UserValue value="236-1009024-B" title="item_id"></UserValue> <UserValue value="236-1009024-B" title="object_name"></UserValue> <UserValue value="236-1009024-B" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id695" role="IMAN_master_form" formRef="#id693"></AssociatedForm></Product> <Product id="id711" name="201-1009042-B" accessRefs="#id16" subType="Деталь" productId="201-1009042-B"> <Description>201-1009042-B</Description> <ApplicationRef version="ivF1M_ntwsW4BC" application="Teamcenter" label="ivF1M_ntwsW4BC"></ApplicationRef> <UserData id="id712"> <UserValue value="201-1009042-B" title="item_id"></UserValue> <UserValue value="201-1009042-B" title="object_name"></UserValue> <UserValue value="201-1009042-B" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id715" role="IMAN_master_form" formRef="#id713"></AssociatedForm></Product> <Product id="id731" name="316180-P2" accessRefs="#id16" subType="Деталь" productId="316180-P2"> <Description>316180-P2</Description> <ApplicationRef version="i7I1M_ntwsW4BC" application="Teamcenter" label="i7I1M_ntwsW4BC"></ApplicationRef> <UserData id="id732"> <UserValue value="316180-P2" title="item_id"></UserValue> <UserValue value="316180-P2" title="object_name"></UserValue> <UserValue value="316180-P2" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:33" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id735" role="IMAN_master_form" formRef="#id733"></AssociatedForm></Product> <Product id="id751" name="CHR-10816-28_AF0" accessRefs="#id16" subType="Деталь" productId="CHR-10816-28_AF0"> <Description>CHR-10816-28_AF0</Description> <ApplicationRef version="yHL1M_ntwsW4BC" application="Teamcenter" label="yHL1M_ntwsW4BC"></ApplicationRef> <UserData id="id752"> <UserValue value="CHR-10816-28_AF0" title="item_id"></UserValue> <UserValue value="CHR-10816-28_AF0" title="object_name"></UserValue> <UserValue value="CHR-10816-28_AF0" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id755" role="IMAN_master_form" formRef="#id753"></AssociatedForm></Product> <Product id="id764" name="Картер масляный (new)" accessRefs="#id16" subType="Сб_единица" productId="Karter new"> <Description>Картер масляный (new)</Description> <ApplicationRef version="y_D1M_ntwsW4BC" application="Teamcenter" label="y_D1M_ntwsW4BC"></ApplicationRef> <UserData id="id765"> <UserValue value="Karter new" title="item_id"></UserValue> <UserValue value="Картер масляный (new)" title="object_name"></UserValue> <UserValue value="Картер масляный (new)" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:30" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id768" role="IMAN_master_form" formRef="#id766"></AssociatedForm></Product> <Product id="id784" name="651-C_SW0001" accessRefs="#id16" subType="Деталь" productId="651-C_SW0001"> <Description>651-C_SW0001</Description> <ApplicationRef version="yTO1M_ntwsW4BC" application="Teamcenter" label="yTO1M_ntwsW4BC"></ApplicationRef> <UserData id="id785"> <UserValue value="651-C_SW0001" title="item_id"></UserValue> <UserValue value="651-C_SW0001" title="object_name"></UserValue> <UserValue value="651-C_SW0001" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id788" role="IMAN_master_form" formRef="#id786"></AssociatedForm></Product> <Product id="id804" name="Центр шарнира управления КПП" accessRefs="#id16" subType="Деталь" productId="110"> <Description>Центр шарнира управления КПП</Description> <ApplicationRef version="yjB1M_ntwsW4BC" application="Teamcenter" label="yjB1M_ntwsW4BC"></ApplicationRef> <UserData id="id805"> <UserValue value="110" title="item_id"></UserValue> <UserValue value="Центр шарнира управления КПП" title="object_name"></UserValue> <UserValue value="Центр шарнира управления КПП" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id808" role="IMAN_master_form" formRef="#id806"></AssociatedForm></Product> <Product id="id824" name="6370-1109131-99" accessRefs="#id16" subType="Деталь" productId="6370-1109131-99"> <Description>6370-1109131-99</Description> <ApplicationRef version="yvE1M_ntwsW4BC" application="Teamcenter" label="yvE1M_ntwsW4BC"></ApplicationRef> <UserData id="id825"> <UserValue value="6370-1109131-99" title="item_id"></UserValue> <UserValue value="6370-1109131-99" title="object_name"></UserValue> <UserValue value="6370-1109131-99" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id828" role="IMAN_master_form" formRef="#id826"></AssociatedForm></Product> <Product id="id844" name="63674P-1308005" accessRefs="#id16" subType="Деталь" productId="63674P-1308005"> <Description>63674P-1308005</Description> <ApplicationRef version="y7H1M_ntwsW4BC" application="Teamcenter" label="y7H1M_ntwsW4BC"></ApplicationRef> <UserData id="id845"> <UserValue value="63674P-1308005" title="item_id"></UserValue> <UserValue value="63674P-1308005" title="object_name"></UserValue> <UserValue value="63674P-1308005" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:34" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id848" role="IMAN_master_form" formRef="#id846"></AssociatedForm></Product> <Product id="id864" name="6370-1109131-98" accessRefs="#id16" subType="Деталь" productId="6370-1109131-98"> <Description>6370-1109131-98</Description> <ApplicationRef version="DEK1M_ntwsW4BC" application="Teamcenter" label="DEK1M_ntwsW4BC"></ApplicationRef> <UserData id="id865"> <UserValue value="6370-1109131-98" title="item_id"></UserValue> <UserValue value="6370-1109131-98" title="object_name"></UserValue> <UserValue value="6370-1109131-98" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id868" role="IMAN_master_form" formRef="#id866"></AssociatedForm></Product> <Product id="id884" name="Компрессор кондиционера" accessRefs="#id16" subType="Деталь" productId="114"> <Description>Компрессор кондиционера</Description> <ApplicationRef version="DQN1M_ntwsW4BC" application="Teamcenter" label="DQN1M_ntwsW4BC"></ApplicationRef> <UserData id="id885"> <UserValue value="114" title="item_id"></UserValue> <UserValue value="Компрессор кондиционера" title="object_name"></UserValue> <UserValue value="Компрессор кондиционера" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id888" role="IMAN_master_form" formRef="#id886"></AssociatedForm></Product> <Product id="id904" name="tub-adm.IGS" accessRefs="#id16" subType="Деталь" productId="115"> <Description>tub-adm.IGS</Description> <ApplicationRef version="DgA1M_ntwsW4BC" application="Teamcenter" label="DgA1M_ntwsW4BC"></ApplicationRef> <UserData id="id905"> <UserValue value="115" title="item_id"></UserValue> <UserValue value="tub-adm.IGS" title="object_name"></UserValue> <UserValue value="tub-adm.IGS" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id908" role="IMAN_master_form" formRef="#id906"></AssociatedForm></Product> <Product id="id924" name="КОМ ZF N71/4c" accessRefs="#id16" subType="Деталь" productId="116"> <Description>КОМ ZF N71/4c</Description> <ApplicationRef version="DsD1M_ntwsW4BC" application="Teamcenter" label="DsD1M_ntwsW4BC"></ApplicationRef> <UserData id="id925"> <UserValue value="116" title="item_id"></UserValue> <UserValue value="КОМ ZF N71/4c" title="object_name"></UserValue> <UserValue value="КОМ ZF N71/4c" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id928" role="IMAN_master_form" formRef="#id926"></AssociatedForm></Product> <Product id="id944" name="Насос HYVA-061L" accessRefs="#id16" subType="Деталь" productId="117"> <Description>Насос HYVA-061L</Description> <ApplicationRef version="D4G1M_ntwsW4BC" application="Teamcenter" label="D4G1M_ntwsW4BC"></ApplicationRef> <UserData id="id945"> <UserValue value="117" title="item_id"></UserValue> <UserValue value="Насос HYVA-061L" title="object_name"></UserValue> <UserValue value="Насос HYVA-061L" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id948" role="IMAN_master_form" formRef="#id946"></AssociatedForm></Product> <Product id="id968" name="Kricshka Kompressora Kondicioner" accessRefs="#id16" subType="Деталь" productId="161"> <Description>Kricshka Kompressora Kondicionera</Description> <ApplicationRef version="TQE1M_ntwsW4BC" application="Teamcenter" label="TQE1M_ntwsW4BC"></ApplicationRef> <UserData id="id969"> <UserValue value="161" title="item_id"></UserValue> <UserValue value="Kricshka Kompressora Kondicioner" title="object_name"></UserValue> <UserValue value="Kricshka Kompressora Kondicionera" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id972" role="IMAN_master_form" formRef="#id970"></AssociatedForm></Product> <Product id="id988" name="Trubka Kompressora 2" accessRefs="#id16" subType="Деталь" productId="162"> <Description>Trubka Kompressora 2</Description> <ApplicationRef version="TcH1M_ntwsW4BC" application="Teamcenter" label="TcH1M_ntwsW4BC"></ApplicationRef> <UserData id="id989"> <UserValue value="162" title="item_id"></UserValue> <UserValue value="Trubka Kompressora 2" title="object_name"></UserValue> <UserValue value="Trubka Kompressora 2" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id992" role="IMAN_master_form" formRef="#id990"></AssociatedForm></Product> <Product id="id1008" name="Trubka Kompressora 1" accessRefs="#id16" subType="Деталь" productId="163"> <Description>Trubka Kompressora 1</Description> <ApplicationRef version="ToK1M_ntwsW4BC" application="Teamcenter" label="ToK1M_ntwsW4BC"></ApplicationRef> <UserData id="id1009"> <UserValue value="163" title="item_id"></UserValue> <UserValue value="Trubka Kompressora 1" title="object_name"></UserValue> <UserValue value="Trubka Kompressora 1" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id1012" role="IMAN_master_form" formRef="#id1010"></AssociatedForm></Product> <Product id="id1028" name="Pimpka Kompressora" accessRefs="#id16" subType="Деталь" productId="164"> <Description>Pimpka Kompressora</Description> <ApplicationRef version="T0N1M_ntwsW4BC" application="Teamcenter" label="T0N1M_ntwsW4BC"></ApplicationRef> <UserData id="id1029"> <UserValue value="164" title="item_id"></UserValue> <UserValue value="Pimpka Kompressora" title="object_name"></UserValue> <UserValue value="Pimpka Kompressora" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:36" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id1032" role="IMAN_master_form" formRef="#id1030"></AssociatedForm></Product> <Product id="id1045" name="Kricshka Kompressora (Sborka)" accessRefs="#id16" subType="Сб_единица" productId="118"> <Description>Kricshka Kompressora (Sborka)</Description> <ApplicationRef version="TEJ1M_ntwsW4BC" application="Teamcenter" label="TEJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id1046"> <UserValue value="118" title="item_id"></UserValue> <UserValue value="Kricshka Kompressora (Sborka)" title="object_name"></UserValue> <UserValue value="Kricshka Kompressora (Sborka)" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:35" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id1049" role="IMAN_master_form" formRef="#id1047"></AssociatedForm></Product> <Product id="id1058" name="Силовой агрегат" accessRefs="#id16" subType="Сб_установка" productId="6370-1000250-10"> <Description>Силовой агрегат</Description> <ApplicationRef version="ipN1M_ntwsW4BC" application="Teamcenter" label="ipN1M_ntwsW4BC"></ApplicationRef> <UserData id="id1059"> <UserValue value="6370-1000250-10" title="item_id"></UserValue> <UserValue value="Силовой агрегат" title="object_name"></UserValue> <UserValue value="Силовой агрегат" title="object_desc"></UserValue> <UserValue type="int" value="0" title="revision_number"></UserValue> <UserValue value="2011-05-10T10:07:25" title="creation_date"></UserValue> <UserValue type="reference" value="" title="last_mod_user" dataRef="#id13"></UserValue></UserData> <AssociatedForm id="id1062" role="IMAN_master_form" formRef="#id1060"></AssociatedForm></Product> <RevisionRule id="id2" name="Latest Working"> <Description>Latest Working else Latest Any Status</Description> <ApplicationRef version="QYM1B0xuwsW4BC" application="Teamcenter" label="QYM1B0xuwsW4BC"></ApplicationRef></RevisionRule> <ProductView id="id4" ruleRefs="#id2" rootRefs="id6" primaryOccurrenceRef="id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/QYM1B0xuwsW4BC/AAAAAAAAAAAAAA/BOM"></ApplicationRef> <UserData id="id3" type="TC Specific Properties"> <UserValue value="imprecise" title="BOM_precision_type"></UserValue></UserData> <Occurrence id="id6" instancedRef="#id1050" occurrenceRefs="id9 id42 id139 id236 id256 id276 id296 id316 id336 id356 id433 id770 id790 id810 id830 id850 id870 id890 id910 id930 id950"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/"></ApplicationRef> <UserData id="id7" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <Transform id="id5">1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</Transform></Occurrence> <Occurrence id="id9" instancedRef="#id12" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jID1M_ntwsW4BC/"></ApplicationRef> <UserData id="id10" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="10" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id11" type="InstanceNotes"> <UserValue value="333.1" title="catiaOccurrenceName"></UserValue> <UserValue value="333_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="333.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id8">0.9748401599588861 -0.222904821125868 0.000321325657958303 0 0.0175595384791565 0.07823085386386411 0.9967806158388751 0 -0.222212342455887 -0.971696132658031 0.08017668387812101 0 -0.7138332678052011 -5.69315553701073 2.56188567248486 1</Transform></Occurrence> <Occurrence id="id42" instancedRef="#id125" occurrenceRefs="id46 id66 id86 id106" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jML1M_ntwsW4BC/"></ApplicationRef> <UserData id="id43" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="20" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id44" type="InstanceNotes"> <UserValue value="Кронштейн правый в сборе.1" title="catiaOccurrenceName"></UserValue> <UserValue value="99_0.CATProduct" title="catiaFileName"></UserValue> <UserValue value="Кронштейн правый в сборе.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id41">0.0175592732905735 0.0782308953538747 0.9967806172541891 0 -0.153662056971622 -0.984879369249663 0.0800037516222894 0 0.987967430722673 -0.154572167735727 -0.00527264570409445 0 -1.32630695476508 -5.60493660111401 2.99212378904363 1</Transform></Occurrence> <Occurrence id="id46" instancedRef="#id49" parentRef="#id42"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jQB1M_ntwsW4BC/jML1M_ntwsW4BC/"></ApplicationRef> <UserData id="id47" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="10" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id48" type="InstanceNotes"> <UserValue value="NAUO2" title="catiaOccurrenceName"></UserValue> <UserValue value="NAUO3" title="catiaParentPartName"></UserValue> <UserValue value="63674_-1001018_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO2" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id45">-0.01755927329055751 -0.07823089535387706 -0.9967806172541892 0 0.9879674307226734 -0.1545721677357257 -0.005272645704078345 0 -0.1536620569716219 -0.984879369249663 0.08000375162228926 0 -1.254544528575941 -5.59676923049508 3.018010535641152 1</Transform></Occurrence> <Occurrence id="id66" instancedRef="#id69" parentRef="#id42"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jQH1M_ntwsW4BC/jML1M_ntwsW4BC/"></ApplicationRef> <UserData id="id67" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="20" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id68" type="InstanceNotes"> <UserValue value="NAUO4" title="catiaOccurrenceName"></UserValue> <UserValue value="NAUO3" title="catiaParentPartName"></UserValue> <UserValue value="128_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO4" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id65">0.0175592732905735 0.0782308953538747 0.9967806172541891 0 -0.153662056971622 -0.984879369249663 0.0800037516222894 0 0.987967430722673 -0.154572167735727 -0.00527264570409445 0 -1.32630695476508 -5.60493660111401 2.99212378904363 1</Transform></Occurrence> <Occurrence id="id86" instancedRef="#id89" parentRef="#id42"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jQN1M_ntwsW4BC/jML1M_ntwsW4BC/"></ApplicationRef> <UserData id="id87" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="30" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id88" type="InstanceNotes"> <UserValue value="NAUO5" title="catiaOccurrenceName"></UserValue> <UserValue value="NAUO3" title="catiaParentPartName"></UserValue> <UserValue value=" 63674_-1001016_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO5" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id85">-0.01755927329054629 -0.07823089535387882 -0.9967806172541892 0 0.9879674307226735 -0.1545721677357248 -0.005272645704067026 0 -0.1536620569716219 -0.984879369249663 0.08000375162228926 0 -1.391872001446394 -5.575283699179814 3.018743433394018 1</Transform></Occurrence> <Occurrence id="id106" instancedRef="#id109" parentRef="#id42"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jUD1M_ntwsW4BC/jML1M_ntwsW4BC/"></ApplicationRef> <UserData id="id107" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="40" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id108" type="InstanceNotes"> <UserValue value="NAUO1" title="catiaOccurrenceName"></UserValue> <UserValue value="123_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id105">0.5091904921029667 -0.009536141130605969 0.8606010136900143 0 -0.153662056971622 -0.984879369249663 0.0800037516222894 0 0.8468252564721909 -0.1729788716541064 -0.5029565537519952 0 -1.340151948948911 -5.693674506929983 2.999332149374898 1</Transform></Occurrence> <Occurrence id="id139" instancedRef="#id222" occurrenceRefs="id143 id163 id183 id203" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jYH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id140" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="30" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id141" type="InstanceNotes"> <UserValue value="Кронштейн левый в сборе.1" title="catiaOccurrenceName"></UserValue> <UserValue value="100_0.CATProduct" title="catiaFileName"></UserValue> <UserValue value="Кронштейн левый в сборе.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id138">-0.0175592732905736 -0.0782308953538742 -0.9967806172541911 0 -0.153662056971623 -0.984879369249667 0.0800037516222894 0 -0.987967430722679 0.154572167735729 0.00527264570409469 0 -1.34096894796265 -5.670259398734499 2.15981197363638 1</Transform></Occurrence> <Occurrence id="id143" instancedRef="#id146" parentRef="#id139"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jYN1M_ntwsW4BC/jYH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id144" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="10" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id145" type="InstanceNotes"> <UserValue value="NAUO2" title="catiaOccurrenceName"></UserValue> <UserValue value="NAUO3" title="catiaParentPartName"></UserValue> <UserValue value=" 63674_-1001019_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO2" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id142">-0.01755927329057355 -0.07823089535387422 -0.9967806172541911 0 0.987967430722679 -0.154572167735729 -0.005272645704094634 0 -0.153662056971623 -0.984879369249667 0.0800037516222894 0 -1.262682300835375 -5.57828971984668 2.089392865230299 1</Transform></Occurrence> <Occurrence id="id163" instancedRef="#id166" parentRef="#id139"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jcD1M_ntwsW4BC/jYH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id164" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="20" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id165" type="InstanceNotes"> <UserValue value="NAUO4" title="catiaOccurrenceName"></UserValue> <UserValue value="NAUO3" title="catiaParentPartName"></UserValue> <UserValue value="139_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO4" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id162">-0.0175592732905736 -0.0782308953538742 -0.9967806172541911 0 -0.153662056971623 -0.984879369249667 0.0800037516222894 0 -0.987967430722679 0.154572167735729 0.00527264570409469 0 -1.34096894796265 -5.670259398734499 2.15981197363638 1</Transform></Occurrence> <Occurrence id="id183" instancedRef="#id186" parentRef="#id139"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jcJ1M_ntwsW4BC/jYH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id184" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="30" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id185" type="InstanceNotes"> <UserValue value="NAUO5" title="catiaOccurrenceName"></UserValue> <UserValue value="NAUO3" title="catiaParentPartName"></UserValue> <UserValue value=" 63674_-1001017_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO5" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id182">-0.01755927329057337 -0.07823089535387322 -0.9967806172541912 0 0.987967430722679 -0.154572167735729 -0.005272645704094615 0 -0.153662056971623 -0.9848793692496671 0.08000375162228839 0 -1.386171899075403 -5.546630010224787 2.108849693062673 1</Transform></Occurrence> <Occurrence id="id203" instancedRef="#id206" parentRef="#id139"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jcP1M_ntwsW4BC/jYH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id204" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="40" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id205" type="InstanceNotes"> <UserValue value="NAUO1" title="catiaOccurrenceName"></UserValue> <UserValue value="134_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="NAUO1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id202">-0.5091904921029699 0.009536141130607453 -0.860601013690016 0 -0.153662056971623 -0.984879369249667 0.08000375162228936 0 -0.8468252564721961 0.1729788716541079 0.5029565537519964 0 -1.354813942146481 -5.758997304550473 2.167020333967648 1</Transform></Occurrence> <Occurrence id="id236" instancedRef="#id239" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jgF1M_ntwsW4BC/"></ApplicationRef> <UserData id="id237" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="40" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id238" type="InstanceNotes"> <UserValue value="ZF 16S2220TO.1" title="catiaOccurrenceName"></UserValue> <UserValue value="ZF 16S2220TO_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="ZF 16S2220TO.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id235">-0.0175592732905731 -0.0782308953538739 -0.9967806172541881 0 0.987967430722673 -0.15457216773573 -0.00527264570409403 0 -0.153662056971623 -0.984879369249662 0.08000375162228859 0 -0.204121453106917 -5.594978849245769 2.54520120844825 1</Transform></Occurrence> <Occurrence id="id256" instancedRef="#id259" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jgL1M_ntwsW4BC/"></ApplicationRef> <UserData id="id257" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="50" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id258" type="InstanceNotes"> <UserValue value="Кожух вентилятора на двигателе.1" title="catiaOccurrenceName"></UserValue> <UserValue value="102_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Кожух вентилятора на двигателе.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id255">0.017559273290574 0.0782308953538742 0.9967806172541941 0 -0.987967430722659 0.154572167735728 0.00527264570409395 0 -0.153662056971622 -0.984879369249653 0.08000375162228909 0 -1.54654463705649 -5.61700212625882 2.57057778158789 1</Transform></Occurrence> <Occurrence id="id276" instancedRef="#id279" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jkB1M_ntwsW4BC/"></ApplicationRef> <UserData id="id277" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="60" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id278" type="InstanceNotes"> <UserValue value="Задний левый кронштейн двигателя.1" title="catiaOccurrenceName"></UserValue> <UserValue value="103_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Задний левый кронштейн двигателя.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id275">-0.0175592732905731 -0.0782308953538739 -0.9967806172541881 0 0.982002859207286 -0.18884980084701 -0.00247734308486544 0 -0.188048016288985 -0.978884916490277 0.080139028179793 0 -0.254702120286342 -5.70215493807151 2.27861560851513 1</Transform></Occurrence> <Occurrence id="id296" instancedRef="#id299" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jkH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id297" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="70" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id298" type="InstanceNotes"> <UserValue value="Symmetry of Задний левый кронштейн двигателя.1.1" title="catiaOccurrenceName"></UserValue> <UserValue value="104_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Symmetry of Задний левый кронштейн двигателя.1.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id295">0.017559273290573 0.0782308953538732 0.9967806172541881 0 -0.982002859207286 0.18884980084701 0.0024773430848655 0 -0.188048016288985 -0.978884916490277 0.0801390281797925 0 -0.245044519976527 -5.65912794562688 2.82684494800493 1</Transform></Occurrence> <Occurrence id="id316" instancedRef="#id319" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jkN1M_ntwsW4BC/"></ApplicationRef> <UserData id="id317" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="80" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id318" type="InstanceNotes"> <UserValue value="Скоба правая.1" title="catiaOccurrenceName"></UserValue> <UserValue value="106_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Скоба правая.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id315">-0.0175592732905739 -0.0782308953538739 -0.9967806172541861 0 0.9820028592072799 -0.188849800847035 -0.0024773430848634 0 -0.188048016289011 -0.978884916490278 0.0801390281797935 0 -1.32077512071429 -5.56948094382061 2.98924365398512 1</Transform></Occurrence> <Occurrence id="id336" instancedRef="#id339" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/joD1M_ntwsW4BC/"></ApplicationRef> <UserData id="id337" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="90" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id338" type="InstanceNotes"> <UserValue value="6370-1109131.1" title="catiaOccurrenceName"></UserValue> <UserValue value="6370-1109131_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="6370-1109131.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id335">0.143881497521726 0.9310727693814981 -0.335263497546589 0 -0.05673162844976851 -0.330470779182401 -0.942109646718477 0 -0.9879674270968371 0.154572190975102 0.0052726438163126 0 -1.34510337585249 -5.977419300268119 2.42416501893221 1</Transform></Occurrence> <Occurrence id="id356" instancedRef="#id419" occurrenceRefs="id360 id380 id400" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jsH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id357" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="100" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id358" type="InstanceNotes"> <UserValue value="6370-1109046.1" title="catiaOccurrenceName"></UserValue> <UserValue value="6370-1109046_0.CATProduct" title="catiaFileName"></UserValue> <UserValue value="6370-1109046.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id355">-0.003997240563117469 -0.05959915772445611 0.9982143870263631 0 -0.9879674270968381 0.154572190975102 0.00527264381631296 0 -0.154610429995966 -0.986182223615744 -0.0594998887458647 0 -1.11903372554731 -5.88889151263779 2.91073625109923 1</Transform></Occurrence> <Occurrence id="id360" instancedRef="#id363" parentRef="#id356"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jsN1M_ntwsW4BC/jsH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id361" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="10" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id362" type="InstanceNotes"> <UserValue value="6370-1109047.1" title="catiaOccurrenceName"></UserValue> <UserValue value="6370-1109047_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="6370-1109047.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id359">-0.003997240563117469 -0.05959915772445611 0.9982143870263631 0 -0.9879674270968381 0.154572190975102 0.00527264381631296 0 -0.154610429995966 -0.986182223615744 -0.0594998887458647 0 -1.11903372554731 -5.88889151263779 2.91073625109923 1</Transform></Occurrence> <Occurrence id="id380" instancedRef="#id383" parentRef="#id356"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jwD1M_ntwsW4BC/jsH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id381" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="20" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id382" type="InstanceNotes"> <UserValue value="6370-1109138.1" title="catiaOccurrenceName"></UserValue> <UserValue value="6370-1109138_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="6370-1109138.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id379">-0.003997240563117469 -0.05959915772445611 0.9982143870263631 0 -0.9879674270968381 0.154572190975102 0.00527264381631296 0 -0.154610429995966 -0.986182223615744 -0.0594998887458647 0 -1.075563158755049 -5.895692689040694 2.910504254771312 1</Transform></Occurrence> <Occurrence id="id400" instancedRef="#id403" parentRef="#id356"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/jwJ1M_ntwsW4BC/jsH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id401" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="30" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id402" type="InstanceNotes"> <UserValue value="5323E-1109225.1" title="catiaOccurrenceName"></UserValue> <UserValue value="5323E-1109225_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="5323E-1109225.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id399">-0.003997240563117469 -0.05959915772445611 0.9982143870263631 0 -0.9879674270968381 0.154572190975102 0.00527264381631296 0 -0.154610429995966 -0.986182223615744 -0.0594998887458647 0 -1.619832477026118 -6.035852074363853 2.899956463790202 1</Transform></Occurrence> <Occurrence id="id433" instancedRef="#id756" occurrenceRefs="id437 id457 id477 id497 id517 id537 id557 id577 id597 id617 id637 id657 id677 id697 id717 id737" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id434" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="110" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id435" type="InstanceNotes"> <UserValue value="Картер масляный (new).1" title="catiaOccurrenceName"></UserValue> <UserValue value="Karter new_0.CATProduct" title="catiaFileName"></UserValue> <UserValue value="Картер масляный (new).1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id432">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id437" instancedRef="#id440" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/j4D1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id438" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="10" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id439" type="InstanceNotes"> <UserValue value="0" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-12_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="0" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id436">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id457" instancedRef="#id460" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/j4J1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id458" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="20" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id459" type="InstanceNotes"> <UserValue value="1" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-14_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id456">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id477" instancedRef="#id480" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/j4P1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id478" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="30" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id479" type="InstanceNotes"> <UserValue value="2" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-16_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="2" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id476">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id497" instancedRef="#id500" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/j8F1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id498" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="40" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id499" type="InstanceNotes"> <UserValue value="3" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-18_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="3" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id496">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id517" instancedRef="#id520" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/j8L1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id518" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="50" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id519" type="InstanceNotes"> <UserValue value="4" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-20_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="4" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id516">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id537" instancedRef="#id540" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zAB1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id538" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="60" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id539" type="InstanceNotes"> <UserValue value="5" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-24_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="5" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id536">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id557" instancedRef="#id560" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zAH1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id558" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="70" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id559" type="InstanceNotes"> <UserValue value="6" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-22_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="6" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id556">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id577" instancedRef="#id580" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zAN1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id578" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="80" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id579" type="InstanceNotes"> <UserValue value="7" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-20_AF1_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="7" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id576">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 0.153662056971623 0.9848793692496599 -0.0800037516222888 0 0.0175592732905731 0.0782308953538737 0.9967806172541871 0 -1.306682162253047 -5.313332545403405 2.388021910416817 1</Transform></Occurrence> <Occurrence id="id597" instancedRef="#id600" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zED1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id598" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="90" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id599" type="InstanceNotes"> <UserValue value="8" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-24_AF1_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="8" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id596">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 0.153662056971623 0.9848793692496599 -0.0800037516222888 0 0.0175592732905731 0.0782308953538737 0.9967806172541871 0 -1.306682162253047 -5.313332545403405 2.388021910416817 1</Transform></Occurrence> <Occurrence id="id617" instancedRef="#id620" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zEJ1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id618" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="100" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id619" type="InstanceNotes"> <UserValue value="9" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-22_AF1_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="9" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id616">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 0.153662056971623 0.9848793692496599 -0.0800037516222888 0 0.0175592732905731 0.0782308953538737 0.9967806172541871 0 -1.306682162253047 -5.313332545403405 2.388021910416817 1</Transform></Occurrence> <Occurrence id="id637" instancedRef="#id640" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zEP1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id638" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="110" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id639" type="InstanceNotes"> <UserValue value="10" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-26_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="10" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id636">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id657" instancedRef="#id660" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zIF1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id658" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="120" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id659" type="InstanceNotes"> <UserValue value="11" title="catiaOccurrenceName"></UserValue> <UserValue value="850-1009073_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="11" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id656">0.0175592732905731 0.0782308953538737 0.9967806172541871 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.9764991756238076 -5.295723158803858 2.670255155879117 1</Transform></Occurrence> <Occurrence id="id677" instancedRef="#id680" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zIL1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id678" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="130" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id679" type="InstanceNotes"> <UserValue value="12" title="catiaOccurrenceName"></UserValue> <UserValue value="236-1009024-B_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="12" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id676">-0.2391843616881381 -0.9676597538193293 0.08015885454615855 0 -0.9708153856657527 0.239821866914686 -0.001720204699905521 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.000547546399841 -4.990858668639326 2.511817534421786 1</Transform></Occurrence> <Occurrence id="id697" instancedRef="#id700" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zMB1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id698" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="140" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id699" type="InstanceNotes"> <UserValue value="13" title="catiaOccurrenceName"></UserValue> <UserValue value="201-1009042-B_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="13" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id696">-0.9708153856657527 0.239821866914686 -0.001720204699905521 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -0.2391843616881381 -0.9676597538193293 0.08015885454615855 0 -1.000547546399841 -4.990858668639326 2.511817534421786 1</Transform></Occurrence> <Occurrence id="id717" instancedRef="#id720" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zMH1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id718" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="150" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id719" type="InstanceNotes"> <UserValue value="14" title="catiaOccurrenceName"></UserValue> <UserValue value="316180-P2_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="14" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id716">0.2391843616881381 0.9676597538193293 -0.08015885454615855 0 0.9708153856657527 -0.239821866914686 0.001720204699905521 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -0.9999495854955951 -4.988439519254812 2.511617137285423 1</Transform></Occurrence> <Occurrence id="id737" instancedRef="#id740" parentRef="#id433"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zMN1M_ntwsW4BC/j0N1M_ntwsW4BC/"></ApplicationRef> <UserData id="id738" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="160" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id739" type="InstanceNotes"> <UserValue value="15" title="catiaOccurrenceName"></UserValue> <UserValue value="CHR-10816-28_AF0_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="15" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id736">0.987967430722671 -0.154572167735729 -0.00527264570409402 0 -0.153662056971623 -0.9848793692496599 0.0800037516222888 0 -0.0175592732905731 -0.0782308953538737 -0.9967806172541871 0 -1.30219587842138 -5.29514670584991 2.69551036304084 1</Transform></Occurrence> <Occurrence id="id770" instancedRef="#id773" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zQD1M_ntwsW4BC/"></ApplicationRef> <UserData id="id771" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="120" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id772" type="InstanceNotes"> <UserValue value="651-C_SW0001.1" title="catiaOccurrenceName"></UserValue> <UserValue value="651-C_SW0001_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="651-C_SW0001.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id769">-0.987967430722671 0.154572167735729 0.00527264570409402 0 -0.0175592732905733 -0.0782308953538738 -0.9967806172541871 0 -0.153662056971623 -0.9848793692496599 0.0800037516222892 0 -1.17924530723019 -5.44241611969061 2.55040530975819 1</Transform></Occurrence> <Occurrence id="id790" instancedRef="#id793" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zQJ1M_ntwsW4BC/"></ApplicationRef> <UserData id="id791" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="130" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id792" type="InstanceNotes"> <UserValue value="Центр шарнира управления КПП.1" title="catiaOccurrenceName"></UserValue> <UserValue value="110_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Центр шарнира управления КПП.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id789">0.987967430722672 -0.154572167735729 -0.00527264570409402 0 0.153662056971623 0.9848793692496599 -0.0800037516222889 0 0.0175592732905731 0.0782308953538738 0.9967806172541871 0 -0.361787928771427 -6.14183782507517 2.30999376169889 1</Transform></Occurrence> <Occurrence id="id810" instancedRef="#id813" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zQP1M_ntwsW4BC/"></ApplicationRef> <UserData id="id811" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="140" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id812" type="InstanceNotes"> <UserValue value="6370-1109131-99.1" title="catiaOccurrenceName"></UserValue> <UserValue value="6370-1109131-99_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="6370-1109131-99.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id809">0.143881497521726 0.9310727693814971 -0.335263497546595 0 -0.0567316284497692 -0.330470779182406 -0.942109646718477 0 -0.9879674270968371 0.154572190975102 0.00527264381631256 0 -1.34510337585249 -5.97741930026813 2.42416501893221 1</Transform></Occurrence> <Occurrence id="id830" instancedRef="#id833" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zUF1M_ntwsW4BC/"></ApplicationRef> <UserData id="id831" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="150" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id832" type="InstanceNotes"> <UserValue value="63674P-1308005.1" title="catiaOccurrenceName"></UserValue> <UserValue value="63674P-1308005_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="63674P-1308005.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id829">-0.06905584625992181 -0.410361576863318 -0.909304495937185 0 0.9879674270968371 -0.154572190975102 -0.005272643816313 0 -0.138389497769821 -0.8987273301794091 0.41609798472909 0 -1.47019948087446 -5.9087958031559 2.38658210487439 1</Transform></Occurrence> <Occurrence id="id850" instancedRef="#id853" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zUL1M_ntwsW4BC/"></ApplicationRef> <UserData id="id851" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="160" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id852" type="InstanceNotes"> <UserValue value="6370-1109131-98.1" title="catiaOccurrenceName"></UserValue> <UserValue value="6370-1109131-98_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="6370-1109131-98.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id849">0.143881497521726 0.9310727693814971 -0.335263497546595 0 -0.05673162844976901 -0.330470779182407 -0.942109646718476 0 -0.9879674270968371 0.154572190975101 0.00527264381631272 0 -1.34510337585249 -5.97741930026813 2.42416501893221 1</Transform></Occurrence> <Occurrence id="id870" instancedRef="#id873" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zYB1M_ntwsW4BC/"></ApplicationRef> <UserData id="id871" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="170" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id872" type="InstanceNotes"> <UserValue value="Компрессор кондиционера.1" title="catiaOccurrenceName"></UserValue> <UserValue value="114_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Компрессор кондиционера.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id869">-0.987967430722672 0.15457216773573 0.00527264570409402 0 -0.0175592732905729 -0.0782308953538737 -0.9967806172541871 0 -0.153662056971623 -0.9848793692496599 0.0800037516222889 0 -1.17924530723019 -5.442416119690599 2.55040530975819 1</Transform></Occurrence> <Occurrence id="id890" instancedRef="#id893" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zYH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id891" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="180" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id892" type="InstanceNotes"> <UserValue value="tub-adm.IGS.1" title="catiaOccurrenceName"></UserValue> <UserValue value="115_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="tub-adm.IGS.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id889">0.9757319371190361 -0.215891178200275 -0.0365812255294364 0 -0.05920907961439331 -0.420968341164686 0.905140840216747 0 -0.210811460260478 -0.881008884695471 -0.423534972948506 0 -0.626155319275386 -5.326277334085201 2.7686211650295 1</Transform></Occurrence> <Occurrence id="id910" instancedRef="#id913" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zYN1M_ntwsW4BC/"></ApplicationRef> <UserData id="id911" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="190" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id912" type="InstanceNotes"> <UserValue value="КОМ ZF N71/4c.1" title="catiaOccurrenceName"></UserValue> <UserValue value="116_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="КОМ ZF N71/4c.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id909">0.987967430722666 -0.154572167735728 -0.00527264570409399 0 0.0175592732905717 0.0782308953538742 0.99678061725419 0 -0.153662056971623 -0.9848793692496599 0.08000375162228809 0 0.696157628087136 -5.777072599924299 2.65767539834239 1</Transform></Occurrence> <Occurrence id="id930" instancedRef="#id933" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zcD1M_ntwsW4BC/"></ApplicationRef> <UserData id="id931" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="200" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id932" type="InstanceNotes"> <UserValue value="Насос HYVA-061L.1" title="catiaOccurrenceName"></UserValue> <UserValue value="117_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Насос HYVA-061L.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id929">0.0175592732905716 0.07823089535387399 0.9967806172541871 0 0.987967430722672 -0.154572167735729 -0.00527264570409255 0 0.153662056971623 0.9848793692496599 -0.0800037516222888 0 -0.211434585119049 -5.58500131822083 2.77897666491569 1</Transform></Occurrence> <Occurrence id="id950" instancedRef="#id1037" occurrenceRefs="id954 id974 id994 id1014 id1034" parentRef="#id6"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zgH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id951" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="210" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id952" type="InstanceNotes"> <UserValue value="Kricshka Kompressora (Sborka).1" title="catiaOccurrenceName"></UserValue> <UserValue value="118_0.CATProduct" title="catiaFileName"></UserValue> <UserValue value="Kricshka Kompressora (Sborka).1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id949">0.987967430722671 -0.15457216773573 -0.00527264570409406 0 -0.153662056971623 -0.9848793692496599 0.080003751622289 0 -0.0175592732905732 -0.0782308953538739 -0.9967806172541871 0 -1.26927355178466 -5.23125250438011 2.28962707667221 1</Transform></Occurrence> <Occurrence id="id954" instancedRef="#id957" parentRef="#id950"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zgN1M_ntwsW4BC/zgH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id955" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="10" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id956" type="InstanceNotes"> <UserValue value="Kricshka Kompressora Kondicionera.1" title="catiaOccurrenceName"></UserValue> <UserValue value="161_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Kricshka Kompressora Kondicionera.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id953">0.987967430722671 -0.15457216773573 -0.00527264570409406 0 -0.153662056971623 -0.9848793692496599 0.080003751622289 0 -0.0175592732905732 -0.0782308953538739 -0.9967806172541871 0 -1.26927355178466 -5.23125250438011 2.28962707667221 1</Transform></Occurrence> <Occurrence id="id974" instancedRef="#id977" parentRef="#id950"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zkD1M_ntwsW4BC/zgH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id975" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="20" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id976" type="InstanceNotes"> <UserValue value="Trubka Kompressora 2.1" title="catiaOccurrenceName"></UserValue> <UserValue value="162_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Trubka Kompressora 2.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id973">-0.5973091320056071 0.7673578353976491 -0.2332032445636871 0 0.05673162241598267 0.3304707801265792 0.9421096467502825 0 0.8000020773968595 0.5495006969381514 -0.2409266698063187 0 -1.332465440066235 -5.327550068934139 2.18922316859412 1</Transform></Occurrence> <Occurrence id="id994" instancedRef="#id997" parentRef="#id950"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zkJ1M_ntwsW4BC/zgH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id995" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="30" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id996" type="InstanceNotes"> <UserValue value="Trubka Kompressora 1.1" title="catiaOccurrenceName"></UserValue> <UserValue value="163_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Trubka Kompressora 1.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id993">0.7914459980372476 0.5978222249111792 0.1273649072260164 0 -0.02280971129166159 -0.1793402956542541 0.9835226359489157 0 0.610813350591668 -0.7813102109638226 -0.1283020069284715 0 -1.309606210622901 -5.132589543867915 2.174504427069023 1</Transform></Occurrence> <Occurrence id="id1014" instancedRef="#id1017" parentRef="#id950"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zkP1M_ntwsW4BC/zgH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id1015" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="40" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id1016" type="InstanceNotes"> <UserValue value="Pimpka Kompressora.1" title="catiaOccurrenceName"></UserValue> <UserValue value="164_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Pimpka Kompressora.1" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id1013">-0.02280971129161588 -0.1793402956543195 0.9835226359496845 0 -0.1488808823678459 -0.9721994299945923 -0.1807283906406565 0 0.9885920290676861 -0.150550080281651 -0.004524753145075254 0 -1.259258511341612 -5.183437241527491 2.100311295178026 1</Transform></Occurrence> <Occurrence id="id1034" instancedRef="#id1017" parentRef="#id950"> <ApplicationRef application="Teamcenter" label="jED1M_ntwsW4BC/zoF1M_ntwsW4BC/zgH1M_ntwsW4BC/"></ApplicationRef> <UserData id="id1035" type="AttributesInContext"> <UserValue value="" title="AO_ID"></UserValue> <UserValue value="50" title="SequenceNumber"></UserValue> <UserValue value="" title="OccurrenceName"></UserValue> <UserValue value="" title="Quantity"></UserValue></UserData> <UserData id="id1036" type="InstanceNotes"> <UserValue value="Pimpka Kompressora.2" title="catiaOccurrenceName"></UserValue> <UserValue value="164_0.CATPart" title="catiaFileName"></UserValue> <UserValue value="Pimpka Kompressora.2" title="catiaOccurrenceOEM"></UserValue></UserData> <Transform id="id1033">0.05673162241600086 0.3304707801266852 0.9421096467505838 0 -0.1325207298783855 -0.9327872724364054 0.3351807878341941 0 0.989555344167545 -0.143864407909363 -0.009124306348445667 0 -1.278552845950702 -5.309466619462829 2.110639321329269 1</Transform></Occurrence></ProductView> <User id="id13" personRef="#id15" userId="satetushev"> <ApplicationRef version="CeG15EUrwsW4BC" application="Teamcenter" label="CeG15EUrwsW4BC"></ApplicationRef> <UserData id="id14"> <UserValue value="satetushev" title="user_id"></UserValue> <UserValue value="Тетюшев С.А." title="user_name"></UserValue> <UserValue value="SATetushev" title="os_username"></UserValue> <UserValue value="0" title="status"></UserValue> <UserValue type="reference" value="" title="default_group" dataRef="#id20"></UserValue> <UserValue type="reference" value="" title="volume" dataRef="#id25"></UserValue></UserData></User> <Person id="id15" lastName="Тетюшев С.А."> <ApplicationRef version="yhL15EUrwsW4BC" application="Teamcenter" label="yhL15EUrwsW4BC"></ApplicationRef> <UserData id="id19"> <UserValue value="" title="PA1"></UserValue> <UserValue value="" title="PA2"></UserValue> <UserValue value="" title="PA3"></UserValue> <UserValue value="" title="PA4"></UserValue> <UserValue value="" title="PA5"></UserValue> <UserValue value="" title="PA6"></UserValue> <UserValue value="" title="PA7"></UserValue> <UserValue value="" title="PA8"></UserValue> <UserValue value="SATetushev@azural.sp.uralaz.ru" title="PA9"></UserValue> <UserValue value="" title="PA10"></UserValue></UserData></Person> <AccessIntent id="id16" intent="reference" ownerRefs="#id17"></AccessIntent> <Site id="id17" name="IMC-62266904" siteId="62266904"> <ApplicationRef version="wVC1B0htwsW4BC" application="Teamcenter" label="wVC1B0htwsW4BC"></ApplicationRef> <UserData id="id18"> <UserValue value="1" title="dbms"></UserValue></UserData></Site> <Organisation id="id20" name="dba"> <Description>DataBase Administrator group.</Description> <ApplicationRef version="A4B1B0xuwsW4BC" application="Teamcenter" label="A4B1B0xuwsW4BC"></ApplicationRef> <UserData id="id21"> <UserValue value="dba" title="name"></UserValue> <UserValue type="reference" value="" title="list_of_role" dataRef="#id22"></UserValue> <UserValue type="int" value="1" title="privilege"></UserValue></UserData></Organisation> <Role id="id22" name="DBA"> <Description>Database Administrator.</Description> <ApplicationRef version="A0F1B0xuwsW4BC" application="Teamcenter" label="A0F1B0xuwsW4BC"></ApplicationRef> <UserData id="id23"> <UserValue value="DBA" title="role_name"></UserValue></UserData></Role> <Vault id="id25" name="volume1"> <UserData id="id24"> <UserValue value="TCuralaz" title="node_name"></UserValue> <UserValue value="C:\Siemens\Teamcenter\volume1" title="wnt_path_name"></UserValue> <UserValue value="0" title="machine_type"></UserValue></UserData></Vault> <Form id="id28" name="333/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="y5C1M_ntwsW4BC" application="Teamcenter" label="y5C1M_ntwsW4BC"></ApplicationRef> <UserData id="id31" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id29" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id30" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id33" name="333/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="y9J1M_ntwsW4BC" application="Teamcenter" label="y9J1M_ntwsW4BC"></ApplicationRef> <UserData id="id34" type="FormAttributes"> <UserValue value="333" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="305813" title="weight"></UserValue> <UserValue type="real" value="305813" title="mod_weight"></UserValue> <UserValue type="real" value="3.05813e+008" title="volume"></UserValue> <UserValue type="real" value="12506600" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-857.989" title="pnt_min_x"></UserValue> <UserValue type="real" value="-387.874" title="pnt_min_y"></UserValue> <UserValue type="real" value="-631.567" title="pnt_min_z"></UserValue> <UserValue type="real" value="494.388" title="pnt_max_x"></UserValue> <UserValue type="real" value="429.398" title="pnt_max_y"></UserValue> <UserValue type="real" value="523.034" title="pnt_max_z"></UserValue> <UserValue type="real" value="2.03037e+010" title="inertia_x"></UserValue> <UserValue type="real" value="5.67574e+010" title="inertia_y"></UserValue> <UserValue type="real" value="4.83056e+010" title="inertia_z"></UserValue> <UserValue type="real" value="4.68634e+008" title="inertia_prod_x"></UserValue> <UserValue type="real" value="2.47502e+009" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-59483000" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-248.821" title="gravity_x"></UserValue> <UserValue type="real" value="20.4511" title="gravity_y"></UserValue> <UserValue type="real" value="72.3347" title="gravity_z"></UserValue></UserData></Form> <Form id="id38" name="333" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="y1I1M_ntwsW4BC" application="Teamcenter" label="y1I1M_ntwsW4BC"></ApplicationRef> <UserData id="id39" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id52" name="63674Р-1001018/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CSG1M_ntwsW4BC" application="Teamcenter" label="CSG1M_ntwsW4BC"></ApplicationRef> <UserData id="id55" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id53" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id54" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id57" name="63674Р-1001018/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="CWL1M_ntwsW4BC" application="Teamcenter" label="CWL1M_ntwsW4BC"></ApplicationRef> <UserData id="id58" type="FormAttributes"> <UserValue value="63674Р-1001018" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="121.2" title="weight"></UserValue> <UserValue type="real" value="121.2" title="mod_weight"></UserValue> <UserValue type="real" value="121200" title="volume"></UserValue> <UserValue type="real" value="46605.8" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-32.9953" title="pnt_min_x"></UserValue> <UserValue type="real" value="-38" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="173.935" title="pnt_max_x"></UserValue> <UserValue type="real" value="0" title="pnt_max_y"></UserValue> <UserValue type="real" value="153.075" title="pnt_max_z"></UserValue> <UserValue type="real" value="209170" title="inertia_x"></UserValue> <UserValue type="real" value="469498" title="inertia_y"></UserValue> <UserValue type="real" value="314406" title="inertia_z"></UserValue> <UserValue type="real" value="76244.4" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-102322" title="inertia_prod_y"></UserValue> <UserValue type="real" value="29239.2" title="inertia_prod_z"></UserValue> <UserValue type="real" value="76.3121" title="gravity_x"></UserValue> <UserValue type="real" value="-19.8111" title="gravity_y"></UserValue> <UserValue type="real" value="66.1512" title="gravity_z"></UserValue></UserData></Form> <Form id="id62" name="63674Р-1001018" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CON1M_ntwsW4BC" application="Teamcenter" label="CON1M_ntwsW4BC"></ApplicationRef> <UserData id="id63" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id72" name="128/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CeJ1M_ntwsW4BC" application="Teamcenter" label="CeJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id75" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id73" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id74" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id77" name="128/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="CiO1M_ntwsW4BC" application="Teamcenter" label="CiO1M_ntwsW4BC"></ApplicationRef> <UserData id="id78" type="FormAttributes"> <UserValue value="128" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="118.579" title="weight"></UserValue> <UserValue type="real" value="118.579" title="mod_weight"></UserValue> <UserValue type="real" value="118579" title="volume"></UserValue> <UserValue type="real" value="43531.5" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-78" title="pnt_min_x"></UserValue> <UserValue type="real" value="0" title="pnt_min_y"></UserValue> <UserValue type="real" value="-77" title="pnt_min_z"></UserValue> <UserValue type="real" value="52" title="pnt_max_x"></UserValue> <UserValue type="real" value="33.4545" title="pnt_max_y"></UserValue> <UserValue type="real" value="77" title="pnt_max_z"></UserValue> <UserValue type="real" value="182306" title="inertia_x"></UserValue> <UserValue type="real" value="325872" title="inertia_y"></UserValue> <UserValue type="real" value="167193" title="inertia_z"></UserValue> <UserValue type="real" value="6069.19" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-6.12774" title="gravity_x"></UserValue> <UserValue type="real" value="11.5374" title="gravity_y"></UserValue> <UserValue type="real" value="1.73542e-006" title="gravity_z"></UserValue></UserData></Form> <Form id="id82" name="128" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CeA1M_ntwsW4BC" application="Teamcenter" label="CeA1M_ntwsW4BC"></ApplicationRef> <UserData id="id83" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id92" name=" 63674Р-1001016/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CqM1M_ntwsW4BC" application="Teamcenter" label="CqM1M_ntwsW4BC"></ApplicationRef> <UserData id="id95" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id93" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id94" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id97" name=" 63674Р-1001016/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="CyB1M_ntwsW4BC" application="Teamcenter" label="CyB1M_ntwsW4BC"></ApplicationRef> <UserData id="id98" type="FormAttributes"> <UserValue value=" 63674Р-1001016" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="99.1299" title="weight"></UserValue> <UserValue type="real" value="99.1299" title="mod_weight"></UserValue> <UserValue type="real" value="99129.9" title="volume"></UserValue> <UserValue type="real" value="38241.8" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="0" title="pnt_min_x"></UserValue> <UserValue type="real" value="0" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="173.935" title="pnt_max_x"></UserValue> <UserValue type="real" value="38" title="pnt_max_y"></UserValue> <UserValue type="real" value="153.075" title="pnt_max_z"></UserValue> <UserValue type="real" value="190266" title="inertia_x"></UserValue> <UserValue type="real" value="322531" title="inertia_y"></UserValue> <UserValue type="real" value="172044" title="inertia_z"></UserValue> <UserValue type="real" value="-47317.9" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-96210" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-29758.6" title="inertia_prod_z"></UserValue> <UserValue type="real" value="90.6394" title="gravity_x"></UserValue> <UserValue type="real" value="23.3218" title="gravity_y"></UserValue> <UserValue type="real" value="65.4428" title="gravity_z"></UserValue></UserData></Form> <Form id="id102" name=" 63674Р-1001016" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CqD1M_ntwsW4BC" application="Teamcenter" label="CqD1M_ntwsW4BC"></ApplicationRef> <UserData id="id103" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id112" name="123/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="C2P1M_ntwsW4BC" application="Teamcenter" label="C2P1M_ntwsW4BC"></ApplicationRef> <UserData id="id115" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id113" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id114" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id117" name="123/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="C_E1M_ntwsW4BC" application="Teamcenter" label="C_E1M_ntwsW4BC"></ApplicationRef> <UserData id="id118" type="FormAttributes"> <UserValue value="123" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="16.7693" title="weight"></UserValue> <UserValue type="real" value="16.7693" title="mod_weight"></UserValue> <UserValue type="real" value="16769.3" title="volume"></UserValue> <UserValue type="real" value="5700.85" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-54.0398" title="pnt_min_x"></UserValue> <UserValue type="real" value="-148" title="pnt_min_y"></UserValue> <UserValue type="real" value="-54.0398" title="pnt_min_z"></UserValue> <UserValue type="real" value="54.0398" title="pnt_max_x"></UserValue> <UserValue type="real" value="0.000743319" title="pnt_max_y"></UserValue> <UserValue type="real" value="54.0398" title="pnt_max_z"></UserValue> <UserValue type="real" value="2341.5" title="inertia_x"></UserValue> <UserValue type="real" value="4080.62" title="inertia_y"></UserValue> <UserValue type="real" value="2341.5" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="-137.38" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id122" name="123" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="C2G1M_ntwsW4BC" application="Teamcenter" label="C2G1M_ntwsW4BC"></ApplicationRef> <UserData id="id123" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id128" name="99/0" accessRefs="#id16" subType="Сб_единица Revision Master" subClass="Сб_единица Revision Master"> <ApplicationRef version="CGK1M_ntwsW4BC" application="Teamcenter" label="CGK1M_ntwsW4BC"></ApplicationRef> <UserData id="id131" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id129" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id130" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id135" name="99" accessRefs="#id16" subType="Сб_единица Master" subClass="Сб_единица Master"> <ApplicationRef version="CGA1M_ntwsW4BC" application="Teamcenter" label="CGA1M_ntwsW4BC"></ApplicationRef> <UserData id="id136" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id149" name=" 63674Р-1001019/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SON1M_ntwsW4BC" application="Teamcenter" label="SON1M_ntwsW4BC"></ApplicationRef> <UserData id="id152" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id150" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id151" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id154" name=" 63674Р-1001019/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SWC1M_ntwsW4BC" application="Teamcenter" label="SWC1M_ntwsW4BC"></ApplicationRef> <UserData id="id155" type="FormAttributes"> <UserValue value=" 63674Р-1001019" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="109.055" title="weight"></UserValue> <UserValue type="real" value="109.055" title="mod_weight"></UserValue> <UserValue type="real" value="109055" title="volume"></UserValue> <UserValue type="real" value="42352.5" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-195.134" title="pnt_min_x"></UserValue> <UserValue type="real" value="-32" title="pnt_min_y"></UserValue> <UserValue type="real" value="13.3512" title="pnt_min_z"></UserValue> <UserValue type="real" value="0" title="pnt_max_x"></UserValue> <UserValue type="real" value="6" title="pnt_max_y"></UserValue> <UserValue type="real" value="190.253" title="pnt_max_z"></UserValue> <UserValue type="real" value="172460" title="inertia_x"></UserValue> <UserValue type="real" value="420321" title="inertia_y"></UserValue> <UserValue type="real" value="297156" title="inertia_z"></UserValue> <UserValue type="real" value="-71450.3" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-108088" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-33015.6" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-104.633" title="gravity_x"></UserValue> <UserValue type="real" value="-12.6773" title="gravity_y"></UserValue> <UserValue type="real" value="114.274" title="gravity_z"></UserValue></UserData></Form> <Form id="id159" name=" 63674Р-1001019" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SOE1M_ntwsW4BC" application="Teamcenter" label="SOE1M_ntwsW4BC"></ApplicationRef> <UserData id="id160" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id169" name="139/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SeA1M_ntwsW4BC" application="Teamcenter" label="SeA1M_ntwsW4BC"></ApplicationRef> <UserData id="id172" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id170" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id171" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id174" name="139/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SiF1M_ntwsW4BC" application="Teamcenter" label="SiF1M_ntwsW4BC"></ApplicationRef> <UserData id="id175" type="FormAttributes"> <UserValue value="139" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="118.579" title="weight"></UserValue> <UserValue type="real" value="118.579" title="mod_weight"></UserValue> <UserValue type="real" value="118579" title="volume"></UserValue> <UserValue type="real" value="43531.5" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-78" title="pnt_min_x"></UserValue> <UserValue type="real" value="0" title="pnt_min_y"></UserValue> <UserValue type="real" value="-77" title="pnt_min_z"></UserValue> <UserValue type="real" value="52" title="pnt_max_x"></UserValue> <UserValue type="real" value="33.4545" title="pnt_max_y"></UserValue> <UserValue type="real" value="77" title="pnt_max_z"></UserValue> <UserValue type="real" value="182306" title="inertia_x"></UserValue> <UserValue type="real" value="325872" title="inertia_y"></UserValue> <UserValue type="real" value="167193" title="inertia_z"></UserValue> <UserValue type="real" value="6069.19" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-6.12774" title="gravity_x"></UserValue> <UserValue type="real" value="11.5374" title="gravity_y"></UserValue> <UserValue type="real" value="1.73542e-006" title="gravity_z"></UserValue></UserData></Form> <Form id="id179" name="139" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SaH1M_ntwsW4BC" application="Teamcenter" label="SaH1M_ntwsW4BC"></ApplicationRef> <UserData id="id180" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id189" name=" 63674Р-1001017/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SqD1M_ntwsW4BC" application="Teamcenter" label="SqD1M_ntwsW4BC"></ApplicationRef> <UserData id="id192" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id190" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id191" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id194" name=" 63674Р-1001017/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SuI1M_ntwsW4BC" application="Teamcenter" label="SuI1M_ntwsW4BC"></ApplicationRef> <UserData id="id195" type="FormAttributes"> <UserValue value=" 63674Р-1001017" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="76.6244" title="weight"></UserValue> <UserValue type="real" value="76.6244" title="mod_weight"></UserValue> <UserValue type="real" value="76624.4" title="volume"></UserValue> <UserValue type="real" value="30418.2" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-175.425" title="pnt_min_x"></UserValue> <UserValue type="real" value="-6" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="0" title="pnt_max_x"></UserValue> <UserValue type="real" value="32" title="pnt_max_y"></UserValue> <UserValue type="real" value="150" title="pnt_max_z"></UserValue> <UserValue type="real" value="85242.3" title="inertia_x"></UserValue> <UserValue type="real" value="212077" title="inertia_y"></UserValue> <UserValue type="real" value="158770" title="inertia_z"></UserValue> <UserValue type="real" value="41909.8" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-37611.2" title="inertia_prod_y"></UserValue> <UserValue type="real" value="13900.4" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-101.051" title="gravity_x"></UserValue> <UserValue type="real" value="16.9405" title="gravity_y"></UserValue> <UserValue type="real" value="108.347" title="gravity_z"></UserValue></UserData></Form> <Form id="id199" name=" 63674Р-1001017" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SmK1M_ntwsW4BC" application="Teamcenter" label="SmK1M_ntwsW4BC"></ApplicationRef> <UserData id="id200" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id209" name="134/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="S2G1M_ntwsW4BC" application="Teamcenter" label="S2G1M_ntwsW4BC"></ApplicationRef> <UserData id="id212" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id210" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id211" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id214" name="134/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="S6L1M_ntwsW4BC" application="Teamcenter" label="S6L1M_ntwsW4BC"></ApplicationRef> <UserData id="id215" type="FormAttributes"> <UserValue value="134" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="16.7693" title="weight"></UserValue> <UserValue type="real" value="16.7693" title="mod_weight"></UserValue> <UserValue type="real" value="16769.3" title="volume"></UserValue> <UserValue type="real" value="5700.85" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-54.0398" title="pnt_min_x"></UserValue> <UserValue type="real" value="-148" title="pnt_min_y"></UserValue> <UserValue type="real" value="-54.0398" title="pnt_min_z"></UserValue> <UserValue type="real" value="54.0398" title="pnt_max_x"></UserValue> <UserValue type="real" value="0.000743319" title="pnt_max_y"></UserValue> <UserValue type="real" value="54.0398" title="pnt_max_z"></UserValue> <UserValue type="real" value="2341.5" title="inertia_x"></UserValue> <UserValue type="real" value="4080.62" title="inertia_y"></UserValue> <UserValue type="real" value="2341.5" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="-137.38" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id219" name="134" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SyN1M_ntwsW4BC" application="Teamcenter" label="SyN1M_ntwsW4BC"></ApplicationRef> <UserData id="id220" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id225" name="100/0" accessRefs="#id16" subType="Сб_единица Revision Master" subClass="Сб_единица Revision Master"> <ApplicationRef version="SGC1M_ntwsW4BC" application="Teamcenter" label="SGC1M_ntwsW4BC"></ApplicationRef> <UserData id="id228" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id226" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id227" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id232" name="100" accessRefs="#id16" subType="Сб_единица Master" subClass="Сб_единица Master"> <ApplicationRef version="SCJ1M_ntwsW4BC" application="Teamcenter" label="SCJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id233" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id242" name="ZF 16S2220TO/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="iCJ1M_ntwsW4BC" application="Teamcenter" label="iCJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id245" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id243" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id244" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id247" name="ZF 16S2220TO/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="iGO1M_ntwsW4BC" application="Teamcenter" label="iGO1M_ntwsW4BC"></ApplicationRef> <UserData id="id248" type="FormAttributes"> <UserValue value="ZF 16S2220TO" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="177137" title="weight"></UserValue> <UserValue type="real" value="177137" title="mod_weight"></UserValue> <UserValue type="real" value="1.77137e+008" title="volume"></UserValue> <UserValue type="real" value="2647570" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-287.078" title="pnt_min_x"></UserValue> <UserValue type="real" value="-109" title="pnt_min_y"></UserValue> <UserValue type="real" value="-296.5" title="pnt_min_z"></UserValue> <UserValue type="real" value="295" title="pnt_max_x"></UserValue> <UserValue type="real" value="1229.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="274.377" title="pnt_max_z"></UserValue> <UserValue type="real" value="1.88205e+010" title="inertia_x"></UserValue> <UserValue type="real" value="5.32064e+009" title="inertia_y"></UserValue> <UserValue type="real" value="1.99276e+010" title="inertia_z"></UserValue> <UserValue type="real" value="7.67247e+008" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-2.10562e+008" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-36888600" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-22.395" title="gravity_x"></UserValue> <UserValue type="real" value="472.009" title="gravity_y"></UserValue> <UserValue type="real" value="0.465446" title="gravity_z"></UserValue></UserData></Form> <Form id="id252" name="ZF 16S2220TO" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="iCA1M_ntwsW4BC" application="Teamcenter" label="iCA1M_ntwsW4BC"></ApplicationRef> <UserData id="id253" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id262" name="102/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="iOM1M_ntwsW4BC" application="Teamcenter" label="iOM1M_ntwsW4BC"></ApplicationRef> <UserData id="id265" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id263" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id264" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id267" name="102/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="iWB1M_ntwsW4BC" application="Teamcenter" label="iWB1M_ntwsW4BC"></ApplicationRef> <UserData id="id268" type="FormAttributes"> <UserValue value="102" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="665.231" title="weight"></UserValue> <UserValue type="real" value="665.231" title="mod_weight"></UserValue> <UserValue type="real" value="665231" title="volume"></UserValue> <UserValue type="real" value="561124" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-393" title="pnt_min_x"></UserValue> <UserValue type="real" value="0" title="pnt_min_y"></UserValue> <UserValue type="real" value="-393" title="pnt_min_z"></UserValue> <UserValue type="real" value="393" title="pnt_max_x"></UserValue> <UserValue type="real" value="75" title="pnt_max_y"></UserValue> <UserValue type="real" value="393" title="pnt_max_z"></UserValue> <UserValue type="real" value="43462500" title="inertia_x"></UserValue> <UserValue type="real" value="86175700" title="inertia_y"></UserValue> <UserValue type="real" value="43462500" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="25.5824" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id272" name="102" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="iOD1M_ntwsW4BC" application="Teamcenter" label="iOD1M_ntwsW4BC"></ApplicationRef> <UserData id="id273" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id282" name="103/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="iaP1M_ntwsW4BC" application="Teamcenter" label="iaP1M_ntwsW4BC"></ApplicationRef> <UserData id="id285" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id283" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id284" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id287" name="103/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="iiE1M_ntwsW4BC" application="Teamcenter" label="iiE1M_ntwsW4BC"></ApplicationRef> <UserData id="id288" type="FormAttributes"> <UserValue value="103" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Steel" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="7697.07" title="weight"></UserValue> <UserValue type="real" value="7697.07" title="mod_weight"></UserValue> <UserValue type="real" value="979271" title="volume"></UserValue> <UserValue type="real" value="165854" title="wetArea"></UserValue> <UserValue type="real" value="0.00786" title="density"></UserValue> <UserValue type="real" value="0" title="pnt_min_x"></UserValue> <UserValue type="real" value="-113.94" title="pnt_min_y"></UserValue> <UserValue type="real" value="-142" title="pnt_min_z"></UserValue> <UserValue type="real" value="103" title="pnt_max_x"></UserValue> <UserValue type="real" value="94.993" title="pnt_max_y"></UserValue> <UserValue type="real" value="126.193" title="pnt_max_z"></UserValue> <UserValue type="real" value="62619200" title="inertia_x"></UserValue> <UserValue type="real" value="54529300" title="inertia_y"></UserValue> <UserValue type="real" value="21576900" title="inertia_z"></UserValue> <UserValue type="real" value="-69209.4" title="inertia_prod_x"></UserValue> <UserValue type="real" value="9814440" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-791544" title="inertia_prod_z"></UserValue> <UserValue type="real" value="32.6134" title="gravity_x"></UserValue> <UserValue type="real" value="-20.6928" title="gravity_y"></UserValue> <UserValue type="real" value="-48.1006" title="gravity_z"></UserValue></UserData></Form> <Form id="id292" name="103" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="iaG1M_ntwsW4BC" application="Teamcenter" label="iaG1M_ntwsW4BC"></ApplicationRef> <UserData id="id293" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id302" name="104/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="iqC1M_ntwsW4BC" application="Teamcenter" label="iqC1M_ntwsW4BC"></ApplicationRef> <UserData id="id305" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id303" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id304" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id307" name="104/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="iuH1M_ntwsW4BC" application="Teamcenter" label="iuH1M_ntwsW4BC"></ApplicationRef> <UserData id="id308" type="FormAttributes"> <UserValue value="104" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="979.271" title="weight"></UserValue> <UserValue type="real" value="979.271" title="mod_weight"></UserValue> <UserValue type="real" value="979271" title="volume"></UserValue> <UserValue type="real" value="165854" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="0" title="pnt_min_x"></UserValue> <UserValue type="real" value="-94.993" title="pnt_min_y"></UserValue> <UserValue type="real" value="-142" title="pnt_min_z"></UserValue> <UserValue type="real" value="103" title="pnt_max_x"></UserValue> <UserValue type="real" value="113.94" title="pnt_max_y"></UserValue> <UserValue type="real" value="126.193" title="pnt_max_z"></UserValue> <UserValue type="real" value="7966830" title="inertia_x"></UserValue> <UserValue type="real" value="6937570" title="inertia_y"></UserValue> <UserValue type="real" value="2745150" title="inertia_z"></UserValue> <UserValue type="real" value="8805.27" title="inertia_prod_x"></UserValue> <UserValue type="real" value="1248660" title="inertia_prod_y"></UserValue> <UserValue type="real" value="100705" title="inertia_prod_z"></UserValue> <UserValue type="real" value="32.6134" title="gravity_x"></UserValue> <UserValue type="real" value="20.6928" title="gravity_y"></UserValue> <UserValue type="real" value="-48.1006" title="gravity_z"></UserValue></UserData></Form> <Form id="id312" name="104" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="imJ1M_ntwsW4BC" application="Teamcenter" label="imJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id313" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id322" name="106/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="i2F1M_ntwsW4BC" application="Teamcenter" label="i2F1M_ntwsW4BC"></ApplicationRef> <UserData id="id325" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id323" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id324" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id327" name="106/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="i6K1M_ntwsW4BC" application="Teamcenter" label="i6K1M_ntwsW4BC"></ApplicationRef> <UserData id="id328" type="FormAttributes"> <UserValue value="106" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="155.983" title="weight"></UserValue> <UserValue type="real" value="155.983" title="mod_weight"></UserValue> <UserValue type="real" value="155983" title="volume"></UserValue> <UserValue type="real" value="45129.8" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-50.9884" title="pnt_min_x"></UserValue> <UserValue type="real" value="-113" title="pnt_min_y"></UserValue> <UserValue type="real" value="-30" title="pnt_min_z"></UserValue> <UserValue type="real" value="50.9884" title="pnt_max_x"></UserValue> <UserValue type="real" value="113" title="pnt_max_y"></UserValue> <UserValue type="real" value="1.47232" title="pnt_max_z"></UserValue> <UserValue type="real" value="579439" title="inertia_x"></UserValue> <UserValue type="real" value="112015" title="inertia_y"></UserValue> <UserValue type="real" value="658519" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="4416.73" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="-0.406113" title="gravity_y"></UserValue> <UserValue type="real" value="-13.4103" title="gravity_z"></UserValue></UserData></Form> <Form id="id332" name="106" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="iyM1M_ntwsW4BC" application="Teamcenter" label="iyM1M_ntwsW4BC"></ApplicationRef> <UserData id="id333" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id342" name="6370-1109131/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yCI1M_ntwsW4BC" application="Teamcenter" label="yCI1M_ntwsW4BC"></ApplicationRef> <UserData id="id345" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id343" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id344" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id347" name="6370-1109131/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="yGN1M_ntwsW4BC" application="Teamcenter" label="yGN1M_ntwsW4BC"></ApplicationRef> <UserData id="id348" type="FormAttributes"> <UserValue value="6370-1109131" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Aluminium" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="1518.74" title="weight"></UserValue> <UserValue type="real" value="1518.74" title="mod_weight"></UserValue> <UserValue type="real" value="560420" title="volume"></UserValue> <UserValue type="real" value="215351" title="wetArea"></UserValue> <UserValue type="real" value="0.00271" title="density"></UserValue> <UserValue type="real" value="-147.252" title="pnt_min_x"></UserValue> <UserValue type="real" value="-63.9591" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="86.9598" title="pnt_max_x"></UserValue> <UserValue type="real" value="201.629" title="pnt_max_y"></UserValue> <UserValue type="real" value="270" title="pnt_max_z"></UserValue> <UserValue type="real" value="16190400" title="inertia_x"></UserValue> <UserValue type="real" value="13868800" title="inertia_y"></UserValue> <UserValue type="real" value="11773100" title="inertia_z"></UserValue> <UserValue type="real" value="3995810" title="inertia_prod_x"></UserValue> <UserValue type="real" value="4937820" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-6436860" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-43.8554" title="gravity_x"></UserValue> <UserValue type="real" value="72.065" title="gravity_y"></UserValue> <UserValue type="real" value="118.173" title="gravity_z"></UserValue></UserData></Form> <Form id="id352" name="6370-1109131" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="i_P1M_ntwsW4BC" application="Teamcenter" label="i_P1M_ntwsW4BC"></ApplicationRef> <UserData id="id353" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id366" name="6370-1109047/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yaG1M_ntwsW4BC" application="Teamcenter" label="yaG1M_ntwsW4BC"></ApplicationRef> <UserData id="id369" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id367" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id368" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id371" name="6370-1109047/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="yeL1M_ntwsW4BC" application="Teamcenter" label="yeL1M_ntwsW4BC"></ApplicationRef> <UserData id="id372" type="FormAttributes"> <UserValue value="6370-1109047" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Steel" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="1158.16" title="weight"></UserValue> <UserValue type="real" value="1158.16" title="mod_weight"></UserValue> <UserValue type="real" value="147349" title="volume"></UserValue> <UserValue type="real" value="292268" title="wetArea"></UserValue> <UserValue type="real" value="0.00786" title="density"></UserValue> <UserValue type="real" value="-43.9727" title="pnt_min_x"></UserValue> <UserValue type="real" value="0" title="pnt_min_y"></UserValue> <UserValue type="real" value="-48" title="pnt_min_z"></UserValue> <UserValue type="real" value="43.9727" title="pnt_max_x"></UserValue> <UserValue type="real" value="440" title="pnt_max_y"></UserValue> <UserValue type="real" value="271" title="pnt_max_z"></UserValue> <UserValue type="real" value="26009000" title="inertia_x"></UserValue> <UserValue type="real" value="10454200" title="inertia_y"></UserValue> <UserValue type="real" value="17653300" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-11148500" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="220" title="gravity_y"></UserValue> <UserValue type="real" value="111.5" title="gravity_z"></UserValue></UserData></Form> <Form id="id376" name="6370-1109047" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="yWN1M_ntwsW4BC" application="Teamcenter" label="yWN1M_ntwsW4BC"></ApplicationRef> <UserData id="id377" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id386" name="6370-1109138/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="ymJ1M_ntwsW4BC" application="Teamcenter" label="ymJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id389" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id387" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id388" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id391" name="6370-1109138/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="yqO1M_ntwsW4BC" application="Teamcenter" label="yqO1M_ntwsW4BC"></ApplicationRef> <UserData id="id392" type="FormAttributes"> <UserValue value="6370-1109138" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Steel" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="494.75" title="weight"></UserValue> <UserValue type="real" value="494.75" title="mod_weight"></UserValue> <UserValue type="real" value="62945.2" title="volume"></UserValue> <UserValue type="real" value="29228.1" title="wetArea"></UserValue> <UserValue type="real" value="0.00786" title="density"></UserValue> <UserValue type="real" value="-44.9925" title="pnt_min_x"></UserValue> <UserValue type="real" value="0" title="pnt_min_y"></UserValue> <UserValue type="real" value="-44.9998" title="pnt_min_z"></UserValue> <UserValue type="real" value="44.9925" title="pnt_max_x"></UserValue> <UserValue type="real" value="50" title="pnt_max_y"></UserValue> <UserValue type="real" value="44.9998" title="pnt_max_z"></UserValue> <UserValue type="real" value="466140" title="inertia_x"></UserValue> <UserValue type="real" value="741753" title="inertia_y"></UserValue> <UserValue type="real" value="466140" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="23.4621" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id396" name="6370-1109138" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="ymA1M_ntwsW4BC" application="Teamcenter" label="ymA1M_ntwsW4BC"></ApplicationRef> <UserData id="id397" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id406" name="5323E-1109225/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="y6B1M_ntwsW4BC" application="Teamcenter" label="y6B1M_ntwsW4BC"></ApplicationRef> <UserData id="id407" type="FormAttributes"> <UserValue value="5323E-1109225" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Steel" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="93.5802" title="weight"></UserValue> <UserValue type="real" value="93.5802" title="mod_weight"></UserValue> <UserValue type="real" value="11905.9" title="volume"></UserValue> <UserValue type="real" value="24387.7" title="wetArea"></UserValue> <UserValue type="real" value="0.00786" title="density"></UserValue> <UserValue type="real" value="-47.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-40" title="pnt_min_y"></UserValue> <UserValue type="real" value="-47.4901" title="pnt_min_z"></UserValue> <UserValue type="real" value="47.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="0" title="pnt_max_y"></UserValue> <UserValue type="real" value="47.4901" title="pnt_max_z"></UserValue> <UserValue type="real" value="107420" title="inertia_x"></UserValue> <UserValue type="real" value="187738" title="inertia_y"></UserValue> <UserValue type="real" value="107420" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="-20.4983" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id409" name="5323E-1109225/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yyM1M_ntwsW4BC" application="Teamcenter" label="yyM1M_ntwsW4BC"></ApplicationRef> <UserData id="id412" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id410" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id411" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id416" name="5323E-1109225" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="yyD1M_ntwsW4BC" application="Teamcenter" label="yyD1M_ntwsW4BC"></ApplicationRef> <UserData id="id417" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id422" name="6370-1109046/0" accessRefs="#id16" subType="Сб_единица Revision Master" subClass="Сб_единица Revision Master"> <ApplicationRef version="yOL1M_ntwsW4BC" application="Teamcenter" label="yOL1M_ntwsW4BC"></ApplicationRef> <UserData id="id425" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id423" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id424" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id429" name="6370-1109046" accessRefs="#id16" subType="Сб_единица Master" subClass="Сб_единица Master"> <ApplicationRef version="yOC1M_ntwsW4BC" application="Teamcenter" label="yOC1M_ntwsW4BC"></ApplicationRef> <UserData id="id430" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id443" name="CHR-10816-12_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CLK1M_ntwsW4BC" application="Teamcenter" label="CLK1M_ntwsW4BC"></ApplicationRef> <UserData id="id446" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id444" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id445" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id448" name="CHR-10816-12_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="CPP1M_ntwsW4BC" application="Teamcenter" label="CPP1M_ntwsW4BC"></ApplicationRef> <UserData id="id449" type="FormAttributes"> <UserValue value="CHR-10816-12_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="374.928" title="weight"></UserValue> <UserValue type="real" value="374.928" title="mod_weight"></UserValue> <UserValue type="real" value="374928" title="volume"></UserValue> <UserValue type="real" value="504634" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="14.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-357" title="pnt_min_y"></UserValue> <UserValue type="real" value="14.5" title="pnt_min_z"></UserValue> <UserValue type="real" value="985.598" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.11177" title="pnt_max_y"></UserValue> <UserValue type="real" value="154" title="pnt_max_z"></UserValue> <UserValue type="real" value="4533140" title="inertia_x"></UserValue> <UserValue type="real" value="29583400" title="inertia_y"></UserValue> <UserValue type="real" value="33179000" title="inertia_z"></UserValue> <UserValue type="real" value="-5193380" title="inertia_prod_x"></UserValue> <UserValue type="real" value="744060" title="inertia_prod_y"></UserValue> <UserValue type="real" value="62893.9" title="inertia_prod_z"></UserValue> <UserValue type="real" value="297.994" title="gravity_x"></UserValue> <UserValue type="real" value="-144.809" title="gravity_y"></UserValue> <UserValue type="real" value="31.7261" title="gravity_z"></UserValue></UserData></Form> <Form id="id453" name="CHR-10816-12_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CLB1M_ntwsW4BC" application="Teamcenter" label="CLB1M_ntwsW4BC"></ApplicationRef> <UserData id="id454" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id463" name="CHR-10816-14_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CXN1M_ntwsW4BC" application="Teamcenter" label="CXN1M_ntwsW4BC"></ApplicationRef> <UserData id="id466" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id464" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id465" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData> </Form> <Form id="id468" name="CHR-10816-14_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="CfC1M_ntwsW4BC" application="Teamcenter" label="CfC1M_ntwsW4BC"></ApplicationRef> <UserData id="id469" type="FormAttributes"> <UserValue value="CHR-10816-14_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="376.371" title="weight"></UserValue> <UserValue type="real" value="376.371" title="mod_weight"></UserValue> <UserValue type="real" value="376371" title="volume"></UserValue> <UserValue type="real" value="506393" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="14.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-357" title="pnt_min_y"></UserValue> <UserValue type="real" value="154" title="pnt_min_z"></UserValue> <UserValue type="real" value="985.598" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.11177" title="pnt_max_y"></UserValue> <UserValue type="real" value="293.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="4546150" title="inertia_x"></UserValue> <UserValue type="real" value="29584700" title="inertia_y"></UserValue> <UserValue type="real" value="33192500" title="inertia_z"></UserValue> <UserValue type="real" value="-5196600" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-744629" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-65104.1" title="inertia_prod_z"></UserValue> <UserValue type="real" value="298.086" title="gravity_x"></UserValue> <UserValue type="real" value="-144.451" title="gravity_y"></UserValue> <UserValue type="real" value="276.337" title="gravity_z"></UserValue></UserData></Form> <Form id="id473" name="CHR-10816-14_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CXE1M_ntwsW4BC" application="Teamcenter" label="CXE1M_ntwsW4BC"></ApplicationRef> <UserData id="id474" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id483" name="CHR-10816-16_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CnA1M_ntwsW4BC" application="Teamcenter" label="CnA1M_ntwsW4BC"></ApplicationRef> <UserData id="id486" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id484" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id485" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id488" name="CHR-10816-16_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="CrF1M_ntwsW4BC" application="Teamcenter" label="CrF1M_ntwsW4BC"></ApplicationRef> <UserData id="id489" type="FormAttributes"> <UserValue value="CHR-10816-16_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="512.877" title="weight"></UserValue> <UserValue type="real" value="512.877" title="mod_weight"></UserValue> <UserValue type="real" value="512877" title="volume"></UserValue> <UserValue type="real" value="688591" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="13" title="pnt_min_x"></UserValue> <UserValue type="real" value="-358.459" title="pnt_min_y"></UserValue> <UserValue type="real" value="13" title="pnt_min_z"></UserValue> <UserValue type="real" value="971.297" title="pnt_max_x"></UserValue> <UserValue type="real" value="-60.2797" title="pnt_max_y"></UserValue> <UserValue type="real" value="295" title="pnt_max_z"></UserValue> <UserValue type="real" value="10942300" title="inertia_x"></UserValue> <UserValue type="real" value="38452700" title="inertia_y"></UserValue> <UserValue type="real" value="41816300" title="inertia_z"></UserValue> <UserValue type="real" value="-14140900" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="481.631" title="gravity_x"></UserValue> <UserValue type="real" value="-207.327" title="gravity_y"></UserValue> <UserValue type="real" value="154" title="gravity_z"></UserValue></UserData></Form> <Form id="id493" name="CHR-10816-16_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CjH1M_ntwsW4BC" application="Teamcenter" label="CjH1M_ntwsW4BC"></ApplicationRef> <UserData id="id494" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id503" name="CHR-10816-18_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="C3I1M_ntwsW4BC" application="Teamcenter" label="C3I1M_ntwsW4BC"></ApplicationRef> <UserData id="id504" type="FormAttributes"> <UserValue value="CHR-10816-18_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="150.05" title="weight"></UserValue> <UserValue type="real" value="150.05" title="mod_weight"></UserValue> <UserValue type="real" value="150050" title="volume"></UserValue> <UserValue type="real" value="209201" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-11" title="pnt_min_x"></UserValue> <UserValue type="real" value="-14.4657" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="1011.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="0" title="pnt_max_y"></UserValue> <UserValue type="real" value="320" title="pnt_max_z"></UserValue> <UserValue type="real" value="2762260" title="inertia_x"></UserValue> <UserValue type="real" value="19820000" title="inertia_y"></UserValue> <UserValue type="real" value="17062300" title="inertia_z"></UserValue> <UserValue type="real" value="-1791.39" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="492.67" title="gravity_x"></UserValue> <UserValue type="real" value="-2.96362" title="gravity_y"></UserValue> <UserValue type="real" value="154" title="gravity_z"></UserValue></UserData></Form> <Form id="id506" name="CHR-10816-18_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="CzD1M_ntwsW4BC" application="Teamcenter" label="CzD1M_ntwsW4BC"></ApplicationRef> <UserData id="id509" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id507" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id508" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id513" name="CHR-10816-18_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="CvK1M_ntwsW4BC" application="Teamcenter" label="CvK1M_ntwsW4BC"></ApplicationRef> <UserData id="id514" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id523" name="CHR-10816-20_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="C$G1M_ntwsW4BC" application="Teamcenter" label="C$G1M_ntwsW4BC"></ApplicationRef> <UserData id="id526" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id524" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id525" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id528" name="CHR-10816-20_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SDL1M_ntwsW4BC" application="Teamcenter" label="SDL1M_ntwsW4BC"></ApplicationRef> <UserData id="id529" type="FormAttributes"> <UserValue value="CHR-10816-20_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="12.0963" title="weight"></UserValue> <UserValue type="real" value="12.0963" title="mod_weight"></UserValue> <UserValue type="real" value="12096.3" title="volume"></UserValue> <UserValue type="real" value="9541.35" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-11" title="pnt_min_x"></UserValue> <UserValue type="real" value="-4.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="28.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="153.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="30517.9" title="inertia_x"></UserValue> <UserValue type="real" value="31489.8" title="inertia_y"></UserValue> <UserValue type="real" value="990.121" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="1569.58" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="3.03246" title="gravity_x"></UserValue> <UserValue type="real" value="-3" title="gravity_y"></UserValue> <UserValue type="real" value="65.9843" title="gravity_z"></UserValue></UserData></Form> <Form id="id533" name="CHR-10816-20_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="C7N1M_ntwsW4BC" application="Teamcenter" label="C7N1M_ntwsW4BC"></ApplicationRef> <UserData id="id534" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id543" name="CHR-10816-24_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SLJ1M_ntwsW4BC" application="Teamcenter" label="SLJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id546" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id544" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id545" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id548" name="CHR-10816-24_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SPO1M_ntwsW4BC" application="Teamcenter" label="SPO1M_ntwsW4BC"></ApplicationRef> <UserData id="id549" type="FormAttributes"> <UserValue value="CHR-10816-24_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="62.5916" title="weight"></UserValue> <UserValue type="real" value="62.5916" title="mod_weight"></UserValue> <UserValue type="real" value="62591.6" title="volume"></UserValue> <UserValue type="real" value="47898.4" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="29.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-4.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="901" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="13" title="pnt_max_z"></UserValue> <UserValue type="real" value="3416.57" title="inertia_x"></UserValue> <UserValue type="real" value="3955590" title="inertia_y"></UserValue> <UserValue type="real" value="3952270" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="43.2827" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="466.574" title="gravity_x"></UserValue> <UserValue type="real" value="-3" title="gravity_y"></UserValue> <UserValue type="real" value="0.522135" title="gravity_z"></UserValue></UserData></Form> <Form id="id553" name="CHR-10816-24_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SLA1M_ntwsW4BC" application="Teamcenter" label="SLA1M_ntwsW4BC"></ApplicationRef> <UserData id="id554" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id563" name="CHR-10816-22_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SXM1M_ntwsW4BC" application="Teamcenter" label="SXM1M_ntwsW4BC"></ApplicationRef> <UserData id="id566" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id564" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id565" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id568" name="CHR-10816-22_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SfB1M_ntwsW4BC" application="Teamcenter" label="SfB1M_ntwsW4BC"></ApplicationRef> <UserData id="id569" type="FormAttributes"> <UserValue value="CHR-10816-22_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="15.6392" title="weight"></UserValue> <UserValue type="real" value="15.6392" title="mod_weight"></UserValue> <UserValue type="real" value="15639.2" title="volume"></UserValue> <UserValue type="real" value="12184.5" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="902" title="pnt_min_x"></UserValue> <UserValue type="real" value="-4.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="1011.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="153.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="39396.3" title="inertia_x"></UserValue> <UserValue type="real" value="54338.6" title="inertia_y"></UserValue> <UserValue type="real" value="14965.7" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-17602.2" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="976.439" title="gravity_x"></UserValue> <UserValue type="real" value="-3" title="gravity_y"></UserValue> <UserValue type="real" value="52.9521" title="gravity_z"></UserValue></UserData></Form> <Form id="id573" name="CHR-10816-22_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SXD1M_ntwsW4BC" application="Teamcenter" label="SXD1M_ntwsW4BC"></ApplicationRef> <UserData id="id574" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id583" name="CHR-10816-20_AF1/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SjP1M_ntwsW4BC" application="Teamcenter" label="SjP1M_ntwsW4BC"></ApplicationRef> <UserData id="id586" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id584" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id585" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id588" name="CHR-10816-20_AF1/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="SrE1M_ntwsW4BC" application="Teamcenter" label="SrE1M_ntwsW4BC"></ApplicationRef> <UserData id="id589" type="FormAttributes"> <UserValue value="CHR-10816-20_AF1" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="12.0963" title="weight"></UserValue> <UserValue type="real" value="12.0963" title="mod_weight"></UserValue> <UserValue type="real" value="12096.3" title="volume"></UserValue> <UserValue type="real" value="9541.35" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-11" title="pnt_min_x"></UserValue> <UserValue type="real" value="-4.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="28.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="153.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="30517.9" title="inertia_x"></UserValue> <UserValue type="real" value="31489.8" title="inertia_y"></UserValue> <UserValue type="real" value="990.121" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="1569.58" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="3.03246" title="gravity_x"></UserValue> <UserValue type="real" value="-3" title="gravity_y"></UserValue> <UserValue type="real" value="65.9843" title="gravity_z"></UserValue></UserData></Form> <Form id="id593" name="CHR-10816-20_AF1" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SjG1M_ntwsW4BC" application="Teamcenter" label="SjG1M_ntwsW4BC"></ApplicationRef> <UserData id="id594" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id603" name="CHR-10816-24_AF1/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="S3H1M_ntwsW4BC" application="Teamcenter" label="S3H1M_ntwsW4BC"></ApplicationRef> <UserData id="id604" type="FormAttributes"> <UserValue value="CHR-10816-24_AF1" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="62.5916" title="weight"></UserValue> <UserValue type="real" value="62.5916" title="mod_weight"></UserValue> <UserValue type="real" value="62591.6" title="volume"></UserValue> <UserValue type="real" value="47898.4" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="29.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-4.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="901" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="13" title="pnt_max_z"></UserValue> <UserValue type="real" value="3416.57" title="inertia_x"></UserValue> <UserValue type="real" value="3955590" title="inertia_y"></UserValue> <UserValue type="real" value="3952270" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="43.2827" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="466.574" title="gravity_x"></UserValue> <UserValue type="real" value="-3" title="gravity_y"></UserValue> <UserValue type="real" value="0.522135" title="gravity_z"></UserValue></UserData></Form> <Form id="id606" name="CHR-10816-24_AF1/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="SzC1M_ntwsW4BC" application="Teamcenter" label="SzC1M_ntwsW4BC"></ApplicationRef> <UserData id="id609" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id607" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id608" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id613" name="CHR-10816-24_AF1" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="SvJ1M_ntwsW4BC" application="Teamcenter" label="SvJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id614" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id623" name="CHR-10816-22_AF1/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="S$F1M_ntwsW4BC" application="Teamcenter" label="S$F1M_ntwsW4BC"></ApplicationRef> <UserData id="id626" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id624" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id625" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id628" name="CHR-10816-22_AF1/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="iDK1M_ntwsW4BC" application="Teamcenter" label="iDK1M_ntwsW4BC"></ApplicationRef> <UserData id="id629" type="FormAttributes"> <UserValue value="CHR-10816-22_AF1" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="15.6392" title="weight"></UserValue> <UserValue type="real" value="15.6392" title="mod_weight"></UserValue> <UserValue type="real" value="15639.2" title="volume"></UserValue> <UserValue type="real" value="12184.5" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="902" title="pnt_min_x"></UserValue> <UserValue type="real" value="-4.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-12" title="pnt_min_z"></UserValue> <UserValue type="real" value="1011.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="-1.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="153.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="39396.3" title="inertia_x"></UserValue> <UserValue type="real" value="54338.6" title="inertia_y"></UserValue> <UserValue type="real" value="14965.7" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="-17602.2" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="976.439" title="gravity_x"></UserValue> <UserValue type="real" value="-3" title="gravity_y"></UserValue> <UserValue type="real" value="52.9521" title="gravity_z"></UserValue></UserData></Form> <Form id="id633" name="CHR-10816-22_AF1" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="S7M1M_ntwsW4BC" application="Teamcenter" label="S7M1M_ntwsW4BC"></ApplicationRef> <UserData id="id634" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id643" name="CHR-10816-26_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="iLI1M_ntwsW4BC" application="Teamcenter" label="iLI1M_ntwsW4BC"></ApplicationRef> <UserData id="id646" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id644" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id645" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id648" name="CHR-10816-26_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="iPN1M_ntwsW4BC" application="Teamcenter" label="iPN1M_ntwsW4BC"></ApplicationRef> <UserData id="id649" type="FormAttributes"> <UserValue value="CHR-10816-26_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="20.9753" title="weight"></UserValue> <UserValue type="real" value="20.9753" title="mod_weight"></UserValue> <UserValue type="real" value="20975.3" title="volume"></UserValue> <UserValue type="real" value="29553.7" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="450.351" title="pnt_min_x"></UserValue> <UserValue type="real" value="-125.458" title="pnt_min_y"></UserValue> <UserValue type="real" value="17.5" title="pnt_min_z"></UserValue> <UserValue type="real" value="464.401" title="pnt_max_x"></UserValue> <UserValue type="real" value="-70" title="pnt_max_y"></UserValue> <UserValue type="real" value="290.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="140232" title="inertia_x"></UserValue> <UserValue type="real" value="134063" title="inertia_y"></UserValue> <UserValue type="real" value="6464.22" title="inertia_z"></UserValue> <UserValue type="real" value="-257.649" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="454.82" title="gravity_x"></UserValue> <UserValue type="real" value="-92.6882" title="gravity_y"></UserValue> <UserValue type="real" value="154" title="gravity_z"></UserValue></UserData></Form> <Form id="id653" name="CHR-10816-26_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="iHP1M_ntwsW4BC" application="Teamcenter" label="iHP1M_ntwsW4BC"></ApplicationRef> <UserData id="id654" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id663" name="850-1009073_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="iXL1M_ntwsW4BC" application="Teamcenter" label="iXL1M_ntwsW4BC"></ApplicationRef> <UserData id="id666" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id664" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id665" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id668" name="850-1009073_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="ifA1M_ntwsW4BC" application="Teamcenter" label="ifA1M_ntwsW4BC"></ApplicationRef> <UserData id="id669" type="FormAttributes"> <UserValue value="850-1009073_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="15.7192" title="weight"></UserValue> <UserValue type="real" value="15.7192" title="mod_weight"></UserValue> <UserValue type="real" value="15719.2" title="volume"></UserValue> <UserValue type="real" value="6221" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="0" title="pnt_min_x"></UserValue> <UserValue type="real" value="-22.5" title="pnt_min_y"></UserValue> <UserValue type="real" value="-22.4966" title="pnt_min_z"></UserValue> <UserValue type="real" value="29.1924" title="pnt_max_x"></UserValue> <UserValue type="real" value="22.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="22.4966" title="pnt_max_z"></UserValue> <UserValue type="real" value="3083.18" title="inertia_x"></UserValue> <UserValue type="real" value="2243.33" title="inertia_y"></UserValue> <UserValue type="real" value="2292.2" title="inertia_z"></UserValue> <UserValue type="real" value="-168.551" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="10.4413" title="gravity_x"></UserValue> <UserValue type="real" value="2.33371" title="gravity_y"></UserValue> <UserValue type="real" value="1.89357e-006" title="gravity_z"></UserValue></UserData></Form> <Form id="id673" name="850-1009073_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="iXC1M_ntwsW4BC" application="Teamcenter" label="iXC1M_ntwsW4BC"></ApplicationRef> <UserData id="id674" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id683" name="236-1009024-B/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="ijO1M_ntwsW4BC" application="Teamcenter" label="ijO1M_ntwsW4BC"></ApplicationRef> <UserData id="id686" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id684" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id685" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id688" name="236-1009024-B/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="irD1M_ntwsW4BC" application="Teamcenter" label="irD1M_ntwsW4BC"></ApplicationRef> <UserData id="id689" type="FormAttributes"> <UserValue value="236-1009024-B" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="5.93126" title="weight"></UserValue> <UserValue type="real" value="5.93126" title="mod_weight"></UserValue> <UserValue type="real" value="5931.26" title="volume"></UserValue> <UserValue type="real" value="3055.24" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-0.000147356" title="pnt_min_x"></UserValue> <UserValue type="real" value="-18" title="pnt_min_y"></UserValue> <UserValue type="real" value="-18" title="pnt_min_z"></UserValue> <UserValue type="real" value="12.0001" title="pnt_max_x"></UserValue> <UserValue type="real" value="18" title="pnt_max_y"></UserValue> <UserValue type="real" value="18" title="pnt_max_z"></UserValue> <UserValue type="real" value="1377.83" title="inertia_x"></UserValue> <UserValue type="real" value="746.149" title="inertia_y"></UserValue> <UserValue type="real" value="746.149" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="5.64237" title="gravity_x"></UserValue> <UserValue type="real" value="0" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id693" name="236-1009024-B" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="ijF1M_ntwsW4BC" application="Teamcenter" label="ijF1M_ntwsW4BC"></ApplicationRef> <UserData id="id694" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id703" name="201-1009042-B/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="i3G1M_ntwsW4BC" application="Teamcenter" label="i3G1M_ntwsW4BC"></ApplicationRef> <UserData id="id704" type="FormAttributes"> <UserValue value="201-1009042-B" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="0.703716" title="weight"></UserValue> <UserValue type="real" value="0.703716" title="mod_weight"></UserValue> <UserValue type="real" value="703.716" title="volume"></UserValue> <UserValue type="real" value="1055.57" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-16" title="pnt_min_x"></UserValue> <UserValue type="real" value="-16" title="pnt_min_y"></UserValue> <UserValue type="real" value="-2" title="pnt_min_z"></UserValue> <UserValue type="real" value="16" title="pnt_max_x"></UserValue> <UserValue type="real" value="16" title="pnt_max_y"></UserValue> <UserValue type="real" value="0" title="pnt_max_z"></UserValue> <UserValue type="real" value="70.6062" title="inertia_x"></UserValue> <UserValue type="real" value="70.6062" title="inertia_y"></UserValue> <UserValue type="real" value="140.743" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="-1.58375e-006" title="gravity_y"></UserValue> <UserValue type="real" value="-1" title="gravity_z"></UserValue></UserData></Form> <Form id="id706" name="201-1009042-B/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="izB1M_ntwsW4BC" application="Teamcenter" label="izB1M_ntwsW4BC"></ApplicationRef> <UserData id="id709" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id707" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id708" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id713" name="201-1009042-B" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="ivI1M_ntwsW4BC" application="Teamcenter" label="ivI1M_ntwsW4BC"></ApplicationRef> <UserData id="id714" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id723" name="316180-P2/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="i$E1M_ntwsW4BC" application="Teamcenter" label="i$E1M_ntwsW4BC"></ApplicationRef> <UserData id="id726" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id724" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id725" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id728" name="316180-P2/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="yDJ1M_ntwsW4BC" application="Teamcenter" label="yDJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id729" type="FormAttributes"> <UserValue value="316180-P2" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="16.978" title="weight"></UserValue> <UserValue type="real" value="16.978" title="mod_weight"></UserValue> <UserValue type="real" value="16978" title="volume"></UserValue> <UserValue type="real" value="4190.56" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-15.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-18.4752" title="pnt_min_y"></UserValue> <UserValue type="real" value="-16" title="pnt_min_z"></UserValue> <UserValue type="real" value="11.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="18.4752" title="pnt_max_y"></UserValue> <UserValue type="real" value="16" title="pnt_max_z"></UserValue> <UserValue type="real" value="1930.62" title="inertia_x"></UserValue> <UserValue type="real" value="1958.06" title="inertia_y"></UserValue> <UserValue type="real" value="1958.06" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0.325571" title="gravity_x"></UserValue> <UserValue type="real" value="0" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id733" name="316180-P2" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="i7L1M_ntwsW4BC" application="Teamcenter" label="i7L1M_ntwsW4BC"></ApplicationRef> <UserData id="id734" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id743" name="CHR-10816-28_AF0/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yLH1M_ntwsW4BC" application="Teamcenter" label="yLH1M_ntwsW4BC"></ApplicationRef> <UserData id="id746" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id744" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id745" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id748" name="CHR-10816-28_AF0/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="yPM1M_ntwsW4BC" application="Teamcenter" label="yPM1M_ntwsW4BC"></ApplicationRef> <UserData id="id749" type="FormAttributes"> <UserValue value="CHR-10816-28_AF0" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="92.3356" title="weight"></UserValue> <UserValue type="real" value="92.3356" title="mod_weight"></UserValue> <UserValue type="real" value="92335.6" title="volume"></UserValue> <UserValue type="real" value="125645" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="210" title="pnt_min_x"></UserValue> <UserValue type="real" value="-351.801" title="pnt_min_y"></UserValue> <UserValue type="real" value="17.5" title="pnt_min_z"></UserValue> <UserValue type="real" value="221.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="-71.5" title="pnt_max_y"></UserValue> <UserValue type="real" value="290.5" title="pnt_max_z"></UserValue> <UserValue type="real" value="1200210" title="inertia_x"></UserValue> <UserValue type="real" value="677638" title="inertia_y"></UserValue> <UserValue type="real" value="523079" title="inertia_z"></UserValue> <UserValue type="real" value="-358.207" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="211.172" title="gravity_x"></UserValue> <UserValue type="real" value="-222.001" title="gravity_y"></UserValue> <UserValue type="real" value="154" title="gravity_z"></UserValue></UserData></Form> <Form id="id753" name="CHR-10816-28_AF0" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="yHO1M_ntwsW4BC" application="Teamcenter" label="yHO1M_ntwsW4BC"></ApplicationRef> <UserData id="id754" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id759" name="Karter new/0" accessRefs="#id16" subType="Сб_единица Revision Master" subClass="Сб_единица Revision Master"> <ApplicationRef version="y_P1M_ntwsW4BC" application="Teamcenter" label="y_P1M_ntwsW4BC"></ApplicationRef> <UserData id="id762" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id760" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id761" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id766" name="Karter new" accessRefs="#id16" subType="Сб_единица Master" subClass="Сб_единица Master"> <ApplicationRef version="y_G1M_ntwsW4BC" application="Teamcenter" label="y_G1M_ntwsW4BC"></ApplicationRef> <UserData id="id767" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id776" name="651-C_SW0001/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yXK1M_ntwsW4BC" application="Teamcenter" label="yXK1M_ntwsW4BC"></ApplicationRef> <UserData id="id779" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id777" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id778" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id781" name="651-C_SW0001/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="ybP1M_ntwsW4BC" application="Teamcenter" label="ybP1M_ntwsW4BC"></ApplicationRef> <UserData id="id782" type="FormAttributes"> <UserValue value="651-C_SW0001" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="" title="weight"></UserValue> <UserValue type="real" value="" title="mod_weight"></UserValue> <UserValue type="real" value="" title="volume"></UserValue> <UserValue type="real" value="" title="wetArea"></UserValue> <UserValue type="real" value="" title="density"></UserValue> <UserValue type="real" value="162.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-387.999" title="pnt_min_y"></UserValue> <UserValue type="real" value="-152.007" title="pnt_min_z"></UserValue> <UserValue type="real" value="439.056" title="pnt_max_x"></UserValue> <UserValue type="real" value="381.953" title="pnt_max_y"></UserValue> <UserValue type="real" value="611.993" title="pnt_max_z"></UserValue> <UserValue type="real" value="" title="inertia_x"></UserValue> <UserValue type="real" value="" title="inertia_y"></UserValue> <UserValue type="real" value="" title="inertia_z"></UserValue> <UserValue type="real" value="" title="inertia_prod_x"></UserValue> <UserValue type="real" value="" title="inertia_prod_y"></UserValue> <UserValue type="real" value="" title="inertia_prod_z"></UserValue> <UserValue type="real" value="" title="gravity_x"></UserValue> <UserValue type="real" value="" title="gravity_y"></UserValue> <UserValue type="real" value="" title="gravity_z"></UserValue></UserData></Form> <Form id="id786" name="651-C_SW0001" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="yXB1M_ntwsW4BC" application="Teamcenter" label="yXB1M_ntwsW4BC"></ApplicationRef> <UserData id="id787" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id796" name="110/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yjN1M_ntwsW4BC" application="Teamcenter" label="yjN1M_ntwsW4BC"></ApplicationRef> <UserData id="id799" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id797" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id798" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id801" name="110/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="yrC1M_ntwsW4BC" application="Teamcenter" label="yrC1M_ntwsW4BC"></ApplicationRef> <UserData id="id802" type="FormAttributes"> <UserValue value="110" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="33.5103" title="weight"></UserValue> <UserValue type="real" value="33.5103" title="mod_weight"></UserValue> <UserValue type="real" value="33510.3" title="volume"></UserValue> <UserValue type="real" value="5026.55" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-19.9999" title="pnt_min_x"></UserValue> <UserValue type="real" value="-20" title="pnt_min_y"></UserValue> <UserValue type="real" value="-19.9999" title="pnt_min_z"></UserValue> <UserValue type="real" value="19.9999" title="pnt_max_x"></UserValue> <UserValue type="real" value="20" title="pnt_max_y"></UserValue> <UserValue type="real" value="19.9999" title="pnt_max_z"></UserValue> <UserValue type="real" value="5361.65" title="inertia_x"></UserValue> <UserValue type="real" value="5361.65" title="inertia_y"></UserValue> <UserValue type="real" value="5361.65" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="0" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id806" name="110" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="yjE1M_ntwsW4BC" application="Teamcenter" label="yjE1M_ntwsW4BC"></ApplicationRef> <UserData id="id807" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id816" name="6370-1109131-99/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="y3F1M_ntwsW4BC" application="Teamcenter" label="y3F1M_ntwsW4BC"></ApplicationRef> <UserData id="id817" type="FormAttributes"> <UserValue value="6370-1109131-99" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Aluminium" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="6949.06" title="weight"></UserValue> <UserValue type="real" value="6949.06" title="mod_weight"></UserValue> <UserValue type="real" value="2564230" title="volume"></UserValue> <UserValue type="real" value="143434" title="wetArea"></UserValue> <UserValue type="real" value="0.00271" title="density"></UserValue> <UserValue type="real" value="-146.114" title="pnt_min_x"></UserValue> <UserValue type="real" value="-63.9591" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="86.9598" title="pnt_max_x"></UserValue> <UserValue type="real" value="199.833" title="pnt_max_y"></UserValue> <UserValue type="real" value="269.893" title="pnt_max_z"></UserValue> <UserValue type="real" value="64969700" title="inertia_x"></UserValue> <UserValue type="real" value="50925100" title="inertia_y"></UserValue> <UserValue type="real" value="45490200" title="inertia_z"></UserValue> <UserValue type="real" value="13217500" title="inertia_prod_x"></UserValue> <UserValue type="real" value="15587100" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-27572500" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-24.4348" title="gravity_x"></UserValue> <UserValue type="real" value="82.0325" title="gravity_y"></UserValue> <UserValue type="real" value="138.225" title="gravity_z"></UserValue></UserData></Form> <Form id="id819" name="6370-1109131-99/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="yzA1M_ntwsW4BC" application="Teamcenter" label="yzA1M_ntwsW4BC"></ApplicationRef> <UserData id="id822" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id820" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id821" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id826" name="6370-1109131-99" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="yvH1M_ntwsW4BC" application="Teamcenter" label="yvH1M_ntwsW4BC"></ApplicationRef> <UserData id="id827" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id836" name="63674P-1308005/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="DAI1M_ntwsW4BC" application="Teamcenter" label="DAI1M_ntwsW4BC"></ApplicationRef> <UserData id="id837" type="FormAttributes"> <UserValue value="63674P-1308005" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Сталь Ст3сп ГОСТ 380-94" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="569.614" title="weight"></UserValue> <UserValue type="real" value="569.614" title="mod_weight"></UserValue> <UserValue type="real" value="72562.3" title="volume"></UserValue> <UserValue type="real" value="33029.3" title="wetArea"></UserValue> <UserValue type="real" value="0.00785" title="density"></UserValue> <UserValue type="real" value="-32.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="-120" title="pnt_min_y"></UserValue> <UserValue type="real" value="-30" title="pnt_min_z"></UserValue> <UserValue type="real" value="32.5" title="pnt_max_x"></UserValue> <UserValue type="real" value="122" title="pnt_max_y"></UserValue> <UserValue type="real" value="101.486" title="pnt_max_z"></UserValue> <UserValue type="real" value="3765070" title="inertia_x"></UserValue> <UserValue type="real" value="515335" title="inertia_y"></UserValue> <UserValue type="real" value="3496780" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="1029120" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="16.3419" title="gravity_y"></UserValue> <UserValue type="real" value="16.097" title="gravity_z"></UserValue></UserData></Form> <Form id="id839" name="63674P-1308005/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="y$D1M_ntwsW4BC" application="Teamcenter" label="y$D1M_ntwsW4BC"></ApplicationRef> <UserData id="id842" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id840" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id841" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id846" name="63674P-1308005" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="y7K1M_ntwsW4BC" application="Teamcenter" label="y7K1M_ntwsW4BC"></ApplicationRef> <UserData id="id847" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id856" name="6370-1109131-98/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="DIG1M_ntwsW4BC" application="Teamcenter" label="DIG1M_ntwsW4BC"></ApplicationRef> <UserData id="id859" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id857" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id858" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id861" name="6370-1109131-98/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="DML1M_ntwsW4BC" application="Teamcenter" label="DML1M_ntwsW4BC"></ApplicationRef> <UserData id="id862" type="FormAttributes"> <UserValue value="6370-1109131-98" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="Aluminium" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="1707.21" title="weight"></UserValue> <UserValue type="real" value="1707.21" title="mod_weight"></UserValue> <UserValue type="real" value="629966" title="volume"></UserValue> <UserValue type="real" value="243988" title="wetArea"></UserValue> <UserValue type="real" value="0.00271" title="density"></UserValue> <UserValue type="real" value="-147.255" title="pnt_min_x"></UserValue> <UserValue type="real" value="-63.9591" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="86.9598" title="pnt_max_x"></UserValue> <UserValue type="real" value="201.651" title="pnt_max_y"></UserValue> <UserValue type="real" value="305" title="pnt_max_z"></UserValue> <UserValue type="real" value="21436300" title="inertia_x"></UserValue> <UserValue type="real" value="18525500" title="inertia_y"></UserValue> <UserValue type="real" value="13316500" title="inertia_z"></UserValue> <UserValue type="real" value="4520940" title="inertia_prod_x"></UserValue> <UserValue type="real" value="5993360" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-7684420" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-35.936" title="gravity_x"></UserValue> <UserValue type="real" value="59.3549" title="gravity_y"></UserValue> <UserValue type="real" value="145.326" title="gravity_z"></UserValue></UserData></Form> <Form id="id866" name="6370-1109131-98" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="DEN1M_ntwsW4BC" application="Teamcenter" label="DEN1M_ntwsW4BC"></ApplicationRef> <UserData id="id867" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id876" name="114/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="DUJ1M_ntwsW4BC" application="Teamcenter" label="DUJ1M_ntwsW4BC"></ApplicationRef> <UserData id="id879" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id877" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id878" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id881" name="114/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="DYO1M_ntwsW4BC" application="Teamcenter" label="DYO1M_ntwsW4BC"></ApplicationRef> <UserData id="id882" type="FormAttributes"> <UserValue value="114" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="1.59279" title="weight"></UserValue> <UserValue type="real" value="1.59279" title="mod_weight"></UserValue> <UserValue type="real" value="1592.79" title="volume"></UserValue> <UserValue type="real" value="3430.62" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="67.61" title="pnt_min_x"></UserValue> <UserValue type="real" value="-119.93" title="pnt_min_y"></UserValue> <UserValue type="real" value="-276.982" title="pnt_min_z"></UserValue> <UserValue type="real" value="298.81" title="pnt_max_x"></UserValue> <UserValue type="real" value="320.2" title="pnt_max_y"></UserValue> <UserValue type="real" value="119.93" title="pnt_max_z"></UserValue> <UserValue type="real" value="10133.8" title="inertia_x"></UserValue> <UserValue type="real" value="3792.78" title="inertia_y"></UserValue> <UserValue type="real" value="6341.24" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-2977.63" title="inertia_prod_z"></UserValue> <UserValue type="real" value="157.5" title="gravity_x"></UserValue> <UserValue type="real" value="240.333" title="gravity_y"></UserValue> <UserValue type="real" value="-48.3333" title="gravity_z"></UserValue></UserData></Form> <Form id="id886" name="114" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="DUA1M_ntwsW4BC" application="Teamcenter" label="DUA1M_ntwsW4BC"></ApplicationRef> <UserData id="id887" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id896" name="115/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="DgM1M_ntwsW4BC" application="Teamcenter" label="DgM1M_ntwsW4BC"></ApplicationRef> <UserData id="id899" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id897" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id898" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id901" name="115/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="DoB1M_ntwsW4BC" application="Teamcenter" label="DoB1M_ntwsW4BC"></ApplicationRef> <UserData id="id902" type="FormAttributes"> <UserValue value="115" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="" title="weight"></UserValue> <UserValue type="real" value="" title="mod_weight"></UserValue> <UserValue type="real" value="" title="volume"></UserValue> <UserValue type="real" value="" title="wetArea"></UserValue> <UserValue type="real" value="" title="density"></UserValue> <UserValue type="real" value="-472.1" title="pnt_min_x"></UserValue> <UserValue type="real" value="6.01211" title="pnt_min_y"></UserValue> <UserValue type="real" value="-30.6894" title="pnt_min_z"></UserValue> <UserValue type="real" value="-89.2022" title="pnt_max_x"></UserValue> <UserValue type="real" value="609.876" title="pnt_max_y"></UserValue> <UserValue type="real" value="533.548" title="pnt_max_z"></UserValue> <UserValue type="real" value="" title="inertia_x"></UserValue> <UserValue type="real" value="" title="inertia_y"></UserValue> <UserValue type="real" value="" title="inertia_z"></UserValue> <UserValue type="real" value="" title="inertia_prod_x"></UserValue> <UserValue type="real" value="" title="inertia_prod_y"></UserValue> <UserValue type="real" value="" title="inertia_prod_z"></UserValue> <UserValue type="real" value="" title="gravity_x"></UserValue> <UserValue type="real" value="" title="gravity_y"></UserValue> <UserValue type="real" value="" title="gravity_z"></UserValue></UserData></Form> <Form id="id906" name="115" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="DgD1M_ntwsW4BC" application="Teamcenter" label="DgD1M_ntwsW4BC"></ApplicationRef> <UserData id="id907" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id916" name="116/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="D0E1M_ntwsW4BC" application="Teamcenter" label="D0E1M_ntwsW4BC"></ApplicationRef> <UserData id="id917" type="FormAttributes"> <UserValue value="116" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="1609.36" title="weight"></UserValue> <UserValue type="real" value="1609.36" title="mod_weight"></UserValue> <UserValue type="real" value="1609360" title="volume"></UserValue> <UserValue type="real" value="110454" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-60" title="pnt_min_x"></UserValue> <UserValue type="real" value="-10" title="pnt_min_y"></UserValue> <UserValue type="real" value="-90" title="pnt_min_z"></UserValue> <UserValue type="real" value="89" title="pnt_max_x"></UserValue> <UserValue type="real" value="170" title="pnt_max_y"></UserValue> <UserValue type="real" value="10" title="pnt_max_z"></UserValue> <UserValue type="real" value="5358730" title="inertia_x"></UserValue> <UserValue type="real" value="2661950" title="inertia_y"></UserValue> <UserValue type="real" value="5564860" title="inertia_z"></UserValue> <UserValue type="real" value="-214160" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="41.0097" title="gravity_x"></UserValue> <UserValue type="real" value="78.126" title="gravity_y"></UserValue> <UserValue type="real" value="-40" title="gravity_z"></UserValue></UserData></Form> <Form id="id919" name="116/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="DsP1M_ntwsW4BC" application="Teamcenter" label="DsP1M_ntwsW4BC"></ApplicationRef> <UserData id="id922" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id920" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id921" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id926" name="116" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="DsG1M_ntwsW4BC" application="Teamcenter" label="DsG1M_ntwsW4BC"></ApplicationRef> <UserData id="id927" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id936" name="117/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="D8C1M_ntwsW4BC" application="Teamcenter" label="D8C1M_ntwsW4BC"></ApplicationRef> <UserData id="id939" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id937" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id938" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id941" name="117/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="TAH1M_ntwsW4BC" application="Teamcenter" label="TAH1M_ntwsW4BC"></ApplicationRef> <UserData id="id942" type="FormAttributes"> <UserValue value="117" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="2119.52" title="weight"></UserValue> <UserValue type="real" value="2119.52" title="mod_weight"></UserValue> <UserValue type="real" value="2119520" title="volume"></UserValue> <UserValue type="real" value="130929" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-99.5" title="pnt_min_x"></UserValue> <UserValue type="real" value="1016" title="pnt_min_y"></UserValue> <UserValue type="real" value="-54" title="pnt_min_z"></UserValue> <UserValue type="real" value="50" title="pnt_max_x"></UserValue> <UserValue type="real" value="1222" title="pnt_max_y"></UserValue> <UserValue type="real" value="74" title="pnt_max_z"></UserValue> <UserValue type="real" value="8154790" title="inertia_x"></UserValue> <UserValue type="real" value="4691860" title="inertia_y"></UserValue> <UserValue type="real" value="9030570" title="inertia_z"></UserValue> <UserValue type="real" value="1046470" title="inertia_prod_x"></UserValue> <UserValue type="real" value="103718" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-410382" title="inertia_prod_z"></UserValue> <UserValue type="real" value="-18.8965" title="gravity_x"></UserValue> <UserValue type="real" value="1130.51" title="gravity_y"></UserValue> <UserValue type="real" value="7.41039" title="gravity_z"></UserValue></UserData></Form> <Form id="id946" name="117" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="D4J1M_ntwsW4BC" application="Teamcenter" label="D4J1M_ntwsW4BC"></ApplicationRef> <UserData id="id947" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id960" name="161/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="TUA1M_ntwsW4BC" application="Teamcenter" label="TUA1M_ntwsW4BC"></ApplicationRef> <UserData id="id963" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id961" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id962" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id965" name="161/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="TYF1M_ntwsW4BC" application="Teamcenter" label="TYF1M_ntwsW4BC"></ApplicationRef> <UserData id="id966" type="FormAttributes"> <UserValue value="161" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="153.007" title="weight"></UserValue> <UserValue type="real" value="153.007" title="mod_weight"></UserValue> <UserValue type="real" value="153007" title="volume"></UserValue> <UserValue type="real" value="48107.3" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="0" title="pnt_min_x"></UserValue> <UserValue type="real" value="-60" title="pnt_min_y"></UserValue> <UserValue type="real" value="-59.9902" title="pnt_min_z"></UserValue> <UserValue type="real" value="33.5885" title="pnt_max_x"></UserValue> <UserValue type="real" value="60" title="pnt_max_y"></UserValue> <UserValue type="real" value="90.4274" title="pnt_max_z"></UserValue> <UserValue type="real" value="443641" title="inertia_x"></UserValue> <UserValue type="real" value="292935" title="inertia_y"></UserValue> <UserValue type="real" value="176096" title="inertia_z"></UserValue> <UserValue type="real" value="-359.878" title="inertia_prod_x"></UserValue> <UserValue type="real" value="6509.4" title="inertia_prod_y"></UserValue> <UserValue type="real" value="7037.61" title="inertia_prod_z"></UserValue> <UserValue type="real" value="20.9906" title="gravity_x"></UserValue> <UserValue type="real" value="-0.789529" title="gravity_y"></UserValue> <UserValue type="real" value="14.2369" title="gravity_z"></UserValue></UserData></Form> <Form id="id970" name="161" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="TQH1M_ntwsW4BC" application="Teamcenter" label="TQH1M_ntwsW4BC"></ApplicationRef> <UserData id="id971" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id980" name="162/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="TgD1M_ntwsW4BC" application="Teamcenter" label="TgD1M_ntwsW4BC"></ApplicationRef> <UserData id="id983" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id981" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id982" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id985" name="162/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="TkI1M_ntwsW4BC" application="Teamcenter" label="TkI1M_ntwsW4BC"></ApplicationRef> <UserData id="id986" type="FormAttributes"> <UserValue value="162" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="18.3262" title="weight"></UserValue> <UserValue type="real" value="18.3262" title="mod_weight"></UserValue> <UserValue type="real" value="18326.2" title="volume"></UserValue> <UserValue type="real" value="6356.26" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-6" title="pnt_min_x"></UserValue> <UserValue type="real" value="-15" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="6" title="pnt_max_x"></UserValue> <UserValue type="real" value="70" title="pnt_max_y"></UserValue> <UserValue type="real" value="98" title="pnt_max_z"></UserValue> <UserValue type="real" value="25189.2" title="inertia_x"></UserValue> <UserValue type="real" value="16143.8" title="inertia_y"></UserValue> <UserValue type="real" value="9377.29" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-7555.9" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="14.6923" title="gravity_y"></UserValue> <UserValue type="real" value="64.4183" title="gravity_z"></UserValue></UserData></Form> <Form id="id990" name="162" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="TcK1M_ntwsW4BC" application="Teamcenter" label="TcK1M_ntwsW4BC"></ApplicationRef> <UserData id="id991" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id1000" name="163/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="TsG1M_ntwsW4BC" application="Teamcenter" label="TsG1M_ntwsW4BC"></ApplicationRef> <UserData id="id1003" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id1001" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id1002" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id1005" name="163/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="TwL1M_ntwsW4BC" application="Teamcenter" label="TwL1M_ntwsW4BC"></ApplicationRef> <UserData id="id1006" type="FormAttributes"> <UserValue value="163" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="33.4993" title="weight"></UserValue> <UserValue type="real" value="33.4993" title="mod_weight"></UserValue> <UserValue type="real" value="33499.3" title="volume"></UserValue> <UserValue type="real" value="8812.29" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="-8" title="pnt_min_x"></UserValue> <UserValue type="real" value="-15" title="pnt_min_y"></UserValue> <UserValue type="real" value="0" title="pnt_min_z"></UserValue> <UserValue type="real" value="8" title="pnt_max_x"></UserValue> <UserValue type="real" value="70" title="pnt_max_y"></UserValue> <UserValue type="real" value="108" title="pnt_max_z"></UserValue> <UserValue type="real" value="51408.3" title="inertia_x"></UserValue> <UserValue type="real" value="35327.5" title="inertia_y"></UserValue> <UserValue type="real" value="17161.4" title="inertia_z"></UserValue> <UserValue type="real" value="0" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="-15252.6" title="inertia_prod_z"></UserValue> <UserValue type="real" value="0" title="gravity_x"></UserValue> <UserValue type="real" value="14.4444" title="gravity_y"></UserValue> <UserValue type="real" value="68.4403" title="gravity_z"></UserValue></UserData></Form> <Form id="id1010" name="163" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="ToN1M_ntwsW4BC" application="Teamcenter" label="ToN1M_ntwsW4BC"></ApplicationRef> <UserData id="id1011" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id1020" name="164/0" accessRefs="#id16" subType="Деталь Revision Master" subClass="Деталь Revision Master"> <ApplicationRef version="T4J1M_ntwsW4BC" application="Teamcenter" label="T4J1M_ntwsW4BC"></ApplicationRef> <UserData id="id1023" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id1021" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id1022" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id1025" name="164/0" accessRefs="#id16" subType="catia_model_attributes" subClass="catia_model_attributes"> <ApplicationRef version="T8O1M_ntwsW4BC" application="Teamcenter" label="T8O1M_ntwsW4BC"></ApplicationRef> <UserData id="id1026" type="FormAttributes"> <UserValue value="164" title="item_id"></UserValue> <UserValue value="0" title="item_rev_id"></UserValue> <UserValue value="" title="seq_no"></UserValue> <UserValue value="" title="material"></UserValue> <UserValue type="real" value="1" title="coef"></UserValue> <UserValue type="real" value="63.6296" title="weight"></UserValue> <UserValue type="real" value="63.6296" title="mod_weight"></UserValue> <UserValue type="real" value="63629.6" title="volume"></UserValue> <UserValue type="real" value="9119.93" title="wetArea"></UserValue> <UserValue type="real" value="0.001" title="density"></UserValue> <UserValue type="real" value="0" title="pnt_min_x"></UserValue> <UserValue type="real" value="-20" title="pnt_min_y"></UserValue> <UserValue type="real" value="-20" title="pnt_min_z"></UserValue> <UserValue type="real" value="50" title="pnt_max_x"></UserValue> <UserValue type="real" value="30" title="pnt_max_y"></UserValue> <UserValue type="real" value="20" title="pnt_max_z"></UserValue> <UserValue type="real" value="13067.5" title="inertia_x"></UserValue> <UserValue type="real" value="19462" title="inertia_y"></UserValue> <UserValue type="real" value="19953" title="inertia_z"></UserValue> <UserValue type="real" value="196.311" title="inertia_prod_x"></UserValue> <UserValue type="real" value="0" title="inertia_prod_y"></UserValue> <UserValue type="real" value="0" title="inertia_prod_z"></UserValue> <UserValue type="real" value="24.8746" title="gravity_x"></UserValue> <UserValue type="real" value="0.312439" title="gravity_y"></UserValue> <UserValue type="real" value="0" title="gravity_z"></UserValue></UserData></Form> <Form id="id1030" name="164" accessRefs="#id16" subType="Деталь Master" subClass="Деталь Master"> <ApplicationRef version="T4A1M_ntwsW4BC" application="Teamcenter" label="T4A1M_ntwsW4BC"></ApplicationRef> <UserData id="id1031" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id1040" name="118/0" accessRefs="#id16" subType="Сб_единица Revision Master" subClass="Сб_единица Revision Master"> <ApplicationRef version="TIF1M_ntwsW4BC" application="Teamcenter" label="TIF1M_ntwsW4BC"></ApplicationRef> <UserData id="id1043" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id1041" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id1042" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id1047" name="118" accessRefs="#id16" subType="Сб_единица Master" subClass="Сб_единица Master"> <ApplicationRef version="TEM1M_ntwsW4BC" application="Teamcenter" label="TEM1M_ntwsW4BC"></ApplicationRef> <UserData id="id1048" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form> <Form id="id1053" name="6370-1000250-10/0" accessRefs="#id16" subType="Сб_установка Revision Master" subClass="Сб_установка Revision Master"> <ApplicationRef version="yNH1M_ntwsW4BC" application="Teamcenter" label="yNH1M_ntwsW4BC"></ApplicationRef> <UserData id="id1056" type="FormAttributes"> <UserValue value="" title="UAZ_DESIGNER_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICE_1"></UserValue> <UserValue value="" title="UAZ_NOTICE_1_DATE"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN_DATE"></UserValue> <UserValue value="" title="UAZ_CERTIFICATMEN"></UserValue> <UserValue value="" title="UAZ_NOTICEMEN"></UserValue> <UserValue value="" title="UAZ_STATUS_MM"></UserValue> <UserValue value="" title="Z_ALTERNATEMAT"> <UserList id="id1054" type="list"></UserList></UserValue> <UserValue value="" title="Z_FORMAT"></UserValue> <UserValue value="" title="ZORIGSTORE"></UserValue> <UserValue value="" title="Z_REVIEWER"></UserValue> <UserValue value="" title="Z_SMOTRI"></UserValue> <UserValue value="" title="Z_FULLNAME"></UserValue> <UserValue value="" title="Z_NCONTROL"></UserValue> <UserValue value="" title="Z_COMMENTS"></UserValue> <UserValue value="" title="Z_TCONTROL"></UserValue> <UserValue value="" title="Z_CHEEFDEP"></UserValue> <UserValue value="" title="Z_EXTNAME"></UserValue> <UserValue value="0-01-00T00:00:00" title="ZDATEIZVUT"></UserValue> <UserValue value="" title="Z_FIRSTUSE"></UserValue> <UserValue value="" title="Z_INVNOM"></UserValue> <UserValue value="" title="Z_BASEMAT"></UserValue> <UserValue value="" title="Z_CODEOKP"></UserValue> <UserValue value="" title="Z_PRODTYPE"></UserValue> <UserValue value="" title="Z_CREATOR"></UserValue> <UserValue value="" title="Z_IZMCOMMENTS"> <UserList id="id1055" type="list"></UserList></UserValue> <UserValue value="" title="Z_VZINVNOM"></UserValue> <UserValue value="" title="Z_MASSA"></UserValue> <UserValue value="" title="ZPRODSOURC"></UserValue> <UserValue value="" title="ZIZVITEMID"></UserValue> <UserValue value="" title="ZINVNOMDBL"></UserValue> <UserValue value="" title="Z_GENCHECK"></UserValue> <UserValue value="" title="Z_CONTRPAR"></UserValue> <UserValue value="" title="Z_SERTIF"></UserValue></UserData></Form> <Form id="id1060" name="6370-1000250-10" accessRefs="#id16" subType="Сб_установка Master" subClass="Сб_установка Master"> <ApplicationRef version="itA1M_ntwsW4BC" application="Teamcenter" label="itA1M_ntwsW4BC"></ApplicationRef> <UserData id="id1061" type="FormAttributes"> <UserValue value="" title="project_id"></UserValue> <UserValue value="" title="previous_item_id"></UserValue> <UserValue value="" title="serial_number"></UserValue> <UserValue value="" title="item_comment"></UserValue> <UserValue value="" title="user_data_1"></UserValue> <UserValue value="" title="user_data_2"></UserValue> <UserValue value="" title="user_data_3"></UserValue></UserData></Form></PLMXML> XSL <?xml version="1.0" encoding="WINDOWS-1251"?> <xsl:stylesheet version="1.0" xmlns:xsl=" http://www.w3.org/1999/XSL/Transform" xmlns:plm=" http://www.plmxml.org/Schemas/PLMXMLSchema" xmlns="urn:schemas-microsoft-com:office:spreadsheet" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:x="urn:schemas-microsoft-com:office:excel" xmlns:ss="urn:schemas-microsoft-com:office:spreadsheet" xmlns:html=" http://www.w3.org/TR/REC-html40" > <!-- Define global parameters --> <xsl:param name="primaryOccRef" select="//plm:PLMXML/plm:ProductView/@primaryOccurrenceRef"/> <xsl:param name="rootProductID" select="substring-after(//plm:PLMXML/plm:ProductView/plm:Occurrence[@id=$primaryOccRef]/@instancedRef,'#')"/> <xsl:param name="report_date" select="//plm:PLMXML/@date"/> <!-- Note: the variable below can be set as "display:all" or "display:none" --> <!-- to expand all or none internal links at teh report generation" --> <xsl:param name="linkDisplayStatus" select="'display:none'"/> <!-- Define key functions --> <xsl:key name="product" match="plm:ProductRevision" use="@id"/> <xsl:key name="dataset" match="plm:Dataset" use="@id"/> <xsl:key name="form" match="plm:Form" use="@id"/> <xsl:key name="folder" match="plm:Folder" use="@id"/> <xsl:key name="occurrence" match="plm:Occurrence" use="@id"/> <!-- Method for translation --> <xsl:output method="xml" version="1.0" indent="yes"/> <xsl:strip-space elements="*"/> <!-- ******************** --> <!-- Header and structure --> <!-- ******************** --> <xsl:template name="BOMReportHeader"> <xsl:param name="currentElement"/> <xsl:param name="parentOccurrenceID"/> <xsl:param name="title"/> <Workbook xmlns="urn:schemas-microsoft-com:office:spreadsheet" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:x="urn:schemas-microsoft-com:office:excel" xmlns:ss="urn:schemas-microsoft-com:office:spreadsheet" xmlns:html=" http://www.w3.org/TR/REC-html40"> <Styles> <Style ss:ID="heading1"> <Font ss:Color="#000000" ss:Size="20" ss:FontName="GOST type A" ss:Bold="1"/> </Style> <Style ss:ID="heading2"> <Font ss:Color="#000000" ss:Size="12" ss:FontName="GOST type A" ss:Bold="1"/> </Style> <Style ss:ID="heading3"> <Alignment ss:Horizontal="Center" ss:Vertical="Center"/> <Font ss:Color="#000000" ss:Size="18" ss:FontName="GOST type A" ss:Bold="1"/> <Borders> <Border ss:Position="Bottom" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Left" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Right" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Top" ss:LineStyle="Continuous" ss:Weight="2"/> </Borders> </Style> <Style ss:ID="heading4"> <Alignment ss:Horizontal="Center" ss:Vertical="Center"/> <Font ss:Color="#000000" ss:Size="18" ss:FontName="GOST type A" ss:Bold="1"/> <Borders> <Border ss:Position="Bottom" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Left" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Right" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Top" ss:LineStyle="Continuous" ss:Weight="2"/> </Borders> </Style> <Style ss:ID="cell_data"> <Font ss:Color="#000000" ss:Size="14" ss:FontName="GOST type A"/> <Borders> <Border ss:Position="Bottom" ss:LineStyle="Continuous" ss:Weight="1"/> <Border ss:Position="Left" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Right" ss:LineStyle="Continuous" ss:Weight="2"/> <Border ss:Position="Top" ss:LineStyle="Continuous" ss:Weight="1"/> </Borders> <Alignment ss:WrapText="1"/> </Style> </Styles> <Worksheet ss:Name="Sheet1"> <Table> <Column ss:AutoFitWidth="0" ss:Width="120" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="120" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="120" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="60" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="100" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="100" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <Column ss:AutoFitWidth="0" ss:Width="80" AutoFitWidth="1"/> <xsl:call-template name="generateReportData"> <xsl:with-param name="currentElement" select="$currentElement"/> <xsl:with-param name="parentOccurrenceID" select="$parentOccurrenceID"/> </xsl:call-template> </Table> </Worksheet> </Workbook> </xsl:template> <!-- **************** Top Level data element **************** --> <xsl:template match="/"> <xsl:call-template name="generateReportPage"> <xsl:with-param name="currentElement" select="key('product',$rootProductID)"/> <xsl:with-param name="parentOccurrenceID" select="''"/> </xsl:call-template> </xsl:template> <!-- *** Create seperate page for each process and to be linked from its parent **** --> <xsl:template name="generateReportPage"> <xsl:param name="currentElement"/> <xsl:param name="parentOccurrenceID"/> <xsl:choose> <!-- For the root process, we output to the top level report --> <xsl:when test="$rootProductID=$currentElement/@id"> <xsl:call-template name="BOMReportHeader"> <xsl:with-param name="currentElement" select="$currentElement"/> <xsl:with-param name="parentOccurrenceID" select="$parentOccurrenceID"/> <xsl:with-param name="title" select="'PS(BOM) Report'"/> </xsl:call-template> </xsl:when> </xsl:choose> </xsl:template> <!-- ************ generate report data ************* --> <xsl:template name="generateReportData"> <xsl:param name="currentElement"/> <xsl:param name="parentOccurrenceID"/> <xsl:call-template name="generateCurrentProductData"> <xsl:with-param name="prtele" select="$currentElement"/> <xsl:with-param name="parentID" select="$parentOccurrenceID"/> </xsl:call-template> <xsl:call-template name="generateChildProduct"> <xsl:with-param name="currentElement" select="$currentElement"/> <xsl:with-param name="parentID" select="$parentOccurrenceID"/> </xsl:call-template> </xsl:template> <!-- ************ generate current product data ************* --> <xsl:template name="generateCurrentProductData"> <xsl:param name="prtele"/> <xsl:param name="parentID"/> <Row/> <!-- Modify_Here_Column_Parent --> <Row> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Обозначение</Data> </Cell> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Наименование</Data> </Cell> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Тип</Data> </Cell> <!-- <Cell ss:StyleID="heading3"><Data ss:Type="String">Unit of Measure</Data></Cell> --> </Row> <xsl:variable name="itemID" select="$prtele/plm:UserData/plm:UserValue[@title='item_id']/@value"/> <xsl:variable name="itemRev" select="$prtele/plm:UserData/plm:UserValue[@title='item_revision_id']/@value"/> <xsl:variable name="itemName" select="$prtele/plm:UserData/plm:UserValue[@title='object_name']/@value"/> <xsl:variable name="objecttype" select="$prtele/plm:UserData/plm:UserValue[@title='object_type']/@value"/> <xsl:variable name="itemDesc" select="$prtele/plm:UserData/plm:UserValue[@title='object_desc']/@value"/> <xsl:variable name="creationDate" select="$prtele/plm:UserData/plm:UserValue[@title='creation_date']/@value"/> <xsl:variable name="modifiedDate" select="$prtele/plm:UserData/plm:UserValue[@title='last_mod_date']/@value"/> <xsl:variable name="releaseStatusRef" select="$prtele/plm:UserData/plm:UserValue[@title='release_status_list']/plm:UserList/plm:Item/@value"/> <xsl:variable name="releaseStatus" select="//plm:PLMXML/plm:ReleaseStatus[@id=$releaseStatusRef]"/> <xsl:variable name="releaseStatusName" select="$releaseStatus/@name"/> <xsl:variable name="releasedDate" select="$releaseStatus/@dateReleased"/> <xsl:variable name="userRef" select="substring-after($prtele/plm:UserData/plm:UserValue[@title='owning_user']/@dataRef,'#')"/> <xsl:variable name="userName" select="//plm:PLMXML/plm:User[@id=$userRef]/@userId"/> <xsl:variable name="modUserRef" select="substring-after($prtele/plm:UserData/plm:UserValue[@title='last_mod_user']/@dataRef,'#')"/> <xsl:variable name="modUserName" select="//plm:PLMXML/plm:User[@id=$modUserRef]/@userId"/> <xsl:variable name="formRef" select="$prtele/plm:AssociatedForm[@role='IMAN_master_form']/@formRef"/> <xsl:variable name="form" select="key('form',substring-after($formRef,'#'))"/> <xsl:variable name="userData1" select="$form/plm:UserData/plm:UserValue[@title='user_data_1']/@value"/> <xsl:variable name="userData2" select="$form/plm:UserData/plm:UserValue[@title='user_data_2']/@value"/> <xsl:variable name="projectId" select="$form/plm:UserData/plm:UserValue[@title='project_id']/@value"/> <Row> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$itemID"/>/<xsl:value-of select="$itemRev"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$itemName"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$objecttype"/> </Data> </Cell> <!-- was used for 'Unit of Measure' <Cell ss:StyleID="cell_data"><Data ss:Type="String"></Data></Cell> --> </Row> </xsl:template> <!-- *************** Child Product **************** --> <xsl:template name="generateChildProduct"> <xsl:param name="currentElement"/> <xsl:param name="parentID"/> <xsl:choose> <xsl:when test="//plm:PLMXML/plm:ProductView/plm:Occurrence"> <Row> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Поз.</Data> </Cell> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Обозначение</Data> </Cell> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Наименование</Data> </Cell> <Cell ss:StyleID="heading4"> <Data ss:Type="String">Кол.</Data> </Cell> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Тип</Data> </Cell> <Cell ss:StyleID="heading3"> <Data ss:Type="String">Вес</Data> </Cell> </Row> <xsl:variable name="roe" select="//plm:PLMXML/plm:ProductView/plm:Occurrence[@id=$primaryOccRef]"/> <xsl:variable name="occRefs" select="$roe/@occurrenceRefs"/> <xsl:call-template name="createCL"> <xsl:with-param name="occStr" select="$occRefs"/> <xsl:with-param name="levelID">1</xsl:with-param> </xsl:call-template> </xsl:when> </xsl:choose> </xsl:template> <!-- *************** createCL **************** --> <xsl:template name="createCL"> <xsl:param name="occStr"/> <xsl:param name="levelID"/> <xsl:if test="$occStr!=''"> <xsl:choose> <xsl:when test="contains($occStr,' ')"> <xsl:variable name="occid" select="substring-before($occStr,' ')"/> <xsl:call-template name="createCL"> <xsl:with-param name="occStr" select="$occid"/> <xsl:with-param name="levelID" select="$levelID "/> </xsl:call-template> <xsl:call-template name="createCL"> <xsl:with-param name="occStr" select="substring-after($occStr,' ')"/> <xsl:with-param name="levelID" select="$levelID "/> </xsl:call-template> </xsl:when> <xsl:otherwise> <xsl:call-template name="creCLext"> <xsl:with-param name="occid" select="$occStr"/> <xsl:with-param name="level" select="$levelID "/> </xsl:call-template> </xsl:otherwise> </xsl:choose> </xsl:if> </xsl:template> <!-- *************** creCLext **************** --> <xsl:template name="creCLext"> <xsl:param name="occid"/> <xsl:param name="level"/> <xsl:variable name="occele" select="//plm:PLMXML/plm:ProductView/plm:Occurrence[@id=$occid]"/> <xsl:variable name="occRefs" select="$occele/@occurrenceRefs"/> <xsl:variable name="prtid" select="substring-after($occele/@instancedRef,'#')"/> <xsl:variable name="prtele" select="//plm:PLMXML/plm:ProductRevision[@id=$prtid]"/> <xsl:variable name="itemID" select="$prtele/plm:UserData/plm:UserValue[@title='item_id']/@value"/> <xsl:variable name="itemRev" select="$prtele/plm:UserData/plm:UserValue[@title='item_revision_id']/@value"/> <xsl:variable name="itemName" select="$prtele/plm:UserData/plm:UserValue[@title='object_name']/@value"/> <xsl:variable name="quantity" select="//plm:PLMXML/plm:ProductView/plm:Occurrence[@id=$occid]/plm:UserData/plm:UserValue[@title='Quantity']/@value"/> <xsl:variable name="objecttype" select="$prtele/plm:UserData/plm:UserValue[@title='object_type']/@value"/> <xsl:variable name="weight" select="//plm:PLMXML/plm:form/plm:UserData/plm:UserValue[@title='weight']/@value"/> <xsl:variable name="notesTitle" select="//plm:PLMXML/plm:ProductView/plm:Occurrence[@id=$occid]/plm:UserData[@type='InstanceNotes']/plm:UserValue/@title"/> <xsl:variable name="notesValue" select="//plm:PLMXML/plm:ProductView/plm:Occurrence[@id=$occid]/plm:UserData[@type='InstanceNotes']/plm:UserValue/@value"/> <xsl:choose> <xsl:when test="$occRefs!=''"> <Row> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$level"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$itemID"/>/<xsl:value-of select="$itemRev"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$itemName"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"/> <xsl:value-of select="$quantity"/> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$objecttype"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$weight"/> </Data> </Cell> </Row> </xsl:when> <xsl:otherwise> <Row> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$level"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$itemID"/>/<xsl:value-of select="$itemRev"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$itemName"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$quantity"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$objecttype"/> </Data> </Cell> <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$weight"/> </Data> </Cell> </Row> </xsl:otherwise> </xsl:choose> </xsl:template> </xsl:stylesheet> В XML есть такая строка <UserValue type="real" value="1609.36" title="weight"></UserValue> не получается вытащить вес в таблицу Excel в xsl (более подробно выше) ..... <Cell ss:StyleID="heading3"> <Data ss:Type="String">Вес</Data> </Cell> ....... <xsl:variable name="weight" select="//plm:PLMXML/plm:form/plm:UserData/plm:UserValue[@title='weight']/@value"/> ........ <Cell ss:StyleID="cell_data"> <Data ss:Type="String"> <xsl:value-of select="$weight"/> </Data> </Cell> .......... что у меня не верно колонка ВЕС в эксели появляется только пустая еще пару вопросов подскажите как отсортировать (тоесть X брать втаблицу а Y нет) потом эти X пронумеровать по порядку укажите направление пожалуйста P.S. возможно у меня в xsl файле есть лишние строки ))) ... |
| 11.08.2011, 21:50 |
xml xsl Excel
Откуда в xsl взялся неймспейс plm:? Нет его в исходных данных. ... |
| 11.08.2011, 23:00 |
xml xsl Excel
если даже без plm то не срабатывает подскажите как правильно ? ... |
| 12.08.2011, 06:58 |
start [/forum/topic.php?desktop=1&fid=14&tid=1332892]: |
152ms |
52ms |
| others: | 328ms |
| total: | 578ms |
