Espresso
Здравствуйте! Я использую espresso для тестирования мобильных приложений. Когда я тестирую класс с Activity, то тесты проходят нормально, а когда тестирую с AppCompatActivity, появляется ошибка на уровне @Rule. Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. авторRunning tests Test running started java.lang.NoClassDefFoundError: ru.noticewforddd_00send.com.testespresso.MainActivity at ru.noticewforddd_00send.com.testespresso.MainActivityTest.<init>(MainActivityTest.java:29) at java.lang.reflect.Constructor.constructNative(Native Method) at java.lang.reflect.Constructor.newInstance(Constructor.java:417) at org.junit.runners.BlockJUnit4ClassRunner.createTest(BlockJUnit4ClassRunner.java:217) at org.junit.runners.BlockJUnit4ClassRunner$1.runReflectiveCall(BlockJUnit4ClassRunner.java:266) at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12) at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:263) at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78) at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57) at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290) at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71) at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288) at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58) at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268) at org.junit.runners.ParentRunner.run(ParentRunner.java:363) at org.junit.runners.Suite.runChild(Suite.java:128) at org.junit.runners.Suite.runChild(Suite.java:27) at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290) at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71) at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288) at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58) at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268) at org.junit.runners.ParentRunner.run(ParentRunner.java:363) at org.junit.runner.JUnitCore.run(JUnitCore.java:137) at org.junit.runner.JUnitCore.run(JUnitCore.java:115) at android.support.test.internal.runner.TestExecutor.execute(TestExecutor.java:54) at android.support.test.runner.AndroidJUnitRunner.onStart(AndroidJUnitRunner.java:240) at android.app.Instrumentation$InstrumentationThread.run(Instrumentation.java:1661) ... |
| 04.11.2015, 09:30:01 |
start [/forum/topic.php?desktop=1&fid=13&tid=1331241]: |
64ms |
47ms |
| others: | 229ms |
| total: | 393ms |
