powered by simpleCommunicator - 2.0.59     © 2025 Programmizd 02
Форумы / Android [игнор отключен] [закрыт для гостей] / Berkeley DB: ManagementFactory
2 сообщений из 2, страница 1 из 1
    #39838818
И.Р.
Всем доброе время суток.
При открытии БД вываливается приложение с ошибкой:
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
E/AndroidRuntime: FATAL EXCEPTION: main
    Process: rentp.coffee, PID: 8515
    java.lang.NoClassDefFoundError: Failed resolution of: Ljava/lang/management/ManagementFactory;
        at com.sleepycat.je.dbi.MemoryBudget.<clinit>(MemoryBudget.java:444)
        at com.sleepycat.je.dbi.EnvironmentImpl.<init>(EnvironmentImpl.java:599)
        at com.sleepycat.je.dbi.EnvironmentImpl.<init>(EnvironmentImpl.java:488)
        at com.sleepycat.je.dbi.DbEnvPool.getEnvironment(DbEnvPool.java:192)
        at com.sleepycat.je.Environment.makeEnvironmentImpl(Environment.java:267)
        at com.sleepycat.je.Environment.<init>(Environment.java:252)
        at com.sleepycat.je.Environment.<init>(Environment.java:222)
        at rentp.coffee.BerkeleyDB.<init>(BerkeleyDB.java:42)
        at rentp.coffee.CoffeeDialogFragment.load_countries(CoffeeDialogFragment.java:49)
        at rentp.coffee.CoffeeDialogFragment.onCreateView(CoffeeDialogFragment.java:27)
        at android.support.v4.app.Fragment.performCreateView(Fragment.java:2439)
        at android.support.v4.app.FragmentManagerImpl.moveToState(FragmentManager.java:1460)
        at android.support.v4.app.FragmentManagerImpl.moveFragmentToExpectedState(FragmentManager.java:1784)
        at android.support.v4.app.FragmentManagerImpl.moveToState(FragmentManager.java:1852)
        at android.support.v4.app.BackStackRecord.executeOps(BackStackRecord.java:802)
        at android.support.v4.app.FragmentManagerImpl.executeOps(FragmentManager.java:2625)
        at android.support.v4.app.FragmentManagerImpl.executeOpsTogether(FragmentManager.java:2411)
        at android.support.v4.app.FragmentManagerImpl.removeRedundantOperationsAndExecute(FragmentManager.java:2366)
        at android.support.v4.app.FragmentManagerImpl.execPendingActions(FragmentManager.java:2273)
        at android.support.v4.app.FragmentManagerImpl$1.run(FragmentManager.java:733)
        at android.os.Handler.handleCallback(Handler.java:739)
        at android.os.Handler.dispatchMessage(Handler.java:95)
        at android.os.Looper.loop(Looper.java:135)
        at android.app.ActivityThread.main(ActivityThread.java:5254)
        at java.lang.reflect.Method.invoke(Native Method)
        at java.lang.reflect.Method.invoke(Method.java:372)
        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:903)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:698)
     Caused by: java.lang.ClassNotFoundException: Didn't find class "java.lang.management.ManagementFactory" on path: DexPathList[[zip file "/data/app/rentp.coffee-1/base.apk"],nativeLibraryDirectories=[/vendor/lib64, /system/lib64]]
        at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:511)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:469)
    	Suppressed: java.lang.ClassNotFoundException: java.lang.management.ManagementFactory
        at java.lang.Class.classForName(Native Method)
        at java.lang.BootClassLoader.findClass(ClassLoader.java:781)
        at java.lang.BootClassLoader.loadClass(ClassLoader.java:841)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:504)
        		... 29 more
     Caused by: java.lang.NoClassDefFoundError: Class not found using the boot class loader; no stack available
Application terminated.
Участок кода (Android 5.1 API 22):
Код: java
1.
2.
3.
4.
5.
        EnvironmentConfig ec = new EnvironmentConfig();
        ec.setAllowCreate(true);
        ec.setSharedCache(true);
        env = new Environment(f, ec);
Что где следует искать? Какие мысли по поводу источника ошибки?
    #39838823
Фотография wadman
И.Р.
Код: java
1.
Библиотека взята не для андроида, а для "большой" явы.
