Session variables in SharePoint 2010
Была проблема. Она решена. To enable ASP.NET session state: Enter the following PowerShell command in the SharePoint 2010 Management Shell window: Код: plaintext On each web application for which you want to use session state, edit the web.config file and set the enableSessionState property of the pages element as follows: Код: plaintext Тынц ... |
| 03.06.2011, 18:19 |
start [/forum/topic.php?desktop=1&fid=12&tid=1330451]: |
43ms |
34ms |
| others: | 188ms |
| total: | 300ms |
