jpeg
Prive! Kak mojno v Foxpro (ver:6) otkrit *.doc,*.jpeg,*.bmp fayli? ... |
| 12.08.2005, 15:47:05 |
jpeg
Spasibo, seychas razbirus. U menya yeshyo takoy vopros: yest 2 forma, vizivayu iz odnoy formu druqoy. (pri najatie na knopku: do form form2) Problema v tom chto yesli ya snacala otkroyu 2-yu formu (modi form form2 , potom 'run') potom 1-yu , toqda problema netu, no yesli ya srazu otkroyu 1-yu formu pri najatie na knopku dayut oshibku: "Object form2 is not found" Mojet bit u menya formu nemodalnuyu ,poetomo, no kak formu sdelat modalniy neznayu? ... |
| 12.08.2005, 16:30:19 |
jpeg
Da ,ponyal v chem oshibka moya. Nad forma yest knopka i grid. Pri najatie na knopku v tablitse doljno "pack" delatsa. Kod knopku takoy: pack THISFORM.grid1.Refresh() THISFORM.grid1.SetFocus() Posle najatie na knopku v meste gride pustoy, beliy ekran vxodit. vchem delo? Pomoqite pojalusta. ... |
| 12.08.2005, 17:21:41 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1593694]: |
177ms |
61ms |
| others: | 204ms |
| total: | 501ms |
