Никто не поделится дистрибутивом DTM под DOS?
В целях носталгирования ищу дистрибутив DTM под DOS, никто не знает где можно скачать? Поиск по интеренету ничего не дал :( ... |
| 25.08.2024, 06:46:42 |
user07b9 [игнорируется] ищите ales Readme.txt for WinZip compressed file ales_int.zip ================================================================= This is the International version of the ALES computer program, (English, French, Spanish, Indonesian) available via anonymous FTP at the ALES web site: http://wwwscas.cit.cornell.edu/landeval/ales/ales.htm Or, you can follow the ALES link at: http://www.itc.nl/~rossiter There is an English-only version at the same site. Also at that site is the ALES User's Manual as a PDF file. ALES is a MS-DOS program; here we assume you are running it under MS-Windows. ================================================================= Installation: The zip file is a compressed version of the installed program, complete with folder structure. It was compressed with WinZip and should be decompressed with this same program, available at http://www.winzip.com/ and many shareware sites. 1. Unzip the file *using folder names* to C:\ (the root) >> If you want to install it elsewhere, you will have to modify the file mumps.dbd accordingly after unpacking, as explained in the User's Manual, Chapter 5 2. In a DOS window (or full screen, if you wish): 2.1 >CD c:\dtm 2.2 >ales (or one of the other batch commands) ... |
| 18.11.2024, 17:55:26 |
start [/forum/topic.php?fid=39&gotonew=1&tid=2187000]: |
53ms |
44ms |
| others: | 220ms |
| total: | 367ms |
