Здоровье жестких дисков
Есть сервер, на нем два диска, собранных в RAID1 Помогите, пожалуйста, прочитать результат smartmontools если по 10-ти бальной шкале оценивать, на сколько они потянут) диск1 smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-90-generic] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Toshiba 3.5" DT01ACA... Desktop HDD Device Model: TOSHIBA DT01ACA300 Serial Number: 95DDY39GS LU WWN Device Id: 5 000039 fe3c5e1b7 Firmware Version: MX6OABB0 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Feb 8 23:11:28 2022 MSK SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF ENABLE/DISABLE COMMANDS SECTION === SMART Enabled. === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (21217) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 354) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 140 140 054 Pre-fail Offline - 68 3 Spin_Up_Time 0x0007 139 139 024 Pre-fail Always - 396 (Average 431) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 213 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 31 9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 36794 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 154 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 462 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 462 194 Temperature_Celsius 0x0002 150 150 000 Old_age Always - 40 (Min/Max 18/61) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. диск2 smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-90-generic] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 3.5 Device Model: ST3000DM008-2DM166 Serial Number: Z504LN6J LU WWN Device Id: 5 000c50 0a2bd2376 Firmware Version: CC26 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Feb 8 23:12:54 2022 MSK SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF ENABLE/DISABLE COMMANDS SECTION === SMART Enabled. === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 89) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 325) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x1085) SCT Status supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 150472968 3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 099 099 020 Old_age Always - 1514 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 085 060 030 Pre-fail Always - 368377384 9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33226 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 82 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 043 043 000 Old_age Always - 57 190 Airflow_Temperature_Cel 0x0022 062 051 045 Old_age Always - 38 (Min/Max 33/42) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 35 193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 4702 194 Temperature_Celsius 0x0022 038 049 000 Old_age Always - 38 (0 16 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 26691h+05m+12.484s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 100509442405 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1053148978060 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. ... |
| 08.02.2022, 23:23 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ... |
| 09.02.2022, 11:42 |
Спасибо! Только не понятно почему вы написали, что Raw атрибута Reallocated Sector Count равен 10, может в текстовой форме, которую я приложил сбились поля. По обоим дискам, как я вижу: текущее значение (VALUE) - 100 самое низкое за жизненный цикл (WORST) - 100 порог (THRESH) - по а - 5, по b - 10 или я ошибаюсь? диск а: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. диск b Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. ... |
| 09.02.2022, 16:59 |
Андрей_ONTтекущее значение (VALUE) - 100 самое низкое за жизненный цикл (WORST) - 100 порог (THRESH) - по а - 5, по b - 10 или я ошибаюсь? Ты смотришь на нормализованные значения. Они выставляются изготовителем исходя из "разумных соображений". Параноики смотрят RAW value. Учитывая, что диски в зеркале - можно расслабиться. Без зеркала я бы начал искать замену второму, поскольку мне не нравится сколько у него ошибок чтения. Но тоже без особой срочности, поскольку число reallocated sectors нулевое. Posted via ActualForum NNTP Server 1.5 ... |
| 09.02.2022, 17:22 |
Андрей_ONT Только не понятно почему вы написали, что Raw атрибута Reallocated Sector Count равен 10, может в текстовой форме, которую я приложил сбились поля. это шпаргалка, я для себя писал, куда смотреть ... |
| 09.02.2022, 19:13 |
Dimitry Sibiryakov Андрей_ONTтекущее значение (VALUE) - 100 самое низкое за жизненный цикл (WORST) - 100 порог (THRESH) - по а - 5, по b - 10 или я ошибаюсь? Ты смотришь на нормализованные значения. Они выставляются изготовителем исходя из "разумных соображений". Параноики смотрят RAW value. Учитывая, что диски в зеркале - можно расслабиться. Без зеркала я бы начал искать замену второму, поскольку мне не нравится сколько у него ошибок чтения . Но тоже без особой срочности, поскольку число reallocated sectors нулевое. Это особенность диагностики Сигейтов. Забить. ... |
| 09.02.2022, 19:16 |
Андрей_ONT Есть сервер, на нем два диска, собранных в RAID1 Правильный рйэд1 состоит из трех накопителей. ... |
| 10.02.2022, 14:51 |
Ivan_Pisarevsky мрут в т.ч. при идеальном СМАРТ у меня 10+ дисков померло, и все с херовым смартом ... |
| 10.02.2022, 15:48 |
бабушкин зайчик и все с херовым смартом До этого менял с похожими симптомами четырехтерабайтный сигейт, пришел по обмену его брат близнец, пока в строю. Короче, смарт, смарт-ом, но если инфа представляет коммерческую ценность, то хранить ее надо с резервированием. ... |
| 11.02.2022, 11:34 |
Ivan_Pisarevsky бабушкин зайчик и все с херовым смартом До этого менял с похожими симптомами четырехтерабайтный сигейт, пришел по обмену его брат близнец, пока в строю. Короче, смарт, смарт-ом, но если инфа представляет коммерческую ценность, то хранить ее надо с резервированием. + ... |
| 12.02.2022, 11:51 |
start [/forum/topic.php?fid=30&gotonew=1&tid=1528746]: |
35ms |
39ms |
| others: | 202ms |
| total: | 310ms |
